Driving a solenoid using BS2SX
I am planning to use the circuit diagram from "Application cookbook" byMatt Gilliland - The diagram and the code is attached to this.
What I need to achieve is to make the solenoid open and close about 30 times a second(30Htz).I would like to know if I use the code as it is and changed the pause limit will I will be able to do it or is there ia better way to achive this.The solenoid I have is capable of cycling at 30Htz.
The 30 Htz are maintained for about 1 sec. and paused for about 1 sec.This cycle is repeated.
The trigger for this cycle is fed from a air flow detrector - OMRON D6F - (The specifications are also attached).Ideally I wouls like to
get the out put of the Air Flow sensor and feed to th BS2 which intern would trigger the solenoid.
Can I do all these using BSX OEM board.
I wouls appreciate any help to achieve this goal.
Thank you.
Siri
Thank you.
Siri
- Stephen
Thank you - I will first tackle the solenoid and then figure out the air flow sensor section and post back with the results.
Thanks again
Siri
