Need SERIN parsing help
I am a fairly new BSII programmer and am trying to get a simple program to interface with a LabVIEW program I have written. The LabVIEW prog outputs a string to the com port without a problem (I can·get the correct string from the·BSII Debug window).
I have two 3-digit numbers I want to put into variables in the BSII. The string being sent is "P123T456" where 123 is the data I want in variable "Pan" and 456 into "Tilt"
The command I use to parse is:
Pan VAR Word
Tilt VAR Word
SERIN 0,84,[noparse][[/noparse]WAIT("P"), DEC3 Pan, DEC3 Tilt]
My variable Tilt is always the same as Pan.
I get the same results with the following:
SERIN 0,84,[noparse][[/noparse]WAIT("P"), DEC3 Pan, WAIT("T"), DEC3 Tilt]
What could I be doing wrong? Or is this not a good way to exchange data between the BSII and computer.
Your input is greatly appreciated,
Marc
Pan VAR Word
Tilt VAR Word
Marc
Jon Williams
What else could be causing my two variable to be the same. I have tried renaming them. Is there a better way to parse the data?
Thank-you for your help.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 1/28/2006 2:00:31 AM GMT
It is strange to note that both methods will capture the same string correctly, but only the second parses it correctly. Perhaps since the BS2 does not have a serial buffer, it misses a character when parsing? I will have to look into it further, but for now things are working.
Jon Williams
