Catalina 3.0 - Page 12 — Parallax Forums
Catalina 3.0
191012141517
    edited 2011-05-14 22:05
    RossH wrote: »
    Can you unzip the attached version of catbind.exe into your Catalina bin directory and try that command again?
    bind output file is C:\Users\Public\storage\catalina\target\Catalina.spin
    temporary code file name = \s5js.
    temporary cnst file name = \s5js.1
    temporary init file name = \s5js.2
    temporary data file name = \s5js.3
    [COLOR="red"]cannot open temporary files[/COLOR]
    The only files ending up in my private temp are
    C:\Users\Public\storage\catalina\temp\lcc18082.obj
    C:\Users\Public\storage\catalina\temp\lcc18080.i
    C:\Users\Public\storage\catalina\temp\lcc18081.s
  • RossHRossH Posts: 5,593
    edited 2011-05-14 22:33
    kuroneko wrote: »
    [COLOR=red]cannot open temporary files[/COLOR]
    Yup I see the problem - catbind is using tmpnam(), which is creating the temporary files in the root directory - something which presumably your user is not allowed to do.
    I've updated the catbind binary in the previous post to use tmpfile() instead - can you try that one?
    Thanks for your help,
    Ross.
    edited 2011-05-14 22:39
    Back to square one, cannot open temporary files.
    If I don't set CATALINA_TEMPDIR it uses my user's %APPDATA% temporary directory quite happily (for the lcc* files). What's tmpfile() doing differrently?
    VC-Help wrote:
    The tmpfile function creates a temporary file and puts a pointer to that stream in the pFilePtr argument. The temporary file is created in the root directory. To create a temporary file in a directory other than the root, use tmpnam or tempnam in conjunction with fopen.
    edited 2011-05-14 22:56
    kuroneko wrote: »
    Now that's odd, because I just created a temporary account on my machine, denied it access to the root folder, and it works ok.
    These particular temp files are different to LCC's temp files, so the CATALINA_TEMPDIR setting will have no effect. I have no control over where these particular files are being created - this is up to the operating system. The standard C procedure tmpnam() creates them in the root directory, but tmpfile() is supposed to use /tmp (or its equivalent).
    Is there something strange about the user account you are using?
    This is getting really annoying, because I can never seem to reproduce anyone else's problems with Windows 7! Everything I do works fine on my machine.
    Ross.
    P.S. Have to go to VUPES shortly - I'll get back to this later tonight.
    edited 2011-05-14 23:04
    Hi kuroneko,
    I just discovered that Windows 7 requires adminstrative access to create any tmpfiles - i.e. there is no equivalent to /tmp! How braindead can you get?
    For the moment, you will have to use an account with administrative access. I'll have to rewrite catbind to stop using temporary files at all.
    Sheesh!
    Ross.
    edited 2011-05-14 23:56
    RossH wrote: »
    Why don't you copy the lcc version, at least it looks like it's working? Or is that a no-go under win7 as well?
    edited 2011-05-15 03:54
    kuroneko wrote: »
    Yes, that's what I'll have to do. None of the ANSI C functions that are supposed to be used to create tmp files (without having to worry about where they actually get created) seem to work properly under Windows 7. LCC also does a bunch of non-portable stuff to try and find a temp directory, then generate a unique file name - they may have struck a similar problem on other platforms. It's ugly code, but I suppose that I should copy it, since if it works for LCC it will work for me, and if it doesn't work for LCC then it doesn't matter if it works for me or not!
    Ross.
    edited 2011-05-15 05:15
    Attached is a screenshot of where the GUI is up to. Now have a multiline text box. Mouse is working, 20x4 LCD screen is also working. Need to work on scrollbars and also add checkboxes. And then get the menu working.
    Program is 170k. Ideally this will be a skeleton program where you can add your own code. Currently the buttons etc are being drawn on the screen from code, but there is no reason they could not be drawn on a PC screen and then the positions noted and this turned automatically into C code.
    Text is a little slow but there is always scope to speed things up by moving code into cogs. I love the way cogs can be recycled over and over within code.
    936 x 909 - 121K
    edited 2011-05-15 15:56
    Dr_Acula wrote: »
    Quite impressive, Dr_A! I presume this is HiRes VGA? Is there a TV version as well?
    Ross.
    edited 2011-05-15 16:11
    Yes this is hi res VGA. It is a little 'blocky' though but I think would end up a perfect resolution for the TV, especially the little 7" LCD TV screens.
  • drRobutikdrRobutik Posts: 15
    edited 2011-05-18 01:37
    Hi Ross,
    I ve tried many things. now I am desperate, I tried on freshly intalled windows xp and I get the same result , I tried on about 4 different machine same result
    here attached the lmm_default. file,
    My platform is propeller C3 , I didn't even make to compile a hello_world.c :(
    edited 2011-05-18 02:02
    drRobutik wrote: »
    I ve tried many things. now I am desperate, ...
    Just to remove that possibility, can you compile a minimal SPIN file with homespun from the command line, e.g. homespun030 dummy.spin?
