Propeller Guts Download
Hello friends,
A·new Propeller document·is now available for download below.·This document covers the assembly language and general architecture.
I'd like to point out that all officially released Propeller downloads will be available at http://www.parallax.com/propeller/·- discussion forums will quickly contain dated releases from Parallax. However, I'm·posting·this one·here since our web team won't be able to·post these on the web site·until Friday. ·In the meantime,·you'll have more·material·to review!
Sincerely,
Post Edited (Ken Gracey (Parallax)) : 2/24/2006 6:32:02 AM GMT
Sincerely,
pdf
102K
Truth can be dangerous... Trust can be deadly.
Gee you must be burning the midnight oil...
1.00 PM here.
Cheers,
Chris - West Oz.
Probably won't get much work done in the office today...
(Lucky that the boss is away on vacation...
Don't visit my new website...
Why 'check-out' a lock?
Why not just use them directly, as I assume that when writing a Multi-COG system, we'd know what each of the locks would be used for?
(And how many we're using... )
The PLL...
In the info about the CLK Register it is mentioned that this ALWAYS runs at 16X, and that its internal frequency must be kept within 64 - 128MHz...
(4 - 8MHz Xtal)
Then you select the Master Clock as an multiplication of the Xin signal with the CLKSEL0 - 2 bits. with a max multiplier of 16...
What would happen if someone actually used an 8MHz Xin signal and the 16X multiplier?
Flaky behaviour, blue smoke, men in Black Armani suits and flashy gadgets coming around, or?
Disclaimer: I have no knowledge of the Propellor System other than what's been provided here on this Forum.
With that in mind, I'll take a crack at one of your questions based on the latest documentation provided by Ken, and the Propeller Layout diagrams.
You asked: Why 'check-out' a lock?
"Locks" apply to semaphores, and semaphores are contained in the HUB, thus, by their very definition, they are global in nature. You may well want to check on the status of another process (COG) to make determinations as to what path of logic you should follow within your own COG, based on the status of another COG. This speaks mainly to ordered or sequenced operation I would think.
The PLL question is too deep for me at the moment, so I'll leave that for one of those folks who are better informed.
Bruce Bates
<!--StartFragment -->
Martin Hebel
Disclaimer: ANY Propeller statements made by me are subject to my inaccurate understanding of my limited time with it!
Southern Illinois University Carbondale -Electronic Systems Technologies
Personal Links with plenty of BASIC Stamp info
and SelmaWare Solutions - StampPlot - Graphical Data Acquisition and Control
·1+1=10
Post Edited (Paul Baker) : 2/24/2006 1:17:33 PM GMT
Unless we also have a common way to transfer that information, we will have to update the common objects anyway, to be able to receive it according to your own way of doing that.
As for the PLL, it is obviously capable of producing frequencies up to 128MHz (as stated in the PDF), so what is the most likely problem if we try to run the Propeller at that speed?
(Someone is bound to try... )
Does anyone know the timing of the multiply, divide and square root routines in the datasheet?
www.speechchips.com
Speech & Video IC's for BasicStamps
...Geezzzz, and I never thought I'de never go back to the days of WANTING to write in asm again... [noparse]:)[/noparse]
Thanks Ken!
Just tossing my two bits worth into the bit bucket
KK
·1+1=10
I suppose that we are then limited to the MasterCog allocating the necessary inter-COG semaphores, and informing the other COGs of which semaphore is allocated for a specific purpose.·
Since the HUB can update bytes/words/longwords atomically, the semphore is needed (for sequencing data update/access, anyway) only when the data structure exceeds a longword.· Mutex (mutual-exclusion) semaphores for other purposes may be a different story.
Daniel
Bingo!
In fact, I don't see much use for semaphores internally in objects at all.
But...
What I would REALLY have liked is Free/Read/Exclusive type Semaphores.
Read: A non-exclusive access to read a resource. Any COG can grab this resource as long as it is either Free, or only Read by other COGs.
Exclusive: A COG can only receive this level if NO COG already has Read or Exclusive access to the resource.
The logics would have to be a bit more complex, though, as it would have to keep track of more than one COG's ownership of the Semaphore at once. (In theory, all eight COGs would be allowed to request a Read lock on the same resource at the same time)
This is similar to what multi-user databases uses...
Of course, that is a bit more difficult to use, and it is easier to get blocks, so...
Now, to sit down and study the ASM listing...
(I have a couple of short programs I like to implement to learn a new processor... And as a rule I only do them on paper... And try to calculate the number of cycles it would use, too... Real masochistic... Real GEEK!)
Edit:
BTW: I can foresee bother incredible advantages and problems in having an Assembly-language where setting and acting on flags is entirely up to what options you specify for each line... Cool...
