A new Propeller Board
Hi Propeller Freaks,
here is the final result.
- Propeller Chip with ext. XTAL 5 MHZ
- I2C EEPROM
- Audio
- SD Memory Slot
- USB Programming Interface
- Ethernet ENC28J60 Interface
- XBee Module (optional)
- Power via USB
- Power via Barrel·Connector (6 ...9 VDC)
- VGA
- TV Video
- PS2 Mouse Interface
- PS2 Keyboard Interface
- Port Pins P0...P27 available via Pinheader
- Reset Switch
- User LEDs for P22 and P23
- VGA and Video can be disabled via the DIL Switches
-·prof-made 2 layer board with toplayer silkscreen
- board dimensions 80x100mm
- CDROM with schematics, easyPROP Demosoftware·and Manual included
have fun
Franz
Post Edited (Franz Achatz) : 7/29/2007 10:57:11 PM GMT
- I2C EEPROM
- Audio
- SD Memory Slot
- Power via USB
- VGA
- TV Video
- Reset Switch
have fun
Franz
Great looking board and schematic!
Do you mind if I ask, what software you use?
Also, would it be possible to bring P12-23 out and use jumpers or dip switch to enable TV/VGA to free up I/O?
Carl
PS Selling this board?
i use Eagle from www.cadsoft.com
The full-working Demo can be downloaded.
Just added a SD Slot and connected it to P0..P3.
Will have a look to bring more I/Os down.
>Selling this board?
First i am going to make a first Proto PCB run with about 25 pcs or so.
have fun
Franz
Looks great,
I like the SD card add on,built in !
When will you have this ready to go ?
Any idea on priceing ?
When can we start placeing orders ?
Rob7
Post Edited (Rob7) : 7/3/2007 2:33:16 PM GMT
>When will you have this ready to go !
i just started yesterday with the design and its not ready, yet.
Hope that i can place an order in china, end of this week
Need more ideas !!!!
How about placing Pinheaders for an XBee-Module on this Board ?????
XBee works with3.3V as well.
have fun
Franz
So, I get the XBee fuction right !
Rob7
I’m game for one!
I would use an EEPROM with more storage. (On my Prop Dongle I use a 1024Kbit EEPROM).
You could probably get rid of one of the PS/2 connectors if you wanted. Very few things need BOTH a keyboard and a mouse.
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
you have forgotten the RCA for sound on pin 10 and 11 via the simple RC-circuitry. It would be nice if you could add this to your board.
I would also recommend to configure all wired circuitry on Propeller pins except USB and EEPROM via jumper or dip switch.
Thomas
DIP EEPROM solderd and Propeller socket
DIP Socket and Propeller with two sockets
Maybe i use a smd eeprom.
@Thomas:
where can i find this simpel RC-Circuitry???
Franz
(Without the pullups, things may generally appear to work, but the spec
says to have the pullups. Without them there's danger that we could
have floating inputs which can lead to excessive power consumption
and possibly even chip failure. It's also possible a floating input will
cause the chip to get into a "bad" state from which it doesn't recover.)
Are you going to sell this populated, or unpopulated? If unpopulated, it would
be nice to make a propclip/propplug connector for people that don't want to
populate the USB portion.
See updated schematic.
good idea
Yes, both options, after the board works.
So, we now have:
- USB
- Mouse
- Keyboard
- TV
- VGA
- SD Slot
- XBee
have still to re-arange some part-settings for having more I/Os available, if needed.
Franz
Seems like a smaller Propeller part would allow the overall board to shrink and/or give you more room for prototyping.
Jim C
I would also say go for the smaller Prop package if possible.
yes there is.
I love doing everthing in smd (see foto) but i am thinking about the hobbyist
who is not so "handy" in smd soldering.
By the way if the Propeller smd chip gets killed most people have a big problem.
Therefore i was thinking about using a DIL-Prop.
@rokicki
i think DAT1 and DAT2·is not needed ???
Franz
BTW, your design looks really nice. I'd be interested in one
What Stefan proposes is also interesting.
here you can find the simple circuit for sound. You have it to use twice, one for each sound channel.
http://forums.parallax.com/showthread.php?p=606294
Thomas
·· That's how the PropSTICK was setup...EEPROM hidden under the DIP Propeller Chip.· Slick place to hide many components.
I would suggest going with a microSD and q44 prop chip to save space. Yeah, I know about having to solder the q44 prop if it goes bad, but the chip is pretty tough.
With MicroSD's for under $5 for 512MB, and just a postage stamp to mail, I don't know why they haven't caught on more in this forum. I use one with the sparcfun breakout adapter, and it works well.
Also, I would like a switch to power the whole thing off the usb port, if you can swing it under 500mA 5V.
Doug
did some work and changed the eeprom and propeller-chip to a smd type.
Two dip-switches are now onboard for disconnecting VGA and TV.
See the updated drawings !!!!
More things to implement:
- RCA for sound on P 10 and 11
- Power via USB
- propclip/propplug connector
have fun
Franz
I would suggest to wire the dip switch S3 to disconnect the resistors instead the JP3, otherwise it makes no sense.
Please use a larger EEPROM so that we have some storage for the application.
For the sound you could also use a headphone jack that would save some space. With an adapter you could use an RCA cable to connect an audio device.
Thomas
Oh, thanks. I made a mistake
Franz
I would like to have a 3.5 mm headphone jack for the sound instead the jumper plug.
Also I would suggest to disconnect the output of the 5 V regulator per JP4 if you use the USB for supply.
Thomas
that unused card inputs should be pulled up to VCC. Presumably this is to avoid excessive
power consumptions or oscillations on the input buffers of the SD cards.
In practice leaving them not pulled up doesn't seem to harm things, but perhaps that's only
true for the small number of cards I've actually experimented with. You leave the pullups
off at your own risk. If you plan to make a bunch of these boards, and only 1% of your users
have issues because of the lack of these pullups, you've just spent more on customer support
than you'll probably gain in profit.
you have to reload the page, then you can see that i allready included the other pullups.
I have made an SD-Add-On Print for my webcat board without any pullups
and i works perfect. But you are right, you never know what happens
What else do we need at this board ???????????????????
have fun
Franz
thanks for the headphone jack, very nice.
Did you have understand my suggestion for the USB supply? I think it could be a problem if someone would supply the board from two various sources. Therefore I would suggest to use a 3 pin version for JP4 so you can switch to supply via USB and simultaneous disconnect from the external supply.
Thomas
Franz
Post Edited (Franz Achatz) : 7/7/2007 3:29:58 PM GMT
>Did you have understand my suggestion for the USB supply? I think it could be a problem if someone would supply the board from two various sources. Therefore I would suggest to use a 3 pin version for JP4 so you can switch to supply via USB and simultaneous >disconnect from the external supply.
Yes, i got your message
I will change it tomorrow and then you guys can have the final look
before i place the pcb order.
have fun
Franz
Congratulations, your board is brilliant, put me down for one when you have the pcb's
Can't believe you have Ethernet on there too!
Coley
