Can you unzip the attached version of catbind.exe into your Catalina bin directory and try that command again?
bind output file is C:\Users\Public\storage\catalina\target\Catalina.spin
temporary code file name = \s5js.
temporary cnst file name = \s5js.1temporary init file name = \s5js.2temporary data file name = \s5js.3
[COLOR="red"]cannot open temporary files[/COLOR]
[COLOR=red]cannot open temporary files[/COLOR]
Yup I see the problem - catbind is using tmpnam(), which is creating the temporary files in the root directory - something which presumably your user is not allowed to do.
I've updated the catbind binary in the previous post to use tmpfile() instead - can you try that one?
If I don't set CATALINA_TEMPDIR it uses my user's %APPDATA% temporary directory quite happily (for the lcc* files). What's tmpfile() doing differrently?
The tmpfile function creates a temporary file and puts a pointer to that stream in the pFilePtr argument. The temporary file is created in the root directory. To create a temporary file in a directory other than the root, use tmpnam or tempnam in conjunction with fopen.
Now that's odd, because I just created a temporary account on my machine, denied it access to the root folder, and it works ok.
These particular temp files are different to LCC's temp files, so the CATALINA_TEMPDIR setting will have no effect. I have no control over where these particular files are being created - this is up to the operating system. The standard C procedure tmpnam() creates them in the root directory, but tmpfile() is supposed to use /tmp (or its equivalent).
Is there something strange about the user account you are using?
This is getting really annoying, because I can never seem to reproduce anyone else's problems with Windows 7! Everything I do works fine on my machine.
Ross.
P.S. Have to go to VUPES shortly - I'll get back to this later tonight.
I just discovered that Windows 7 requires adminstrative access to create any tmpfiles - i.e. there is no equivalent to /tmp! How braindead can you get?
For the moment, you will have to use an account with administrative access. I'll have to rewrite catbind to stop using temporary files at all.
Why don't you copy the lcc version, at least it looks like it's working? Or is that a no-go under win7 as well?
Yes, that's what I'll have to do. None of the ANSI C functions that are supposed to be used to create tmp files (without having to worry about where they actually get created) seem to work properly under Windows 7. LCC also does a bunch of non-portable stuff to try and find a temp directory, then generate a unique file name - they may have struck a similar problem on other platforms. It's ugly code, but I suppose that I should copy it, since if it works for LCC it will work for me, and if it doesn't work for LCC then it doesn't matter if it works for me or not!
Attached is a screenshot of where the GUI is up to. Now have a multiline text box. Mouse is working, 20x4 LCD screen is also working. Need to work on scrollbars and also add checkboxes. And then get the menu working.
Program is 170k. Ideally this will be a skeleton program where you can add your own code. Currently the buttons etc are being drawn on the screen from code, but there is no reason they could not be drawn on a PC screen and then the positions noted and this turned automatically into C code.
Text is a little slow but there is always scope to speed things up by moving code into cogs. I love the way cogs can be recycled over and over within code.
Quite impressive, Dr_A! I presume this is HiRes VGA? Is there a TV version as well?
Yes this is hi res VGA. It is a little 'blocky' though but I think would end up a perfect resolution for the TV, especially the little 7" LCD TV screens.
I ve tried many things. now I am desperate, I tried on freshly intalled windows xp and I get the same result , I tried on about 4 different machine same result
here attached the lmm_default. file,
My platform is propeller C3 , I didn't even make to compile a hello_world.c
@RossH: I was able to reproduce the File not found error. This - as you stated already - originates from homespun not being able to find the source file, i.e you get the banner and then the error message.
Hi drRobutik,
That file looks ok. I don't think there is anything wrong with your Catalina installation - it appears to be a Homespun problem. I'm sure we'll figure it out.
Did you try step 1 in my previous post (i.e. to check if you can compile anything with Homespun?)
Try the following:
cd C:\Program Files\Catalina
set LCCDIR=C:\Program Files\Catalina
use_catalina
cd catalyst\demo
homespun demo.spin
Simply by calling it manually with a non-existing file. I then went back trying a file name with full path and found that under cygwin - if I use '\' - I (obviously) have to quote the path or use '/'. From a win32 shell both variants work.
There was a post showing the command line for homespun but is that really what is seen by homespun?
Yes, if you add the -v switch to catalina, what is printed as the "assemble command (lmm) = " is just the string I then pass to the system() function call.
