Viewport v1.2: Free 80Mhz Scope- inside your own program! — Parallax Forums
HannoHanno Posts: 1,130
edited 2007-09-03 07:10 in Propeller 1
Viewport v1.2, the tool that let’s you into the Propeller, is ready for free download at: mydancebot.com
Viewport uses a 2Mbaud connection between a graphical Windows-based application and a cog running alongside your program to let you monitor and change variables in your running spin program.
New features include:
  • A QuickSample object that lets you view all 32 I/O bits at up to 80Mhz- while your program is running. A one-line change to your existing program let’s you see a graph of what’s happening to each bit- with triggers, timescales from 50ns/div to 5s/div and memory limited only by our pc.
  • Applets are pre-built Propeller programs that display data within Viewport and take input from Windows controls like scrollbars, textboxes and checkboxes. Viewport shows you available applets (with description and link to the spin file) and then lets you load to the propeller ram/eeprom. We’ve includes applets to let you interact with LEDs, motors, ping and compass sensors.
  • Check out the website for a video tutorial, help documentation, application notes, and more.
Requirements:
  • Parallax Propeller driven by a 5mhz crystal
  • A Parallax PropPlug to provide a 2Mbps USB connection between PC and Propeller
  • 500Mhz PC with 100MB RAM running Windows XP natively
  • 1MB hard drive space
  • .NET Framework
* Advanced users have succeeded using Viewport in environments different than this: on a Mac, on Linux, inside of a virtual machine...
A big thanks to our beta testers: Ingolf, George, and especially Harley. Here’s what Harley has to say about Viewport:
"Before Viewport, I had trouble programming and debugging the Propellers for a Z80 emulator design- it was difficult for me to see what was happening inside- there is only so much a blinking LED can tell you. Now, I can see AND edit variables in my program and also watch what's happening on the 32 IO lines at high speed with NO wires!"
Enjoy!
Hanno
[url=http://myDancebot.com: Home of the affordable balancing robot]myDancebot.com: Home of the affordable balancing robot[/url]
Post Edited (Hanno) : 9/4/2007 8:13:41 PM GMT
  • bulkheadbulkhead Posts: 405
    edited 2007-08-21 05:33
    I just used this recently as a 20MHz scope, and it worked great! I needed to see some signals with a scope, so I decided to check Viewport out. After just 5 minutes of downloading and installing, and another 5 minutes of figuring out the program, my propeller was up and monitoring 32 channels (I only needed 4 though).
    I'm new to the propeller!
  • HarleyHarley Posts: 997
    edited 2007-08-21 06:12
    And for allowing me to help you while learning about how useful ViewPort can be. yeah.gif
    Harley Shanko
    h.a.s. designn
  • BergamotBergamot Posts: 185
    edited 2007-08-21 17:52
    This tool is shaping up to be really awesome!
    Any chance of releasing the source? It'd be nice to tinker with the interface a little.
  • Rob7Rob7 Posts: 275
    edited 2007-08-21 18:06
    What a great tool to have in our tool box for a great chip !
    " The Propeller"
    Need I say more ?
    Rob7
    edited 2007-08-22 09:09
    Looking really good, I also like your little video guide.
    Graham
  • Franz AchatzFranz Achatz Posts: 140
    edited 2007-08-22 09:57
    Hallo Hanno,
    kompliment, dein ViewPort sieht sehr gut aus.
    Ein tolles Propeller Tool.
    Super Video Tutorial.
    viele Gr
  • GavinGavin Posts: 134
    edited 2007-08-22 12:59
    I would have been happy with just a serial port debug terminal in the prop tool.
    This is smoking hot software, a logic analyser built into the code.
    Well done Hanno.
    This is going to make prop stuff even more fun and much easier to debug.
    Paul, Chip, this is so good can you please add it to a future version of the tool?
    Gavin
    edited 2007-08-22 15:46
    I'm curious how many forum readers have read about ViewPort and dismissed it as if they have no need for it at present. As the saying goes "Try it, you'll like it!!"
    This is one great tool. Even at this relatively early release time.
    It is working for my needs in LSA mode quite well. Much better than hooking up scope probes, or many logic analyzer probes, to be able to view what's happening just on the I/O pins.
    It also allows one to view the values of variables INSIDE the chip!!! yeah.gif Did you KNOW that?
    Here's one/another satisfied 'customer'.