    ' dummy.spin
    PUB null
    edited 2011-05-18 02:07
    @RossH: I was able to reproduce the File not found error. This - as you stated already - originates from homespun not being able to find the source file, i.e you get the banner and then the error message.
    edited 2011-05-18 02:22
    drRobutik wrote: »
    Hi Ross,
    Hi drRobutik,
    That file looks ok. I don't think there is anything wrong with your Catalina installation - it appears to be a Homespun problem. I'm sure we'll figure it out.
    Did you try step 1 in my previous post (i.e. to check if you can compile anything with Homespun?)
    Try the following:
    cd C:\Program Files\Catalina
    set LCCDIR=C:\Program Files\Catalina
    use_catalina
    cd catalyst\demo
    homespun demo.spin
    Please post the output of this command.
    Ross.
    kuroneko wrote: »
    Aha! good news. How did you reproduce it?
    Ross.
    edited 2011-05-18 02:30
    RossH wrote: »
    Simply by calling it manually with a non-existing file. I then went back trying a file name with full path and found that under cygwin - if I use '\' - I (obviously) have to quote the path or use '/'. From a win32 shell both variants work.
    There was a post showing the command line for homespun but is that really what is seen by homespun?
    edited 2011-05-18 02:33
    [code]Microsoft Windows [S
    edited 2011-05-18 02:37
    kuroneko wrote: »
    Yes, if you add the -v switch to catalina, what is printed as the "assemble command (lmm) = " is just the string I then pass to the system() function call.
    Ross.
    edited 2011-05-18 02:38
    and for the dummy.spin
    edited 2011-05-18 02:42
    Hi drRobutik,
    Ok - that confirms it is a homespun issue - what's even stranger is that all the files you are compiling exist in the current directory. Let's try a few more things:
    1. You may have a PATH problem. Please execute the following command and post the output:
    echo %PATH%
    2. Verify that you can read/write the file - try editing demo.spin, add a line or two, and save it:
    notepad demo.spin
    Then try the homespun command again.
    Ross.
    edited 2011-05-18 03:02
    1.
    C:\Program Files\Catalina>set lccdir=c:\program files\catalina
    C:\Program Files\Catalina>echo %path%
    C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\Wind
    owsPowerShell\v1.0\;D:\PROGRA~1\PICC;
    C:\Program Files\Catalina>use_catalina
       SETTING UP CATALINA
    CATALINA_DEFINE  = [default]
    CATALINA_INCLUDE = [default]
    CATALINA_LIBRARY = [default]
    CATALINA_TARGET  = [default]
    CATALINA_LCCOPT  = [default]
    CATALINA_TEMPDIR = [default]
    LCCDIR           = c:\program files\catalina
    c:\program files\catalina\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32
    \Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;D:\PROGRA~1\PICC;
    2. seems no problem on reading and writing.
    edited 2011-05-18 03:10
    drRobutik,
    Can you tell me what version of .NET you have installed? Go to "Control Panel->Programs->Turn Windows Features On or Off" and it should display a list of features. In there you will see one or more .NET Framworks listed. Can you tell me what you have installed?
    Also, have you installed service pack 1? Go to "Control Panel->Systems and Security->System" and it should tell you the windows edition (including service pack) you are running.
    Ross.
    edited 2011-05-18 03:17
    Hi RossH,
    Frame work 4
    I can't see sp1 for win7 installed
    edited 2011-05-18 03:24
    drRobutik,
    Ok. There's a couple of possibilities - I'll try with .NET framework 4. Can you also try the homespun command again, but add -i7 - i.e:
    homespun demo.spin -i7
    Ross.
    edited 2011-05-18 03:30
    RossH wrote: »
    drRobutik,
    Ross.
    C:\Program Files\Catalina\catalyst\demo>homespun Demo.spin -i7
    Homespun Spin Compiler 0.30
    Demo.spin.spin?
    File not found
    edited 2011-05-18 03:40
    drRobutik wrote: »
    Demo.spin.spin?
    File not found
    Aha! "Demo.spin.spin" is not right - how come your homespun is adding another extension? Try just:
    homespun demo
    Ross.
    edited 2011-05-18 03:41
    C:\Program Files\Catalina\catalyst\demo>homespun demo -i7
    demo.spin?
    parsing demo.spin
    Catalyst_Arguments.spin?
    parsing Catalyst_Arguments.spin
    Error: Catalyst_Arguments.spin (85, 8): Expected "(eol)", got long
        if long[COGSTORE] == CMD_RESPONSE
    edited 2011-05-18 03:44
    drRobutik,
    Okay - we're making progress, but this is really wierd!
    Can you please post your Catalyst_Arguments.spin file?
    Ross.
    edited 2011-05-18 03:46
    here it is
    is anybody have same problem with Catalina on win7?
    edited 2011-05-18 03:55
    drRobutik wrote: »
    here it is
    No - nothing remotely like this. That file is correct, by the way - so now we have two issues:
    (1) homespun is adding an extra .spin to the file name - which it should only do if the file does not already have that extension.
    (2) homespun thinks Catalyst_Arguments.spin has a syntax error on line 85 - which it doesn't.
    It's as if your version of homespun is completely and utterly broken. Can you try the same command with homespun030?
    Is it possible for you to install SP1 for Windows 7?
    Ross.
