Parallax Thermocouple Kit with SX28 Tech Board
Bean
Here is some code to use the Parallax Thermcouple Kit (#28022) with the SX28 tech board.
It uses the Parallax serial LCD to display the thermocouple temperature.
Parallax, feel free to include this as a download for the Thermocouple kit. (You'll probably want just the SXB code though).
[noparse][[/noparse]edit] Aug 18, 2006 12:45PM; I added some comments to the spreadsheet and SXB file to explain how I calculated the·thermocouple temperature with such a small data table.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Post Edited (Bean (Hitt Consulting)) : 8/18/2006 4:51:11 PM GMT
Bean.
zip
139K
csavage@parallax.com
I just uploaded a new version. The SXB is the same (just a couple comments added). The speadsheet now has comments explaining how I calculate the thermocouple temperature with very little data tables. I'm sure the same technique could be used on the stamps too.
Bean.
·· I have the updated copy.· Thanks.
