Flight computer
I have finally finished my rocket project. The attachments explain most everything.
If anybody has any suggestions or comments let me know.
Thanks to alll the people on this forum that have helped
· What battery do you use ?
· Have you flown it yet ?
· I'd love to see a data file if you have.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject my reality, and substitute yours." NOT Mythbusters
I was going to fly it fot the first time this weekend but the motors I ordered ended up being the wrong size. What a downer. I am re ording the motors so hopfully next weekend. As soon as I get some data I will post it.
I am already working on a second version that will also have GPS, gyro and SD card reader/writter.
If anybody has a better idea on light weight battery let me know. As the N-cell needing to be replaced in about half the time of a 9V and at $6.00 a battery starts adding up.
Why don't you explore the possibility of using a lithium-ion rechargable???
The power-to-weight ratio is better than most other types, and it has no memory effects.
You just have to make sure you use the correct charger....
Bob
It can even do a 6C discharge... (600mA for about 10 minutes)
Don't visit my new website...
Timothy D. Swieter
tdswieter.com
One little spark is all it takes for an idea to explode
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
Seems to me that two 3.0V Lithium cells [noparse][[/noparse]like the computer backup batteries] could be used with a diode to drop the voltage to 5.3volts. Then just skip the BasicStamps regulator. You really don't need the voltage regulator for battery operation anyway.
These are cheaper and lighter, but they are not rechargible. At least you aren't dumping a lot of energy [noparse][[/noparse]the N cells are 12volt, right?] through the regulator.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
I noticed that the flight computer document shows an Aerotech Strong Arm rocket. This rocket weights 18 ounces without a rocket motor, and probably closer to 24 ounces with a motor. I would suggest using a Lithium 9-volt battery. The Energizer L522 weights 42.4 grams, which is 1.2 ounces. This is only 5% of the total weight of the rocket.
I fly a rocket with a digital camera and controller powered by a 9-volt battery. This rocket is similar in size to the Strong Arm rocket and I have flown it many times with the camera payload. I would suggest adding a battery meter to your flight computer which would measure the voltage of the battery. This way you would know if it is time to change the battery.
Dave
Paul Baker
A 9-volt battery is a good match for a 7805 type regulator. A 7805 requires a minimum of 7.5 vollts on its input. Under "nominal" loading a 9-volt battery will produce a range of 8 to 9 volts during most of its life. The extra 3 volts from a 12-volt battery results in wasted energy.
I understand the desire for a low-weight battery. I have a PerfectFlite altimeter that uses the small 12-volt battery, and I can get several flights out of one battery. However, I don't see any problems in using a 9-volt battery in a rocket the size of the Strong Arm rocket. Also, since a 9-volt battery uses a clip instead of a spring-load holder it will be less prone to losing contact during high accelerations.
Enough about batteries. Have you had a chance to fly your flight computer? I'm interested in the results you got. I started working on a similar flight computer based on the SX. However, I gave up on it after the wiring started looking like a rats nest. If I try it again I will have a PC board made, or I'll use the SX48 proto board. There are several features I would like to see in a flight computer:
- Orientation with the earth's magnetic field
- Sun orientation
- Acceleration along the rocket's cental axis
- GPS
- Data logging
- Telemetry transmission
- Remote radio control for arming and other functions
- Barometric altimeter
- Spin detection
- Video camera control
- Still camera control
- Motor gimbal control
- Anti-spin control
- Vertical flight control
Up to this point I've only done still camera control. I hope to add a video camera and implement a remote radio control in the near future.
Dave
HP 41's used them, they're 1.5V
You're thinking a 23A - it's a 12V cell....
Yeah, I agree - after doing some research a while back, I found that the cheap 9V's (albertsons, CVS) have
more storage capacity (maH) than the Cu - tops!
John
Try LiPo mobile (cell) phone battery packs.... They have a stupidly high mAh capacity, are small, are lightweight and compact
There are variants that are about 4.8V (a reasonable [noparse][[/noparse]low end Vcc] match for 5V logic etc!!), and some that are around 3.6V (a reasonable [noparse][[/noparse]top end Vcc] match for a prop. chip???)
... and to top it alll... are easily available. Try your local phone repair stall, at your local open air market .. ·or backstreet 'phone repair shop... They sell ones that are compatable with 'phone handsets... but not a manufactures original part ...·for peanuts!!!
One word of warning though... make sure you 'balance' the cells properly during discharge.. and especially during charge... They can catch fire or explode!!!
(I know aero-modellers who use LiPo's... and swear by them... but have told me a horror story or two!!!)
Regards M.R.B.
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
Yes I have flown mine several times now.
Is 200 feet difference really that much of a difference?
Depends, If your just data logging no.· If you are using it to deploy a recovery system at a higher altitude not really.· If you are deploying a recovery device at a lower altitude it might.
If you are using the "flight computer" to control recovery one thing you can do is add an accelrometer. The baro and accel help keep each other in check. The baro is supseptable to false data occuring when the rocket transistions to sonic flight.
If you have both an accelrometer and baro you can do other things to like air starting other motors.
The 'N' cell is NOT a 12V battery! - I've been using 4 N cells in my HP41CV calculator for over 25 years!
4 N's = 6 volts....roughly, I put in a metal 'extender' and recharge them in a AA slot in my charger...
You're thinking the 123 cell.....
www.geocities.com/achilles03/flight_1-6-08.xls
Dave
Shawn Lowe
Maybe I should have waited to do that......
