gp2d12 , Im having problems hooking this sensor up. could somebody give me a good description on how to hook up pin 5 and 3 to the potentiometer?· how are all three connected?
My GP2D12 data sheet nly shows 3 connections, as listed below:
Pin 1 Vo = Analog voltage output
Pin 2 GND = Ground
Pin 3 Vcc = Power+
The only pot (if one exists at all on the device) is used for adjusting the distance range. I forget which Sharp units have adjustment pots and which do not - sorry. FWIW, I have attached my Sharp GP2D12 data sheet for your convenience.
can i just plug that into the bs2 than? I thought I needed the analog to DC converter. thats were I was getting the pot from was wiring up that analog to dc converter. If i dont need it than great...do i need it?
Sorry, you didn't mention an ADC in your original post. Here is a Nuts and Volts Column (atttached) written by Jon Williams which lays it all out for you.
my question is about the last attachment, the schematic of the ADC shows the pot going from +5 to ground and than pin 5 and 3 are attached to it. Im confused how the 5 and 3 are attached to it. im a dummy at schematics and a dummy on wiring things so if you could explain in words how that is hooked up that would be great.
You need to start from a central point, and work outwards, or at least thet's how I do it. The central point here in this discussion is the potentiometer (variable resistance), which you seemed to be able to identify from a prior post.
A potentiometer has three connection points. One connection point it the wiper (W), shown as the connection with the ARROW in the schematic. The other two connection points are the ends of the fixed resistor (F+, F-) and are the other two points on the symbol which has a 2.55 V indication next to it in the diagram.
View the potentiometer as though it was the letter "T". The top left and top right sides are the F+ and F- terminals respectively, and the base of of the "T" is the wiper (W) contact. Now we attach the left side of the "T" (F+) to the +5 VDC supply. The right side of the "T" (F-) goes to the GROUND terminal. The wiper (W) is connected to Pin 5 (Vref) of the ADC. Lastly, we also connect Pin 3 (Vin -) to the right side (F-) of the potentiometer. Now there are two wires on the right (F-) side of the potentiometer, and you're done.
Pin 2 GND = Ground
Pin 3 Vcc = Power+
Bruce Bates
<!--StartFragment -->
Bruce Bates
I hope that's what you were looking for.
Bruce Bates
