SOUT,SIN,ATN And VSS Pins
Twisted Pair
Do·the 1,2,3 and 4 pins need any thing connected to them if·a pre-programmed·Basic Stamp module is installed on a prototype board ?
Thanks, Twisted Pair....·
Twisted Pair....
Thank you Chris
Twisted Pair....
You said you checked the A/B outputs of the encoder…But what about the Common (C) line? If your encoder outputs are pulled-high (active low) then the common line should be going to ground. Is this the case? I still believe the issue is in the encoder circuit. As for the power supply, the 7805 is a perfectly suitable regulator. Of course, if your supply is noisy you could be having issues. You should have the proper capacitors on the input and output of the regulator. The 7805 doesn’t have a specific requirement so you would adjust those for your supply and load conditions. Again, I would revisit the encoder…Are you sure you’re connected to the correct pins on the encoder? Do you have a picture of it?
Thank you Chris
Twisted Pair....
Am I correct in saying that there is only one power supply for all of this?
Am I also correct in saying that all grounds come back to the same (approximate) place and are tied together to the power supply ground (- terminal)?
Bruce Bates
Yes, you are correct, all grounds are close to each other and are all tied to the BOE's on-board regulator ground pin....
It should be noted that the Vin on the module is used instead of Vdd Pin....
Thanks Bruce....
Thank you Chris....
Thanks for your help
Twisted Pair....
Post Edited (Twisted Pair) : 6/17/2007 8:38:42 PM GMT
http://www.parallax.com/dl/docs/prod/boards/ParallaxPDB.PDF
Thank you Chris....
Post Edited (Twisted Pair) : 6/18/2007 7:18:18 PM GMT
Post Edited (Twisted Pair) : 6/18/2007 4:55:48 PM GMT
Twisted Pair....