Post Edited (Gadgetman) : 2/24/2006 5:11:08 PM GMT
Inaki, I think you misunderstood, the semaphore itself is not within an object, rather a pointer to the semaphore used is stored within the object.
·1+1=10
Now lets say your higher level object is a USB master you wrote, which has its own buffers (and sends the data received to the serial port run by the serial object). You have two cogs running for the process, one to handle the USB communication, and another to handle the data streams. You use two semaphores, one on the output and one on the input buffer. In the USBMaster object you declare two variables, USBSendBuffMutex and USBRecvBuffMutex, you check out two semaphores and store thier location in the two registers.
Now you have 3 semaphores, each with thier own pointer declaring which of the 8 semaphores it is stored in, they are all unique, and provide access to higher level objects by modifying the semaphore in a procedure located within the object which checked out the semaphore:
PUB GetUSBInputBuffer:OK
·· OK := !LockSet(USBRecvBuffMutex)
This simple procedure provides a higher level object to the USB input buffer through the semaphore, if OK == FALSE then the higher level object does not have mutual exclusive access to the buffer, if OK == TRUE the the higher level object now has mutual exclusive access to the buffer.
Does this example help you understand how to encapsulate arbitrarily checked out semaphore and provide access across objects?
·1+1=10
Post Edited (Paul Baker) : 2/24/2006 5:49:57 PM GMT
Don't get so freaked out about LOCKs. I've written lots of objects which instantiate extra COGs that talk with Spin-level variable constructs and I haven't ever had to resort to using a LOCK in a single case, yet.
The reason is this: almost all 'contracts' for shared data call for one party to write certain memory locations that the other party reads, and vice-versa. In a buffered serial object for example, the COG that performs the actual I/O (in assembly language) has to transmit bytes that are deposited by Spin-level routines. The Spin code drops bytes into a circular buffer and increments the 'head' pointer. Meanwhile, the COG running the assembly code checks to see when the 'tail' is different from the head. When it is, it picks up the byte pointed to by the 'tail' and then increments the 'tail'. By the way, before the Spin code can drop a byte into the circular buffer, it must make sure that the 'head' is not going to bump into the 'tail' (because the transmit buffer is full). So, both processes read both the 'head' and the 'tail', but each variable is written by only one process. This is how most things are made to work, and it's quite simple. If it seems NOT simple, you just have to try it - you'll see. It's totally fun to play with.
A LOCK might be the most convenient way to share a buffer resource, say, which spans multiple bytes/words/longs. If you notice in the example cited above, only atomic read/write operations were occuring on a singular byte/word/long variables in main memory. When you must share many bytes/words/longs, a LOCK can come in handy.
- Chip
Chip Gracey
·1+1=10
Post Edited (Paul Baker) : 2/24/2006 9:43:28 PM GMT
in this case the spin code enqueues to the buffer & sets the head as long as the head and tail dont point to the same location.
the cog performing the i/o dequeues the buffer & sets the tail as long as the head and tail dont point to the same location.
locks arent required because setting the head and tail are mutually exclusive between the two operations.
right?
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
Now say for instance you want a bidirectional queue (push or pop from either end) accessed by multiple cogs. This is an instance where semaphores are needed, but this is a pretty esoteric data structure that you likely won't need to implement.
·1+1=10
Post Edited (Paul Baker) : 2/24/2006 10:28:15 PM GMT
·1+1=10
Can't be...
Staring directly at gods tends to instill blindness in the beholder...
Though...
I did have to take off my glasses a minute ago and rub my eyes a bit after reading his post...
-Martin
Martin Hebel
·· No he's a stunt double we hired to feed propaganda to the mobs!· Of course it's THE Chip Gracey!· LOL
csavage@parallax.com
There really are two Gracey's?
I was beginning to believe that it was the old, 'That wasn't me, that was my twin brother' line.
I knew that Ken is Chip's brother, but after a while, one really begins to wonder if Ken just has mutiple personalities or an alias or whatever.
Setting aside all the kidding, I did read the 15 pages of documentation and it really gives a better impression of what this can do. The EEPROM data pretty much declares the intentions of this to be a substantial number cruncher with video output. Having LOGS, ANTI-LOGS, and SINE tables with video/printer character output will allow it to provide a degree of precise control with Real time output.
I am not sure what I need it for, but I bet you could fly a rock with it if you could just find the right thing to push it and the right things to change direction. [noparse][[/noparse]I cannot afford those kind of toys.]
Now I am wondering about the '6 degrees of freedom' and what this would be like if you had three gyros and three accelerometers attached. You could put this inside a rough and tumble robot as its 'inner ear'. You would have 6 Cogs for sensors and 2 left over for converting data to navigation and response.
Post Edited (Kramer) : 2/25/2006 4:30:41 PM GMT
Tracy Allen
www.emesystems.com