    Harley Shanko
    h.a.s. designn
  • HannoHanno Posts: 1,130
    edited 2007-08-22 20:40
    Thanks and "Vielen Dank" to everyone for all the kind words. The video seems to be quite a hit- we'll look into doing another one- any requests? We've updated the "Help" section - especially the chapter on integrating your program with Viewport and QuickSample- so if you've been confused before, please have another go. We're very interested to see what people are doing with Viewport- if you have a nice measurement of something please share it on this forum (Viewport let's you save directly to a GIF file) or send it our way!
    Hanno
  • mirrormirror Posts: 322
    edited 2007-08-22 21:58
    I like the idea of ViewPort, but have been unable to use it as my board was developed using a standard RS232 convertor, so wont do 2MBaudcry.gif· Would it be possible to select some other baud rate - like 115200?
    edited 2007-08-23 03:36
    We've heard from a couple people who would like Viewport to support a slower baud rate... Unfortunately this is not as easy as changing a constant- both the Propeller and the Windows side are heavily optimized to support 2mbps. Our early prototype only supported 115k- and we are MUCH happier with the faster speed. Now, the screen updates basically in real time- and we can even stream 200ksamples/second when looking at single byte data.
  • rjo_rjo_ Posts: 1,825
    edited 2007-08-23 16:02
    Hanno,
    Any word on when the DanceBot kits will be released?
    Any chance of seeing Viewport work remotely?
    Amazing stuff!!!
    Rich
  • PaulPaul Posts: 263
    edited 2007-08-23 19:20
    Installation says to install .net framework. Any way around that? Due to bugs, it's not allowed here.
    Paul
    edited 2007-08-23 19:49
    Paul said...
    Paul
    Not really, no.
    edited 2007-08-24 00:55
    Paul- Yes, .net framework is required. No way around that.
    rjo- For the next release- v1.4, we're working on a "wireless" mode. This would allow you to disconnect the USB plug, take measurements with the Propeller, and then reconnect the USB connection to download the data. The Propeller uses very little power when idle, so this would allow you to run the Propeller from a 9V battery and take measurements over multiple days... We intend to measure temperature, color, and possibly ph of our beer while it's fermenting. The possibilities are endless!
    The dancebot is coming along- we're striving for very high design goals while making it affordable enough to use for all sorts of hobby applications. No firm dates yet- but if you're interested in helping beta-test a bot please let us know!
  • RaymanRayman Posts: 16,233
    edited 2007-08-29 15:33
    Very·cool software.·
    At 80 MSPS, the propagation delay between cogs causes a slight distortion in the sample rate, but probably not enough to worry too much about.
    Any chance you could make this work with Windows Vista x64?· I had it working a little, but it crashes when trying to change settings...
    For 20 MSPS, could the LSA and Conduit be combined so as to only use one cog?· (I think you need 2 now, right?)
    Ray
    edited 2007-08-29 20:04
    Rayman,
    Glad you like it!
    Are you able to characterize the distortion? The cogs run interleaved- first cog 1, 2 ,3 then 4- just like a four cylinder engine. The cogs take measurements when the clock pulse reaches them- if the clock pulse reaches some cogs faster than others, then those cogs would take measurements slightly earlier than they should.
    Anybody from Parallax- any way of minimizing this distortion by choosing specific cogs?
    Theoretically it might be possible to combine the 20mhz and conduit to run in 1 cog. However, the conduit is doing FULL duplex serial communication at 2mbps- so sending data from the pc to the propeller would be much more involved - you would have to resend an attention byte until acknowledged by the propeller. We're already doing some of this- but this would make an already complex system even more complex.
    At the moment we're working on other features that we believe provide more value:
    - a wireless mode (letting you disconnect the propplug, take measurements for days, then reconnect to get the data)
    - advanced triggers (edge, pattern modes for all channels- frame, analog values, and even virtual channels)
    - and taking analog measurements up to 40msps at 8 bit resolution.
    Speaking of "providing value"- we don't see any value in Windows Vista and won't migrate our shop. If someone wants to help us by providing debugging information (turn on the "trace log" in edit/preferences, then look for the file: "c:/viewport.log") we'll fix those bugs.
  • BradCBradC Posts: 2,601
    edited 2007-08-30 10:43
    I was trying to use viewport a day or so ago. I mostly got it to work in 20Mhz mode, the pre-packaged 80Mhz mode would not come up on my demo board at all.
    If we are looking at feature requests, a one-shot trigger mode would be handy. I was trying to capture some very fast data trains, but they kept scrolling off the screen and I could find no way to slide the window across to let me see them, even though I saw them scroll past. A one shot trigger mode would allow me to capture a single frame and view it at my leisure.
