Does anyone see a problem with Interfacing a Propeller to 5V devices through PC
I have been studying the datasheet for the PCF8574 and see no reason why I can't feed it's VDD·with +5V,·have it's I/O·pins connect·to other +5V devices,·yet directly connect the SDA and SCA to my Propeller with pullups to +3.3V. The PCF8574's·SDA line, when it is an output, only syncs current to 0V (nothing drives to +5V). I have attached a drawing for you to see what I am talking about.
NerdMaster
For
Life
5V tolerant means that no special steps need to be taken to interface.
When you are interfacing via an open collector output situation (such as I2C where you are using pullup resistors on SDA and SCL) connect the pull-ups to 3.3V and you should be able to interface the two.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 2/28/2007 11:50:07 PM GMT
NerdMaster
For
Life
Paul Baker