Ok - that confirms it is a homespun issue - what's even stranger is that all the files you are compiling exist in the current directory. Let's try a few more things:
1. You may have a PATH problem. Please execute the following command and post the output:
echo %PATH%
2. Verify that you can read/write the file - try editing demo.spin, add a line or two, and save it:
Can you tell me what version of .NET you have installed? Go to "Control Panel->Programs->Turn Windows Features On or Off" and it should display a list of features. In there you will see one or more .NET Framworks listed. Can you tell me what you have installed?
Also, have you installed service pack 1? Go to "Control Panel->Systems and Security->System" and it should tell you the windows edition (including service pack) you are running.
here it is
is anybody have same problem with Catalina on win7?
No - nothing remotely like this. That file is correct, by the way - so now we have two issues:
(1) homespun is adding an extra .spin to the file name - which it should only do if the file does not already have that extension.
(2) homespun thinks Catalyst_Arguments.spin has a syntax error on line 85 - which it doesn't.
It's as if your version of homespun is completely and utterly broken. Can you try the same command with homespun030?
Is it possible for you to install SP1 for Windows 7?
bind output file is C:\Users\Public\storage\catalina\target\Catalina.spin temporary code file name = \s5js. temporary cnst file name = \s5js.1 temporary init file name = \s5js.2 temporary data file name = \s5js.3 [COLOR="red"]cannot open temporary files[/COLOR]
The only files ending up in my private temp areC:\Users\Public\storage\catalina\temp\lcc18082.obj C:\Users\Public\storage\catalina\temp\lcc18080.i C:\Users\Public\storage\catalina\temp\lcc18081.s
Thanks for your help,
Ross.
Ross.
Sheesh!
Ross.
Ross.
Ross.
' dummy.spin PUB null
Hi drRobutik,
Try the following:
cd C:\Program Files\Catalina set LCCDIR=C:\Program Files\Catalina use_catalina cd catalyst\demo homespun demo.spin
Please post the output of this command.Ross.
Aha! good news. How did you reproduce it?
Ross.
Ross.
[code]Microsoft Windows [S
echo %PATH%
2. Verify that you can read/write the file - try editing demo.spin, add a line or two, and save it:notepad demo.spin
Then try the homespun command again.Ross.
C:\Program Files\Catalina>set lccdir=c:\program files\catalina C:\Program Files\Catalina>echo %path% C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\Wind owsPowerShell\v1.0\;D:\PROGRA~1\PICC; C:\Program Files\Catalina>use_catalina =================== SETTING UP CATALINA =================== CATALINA_DEFINE = [default] CATALINA_INCLUDE = [default] CATALINA_LIBRARY = [default] CATALINA_TARGET = [default] CATALINA_LCCOPT = [default] CATALINA_TEMPDIR = [default] LCCDIR = c:\program files\catalina C:\Program Files\Catalina>echo %path% c:\program files\catalina\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32 \Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;D:\PROGRA~1\PICC; C:\Program Files\Catalina>
2. seems no problem on reading and writing.Can you tell me what version of .NET you have installed? Go to "Control Panel->Programs->Turn Windows Features On or Off" and it should display a list of features. In there you will see one or more .NET Framworks listed. Can you tell me what you have installed?
Ross.
Frame work 4
I can't see sp1 for win7 installed
Ok. There's a couple of possibilities - I'll try with .NET framework 4. Can you also try the homespun command again, but add -i7 - i.e:
homespun demo.spin -i7
Ross.C:\Program Files\Catalina\catalyst\demo>homespun Demo.spin -i7 Homespun Spin Compiler 0.30 Demo.spin.spin? File not found C:\Program Files\Catalina\catalyst\demo>
Aha! "Demo.spin.spin" is not right - how come your homespun is adding another extension? Try just:
homespun demo
Ross.C:\Program Files\Catalina\catalyst\demo>homespun demo -i7 Homespun Spin Compiler 0.30 demo.spin? parsing demo.spin Catalyst_Arguments.spin? parsing Catalyst_Arguments.spin Error: Catalyst_Arguments.spin (85, 8): Expected "(eol)", got long if long[COGSTORE] == CMD_RESPONSE ^ C:\Program Files\Catalina\catalyst\demo>
Okay - we're making progress, but this is really wierd!
Can you please post your Catalyst_Arguments.spin file?
Ross.
Ross.