    Of course, if it's there and I've missed it, or there is a way to scroll back the history window (won't here anyway) then I'd love to be pointed in the right direction.
    Nice bit of software though.. It'll come in handy.
    edited 2007-08-30 20:33
    Ok, I don't get it...
    I've looked at the "QuickSample_12" assembly code, but don't see how it can aquire at 20 MSPS...
    The chip is running at 80 MHz, but it takes (at least) 4 clock cycles to execute an instruction. So, it's running at 20 MIPS.
    So, to aquire at 20 MSPS, every instruction must be a MOV from INA.
    I would think the only way to do this would be to have many MOV instructions in a row. But, I don't see that in your code (unless the code itself is generating these instructions somehow).
    Hanno, can you clue me in?
    edited 2007-08-30 21:02
    There is no propagation delay with INA and the cogs, the IO pins buffer the signal onto a bus, any propagation delay would be due to transmission effect and would be in the picoseconds, not enough to be anywhere close to noticable. It is only the OUTA that experiences a proagation delay according to cog and pin location and that is outlined in the datasheet.
    Hanno's program achieves higher aquisition rates by using multiple cogs and interleaving the clock cycle each cog samples the INA bus.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 8/30/2007 9:41:55 PM GMT
    edited 2007-08-30 21:16
    Hallo Hanno,
    hast du schon was von Steve V... aus NZ geh
    edited 2007-08-30 23:16
    Paul,
    The manual says there is a 1 to 1.5 ns delay from the first cog to the last for I/O signals. So, with 4 cogs there is ~3/4 of a ns or so offset. This is not a totaly insignificant fraction of 12.5 ns period. Are you saying this 1 to 1.5 ns delay only when used as an output, not input?
    As I understand it, Hanno achieves 20 MSPS with 1 cog and uses 4 cogs to get 80 MSPS. But, I don't see how his code can do this...
    edited 2007-08-31 00:48
    Correct, that is output only, it does not apply to input.
    If each cog waits for the counter to reach a certain value, but each is offset by 1 clock cycle then each will be synchronous to a different clock cycle so data is grabed by the following cog order 1,2,3,4,1,2,3,4,1,...
    Paul Baker
    edited 2007-08-31 01:09
    Paul,
    Thanks for the info on the propagation delay. Looks like Viewport should be able to measure up to 80mhz with no significant artifacts. And yes, QuickSample interleaves the measurements.
    I like to give the analogy that it runs like a 4 Cylinder/4 Stroke engine. Each Cylinder fires Once every 4 Strokes. But, if you interleave 4 of them, then you get a "fire" on every stroke!
    Rayman
    My assembly code dynamically generates the code to take the measurements- that's why you don't see 400 MOV instructions in a row. For the single-cog version, the dynamic code is regenerated for every set of measurements- as the code runs completely in it's own cog and destroys its code as it stores the measurements. To support all the different sampling frequencies, the code actually implements 5 different cases:
    *4 Cog Mode:
    - at 80Mhz each cog takes 1 sample every 4 clock cycles- for a total of 1600 samples. They're interleaved, so a sample is taken every clock cycle.
    - at 40Mhz cogs 1 and 2 run interleaved to take the first 800 samples- so a sample is taken every 2 clock cycles- then cogs 3/4 take the last 800 samples
    - at frequencies <=20Mhz, the cogs run interleaved, but don't run dynamically generated code anymore- a simple wait loop is sufficient. Again, this yields 1600 samples.
    *1 Cog Mode:
    - at 20Mhz, the dynamic code takes 1 measurement every 4 clock cycles- taking 400 samples
    - below 5Mhz, a wait loop takes the measurement whenever needed
    Franz- No, I haven't heard from Steve...
    BradC- Yes, we've had requests for "single-shot" mode- and are working on it now. The "time scrollbar" currently lets you scroll through the non-frame channels. These channels (which represent variables in your program) are updated at 2Mbps- giving you high time resolution- up to 200ksps if monitoring a single byte variable. For example, we take minutes worth of data and can then inspect the data at any timescale- from seconds/div to usec/div for ANY of that data! A PC based scope is very powerful!
    For inspiration on what to do with Viewport, take a look at some of the case studies now on the applications page:mydancebot.com/products/viewport/applications.php
    Ingolf is taking 8bit ANALOG measurements at up to 40MSamples/Second! Support for analog measurements will be released in the next version!
    Post Edited (Hanno) : 8/31/2007 3:57:43 AM GMT
  • SkogsgurraSkogsgurra Posts: 231
    edited 2007-08-31 03:32
    A question of order.
