Raiseing a Voltage
Hello All,
I'm biulding a BS2 powered robot, as part of the motor controllers, I need a way the raise a voltage from 8.4 V, to 12 or 15 V.· Is this possible, or do I need· a seperate battery.· If it is possible, please explane.· Thanks!
NerdMaster
For
Life
NerdMaster
For
Life
You can find DC-DC Converter modules that can provide large output currents but they will cost more in $$$ and require higher-capacity batteries in your low-voltage power source since the converters will draw more current. A DC-DC Converter with a 10W capacity runs about $30-$40 in single item quantity.
In your application weight will be a factor so you have to decide if having two batteries (one for logic and one for motors) is more efficient than having one larger, higher-capacity battery and a DC-DC Converter to power your motors.
I wouldn't connect that if I were you...
Vive Le Tour!
July 1 - July 23
Post Edited (aalegado) : 7/18/2006 6:30:24 PM GMT
NerdMaster
For
Life
Jameco #216830CK. 1W capacity. Output of 12V@84mA from an input of 4.5-5.5V (around 200mA). $11.
Vive Le Tour!
July 1 - July 23
Cheers
NerdMaster
For
Life
