sx48 rambank0 addressing
Peter Verkaik
Having used only sx18 and sx28 I now try to use rambank0 in the sx48.
If I understand the addressing correctly, I must define
;bank0
org $0
bank0 = $· ;so I can use bank bank0
org $10
temp1 ds 1
temp2 ds 1
etc.
;bank1
org $10
bank1 = $
temp3 ds 1
temp4 ds 1
etc.
So bank0 variables have identical addresses as bank1 variables
then use
bank bank0
mov temp1,w· ;semi direct addressing
What registers are addressed when using IND as in
mov w,indf
if fsr holds $00 to $0F
Are the global registers addressed or rambank0?
I assume the global registers are accessed, so rambank0 is not accessible using indirect addressing.
Please correct me if any of the above is not correct.
regards peter
;bank0
org $0
org $10
temp1 ds 1
temp2 ds 1
etc.
;bank1
org $10
bank1 = $
temp3 ds 1
temp4 ds 1
etc.
then use
bank bank0
mov w,indf
regards peter
I think you are correct in your assumptions.
Your right, rambank 0 cannot be accessed using FSR/IND. It can ONLY be accessed by setting FSR to $00 and using semi direct addressing. As in "MOV xx,W" where xx is between $10 and $1F inclusive.
This is why SX/B uses rambank 1 (FSR=$10) as the default on the SX48.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
I made a source for SX48, containing byte read/write and bit read/write routines
for both the general purpose ram and the special configuration registers.
I treat rambank0 registers as special configuration registers.
See the attached pdf for assigned config addresses.
The dynamic access to rambank0 requires a lot of code space (compared to the others)
so I think it is best to reserve rambank0 for a VP that runs in the isr. Then the
readRambank0 and writeRambank0 routines can be left out.
Edit: I added a source without the rambank0 access.
This has much smaller code size and only requires 1 global temporary register.
regards peter
Post Edited (Peter Verkaik) : 9/28/2006 9:43:30 AM GMT