    There has been some German text here. Das is fein, kein Problem f
    edited 2007-08-31 12:55
    Hanno,
    Thanks for clearing that up! I knew that's the only way it could work, but had trouble following the code... The interleaving for 80 MSPS with 4 cogs using the system clock was easy to see. But, I didn't see many MOV instructions. I guess dynamically generating the code is the only way to go to have flexibility in aquisition rate with a small footprint...
    I wonder if it would be possible to use multiple cogs, not to increase sample rate, but to multiply the acqusition depth. 400 samples is good, but 800 or 1200 would be better. Some of the first digital scopes had 50 points/ division with 10 horizontal divisions. They typically had 512 points. I think the system clock could also be used to coordinate cogs in this way too, right?
    I noticed the way you used two variables to indicate when aquisition was started and stopped to coordinate between the LSA and the conduit. Did you think about using the built-in "locks" instead? It seems that this is what they were made for...
    edited 2007-08-31 20:41
    Rayman,
    Yes, assembly code which dynamically generates its own code is not easy to follow.
    If you're using the 4 cog mode 1600 samples will be taken at whatever sampling rate you desire- look at my previous post again... If you're using 1 cog only 400 samples will be taken. Each cog has 512 LONGS of fast memory available, this is shared between the measurement data (406 long), and the assembly code and variables.
    Yes, I thought about using "locks"- however, I'm also using the "synchronization" markers to tell Viewport- running on the PC, that the frame was complete. While complex, the current method assures that variable data is updated at a constant rate and that Viewport only draws complete frames.
    Another cool feature of the single cog acquisition mode is the "interruptible 0 latency" trigger. From Viewport you can change the trigger/timescale even while a trigger is waiting for a signal. The 0 latency feature (only for the single cog mode) means you're measurements are accurate to 1 clock cycle- 12.5ns!
  • janbjanb Posts: 74
    edited 2007-09-02 00:25
    I try to install this 80 MHz scope on my laptop and got stuck on some comunication problem.
    I'm using USB <-->rs232 dongle from Paralax and have no problem w/ loading spin code to propeller.
    However, once I have started Vieport I see this error message:
    Looking for a Viewport Object to connect to:
    Trying COM5...Opened, but no Viewport Object found
    Looking for Propeller:
    Trying COM5...Found Propeller v 1 on COM5
    Propeller found on COM5 but could not communicate with a Viewport Object.
    Please load a Propeller Program that uses a Viewport Object.
    You can load Viewport Applets using the Load Button
    I have uploaded the following code to ·EPROM
    pub run|pin,switch
     vp.start(31, 30,@pin,String("No Data-just switch the LED on/off with the Switch:1s/div:DSO:pin=16,switch!"))
     'starts Viewport- textbox for pin, checkbox for switch
     dira[noparse][[/noparse]17]~~
     repeat
       dira[noparse][[/noparse]pin]~~
       !outa[noparse][[/noparse]17]
       outa[noparse][[/noparse]pin]:=switch
       waitcnt(_1s/4+cnt)
    and I see it is running because LED is blinking @ 4Hz. Although it always stops blinking for ~1 second after I press 'Connect' button in Viewport. But a secnd later it blinks again.
    Any hint what I should check?
    Jan
    edited 2007-09-02 00:52
    Jan,
    Are you sure your clock is configured correctly? Your program should start with:
    CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    This configures the Propeller to run from an external crystal (you should be using a 5Mhz crystal) and uses the pll multiplier to set a 80Mhz clock. If the timing is wrong, the Propeller won't be able to communicate with the Viewport program.
    The Viewport program looks for a running Viewport object on a propeller using 2 passes. In the first pass, it checks for incoming serial data on all available com ports. If it detects a valid signal, it processes the configuration and becomes "connected". If it doesn't, it tries to find a Propeller- by sending the reset signal and a special code to which the propeller replies with a version number.
    I believe what's happening is that your program runs fine, but at the wrong clock rate. This causes Viewport to not understand the Propeller, reset it, and then find just the valid Propeller on the correct port. This "reset" causes the 1 second delay in blinking.
    edited 2007-09-02 00:59
    Hi Hanno,
    I used just your demo, first from the top, and did not touch your clock lines, this is full code.
    CON
      _1s=80_000_000
    OBJ
     vp    :       "ViewportConduit_12"  'transfers data to/from PC
    pub run|pin,switch
     repeat
       waitcnt(_1s/4+cnt)
    I'm using propeller stick - would it make·a difference?
    I'm really stuck
    Jan
