Reversible video card
Oldbitcollector (Jeff)
In my quest for the Ultimate Protoboard, I fell on the idea of creating a reversible video card to make the board compatible with both the Hydra as well as popular Demo/Proto configurations. Since I have a friend who is planning to start on his own Propeller project, I've been documenting everything carefully, and once again thought I'd share with the forum.
Here's the doc.
Oldbitcollector
UPDATE: Something I failed to mention in this document is that you will want to create removable resistors
on the keyboard/mouse pins. In my own version, I used a pin/header system to plug in a small resistor pack which
can be removed easily for Hydra video use.
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Post Edited (Oldbitcollector) : 8/1/2007 6:47:35 AM GMT
Here's the doc.
Oldbitcollector
Gr,
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
| "Wait...if that was a compliment, why is my fist of death tingling?"
| - Alice from Dilbert
Oh and before I do go ahead an make myself one of these, there are ways to make the Prop output a PAL signal, right, preferably with the same objects as you would for NTSC (with some tweaks, naturally).
Gr,
Mightor
Anyone interested in S-video output? You will see information explaining how to fabricate the needed DAC and which resistors connect to Y and C signals comented within the modified graphics demo attatched. For pinouts of the S-video plug, pinouts.ru is an exellent scource.
Consult the TV drivers documentation at the end of tv's DAT section for PAL/NTSC, Progresive/interlace modes for better adjustability. It does give a cleaner picture.
Enjoy
I wouldn't be surprised if the Gen II prop came with a generic DVI and RGB Comosite/HMDI driver lol.
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Post Edited (RinksCustoms) : 7/31/2007 6:13:50 AM GMT
