BS2 OEM "LITE" Schematics
Hello,
·· After several requests from several forum members for schematics of the minimum requirements for a functional OEM BS2 I have compiled the following three schematics which should allow users to integrate a BS2 onto their project without having to have all of the support circuitry.· Essentially these are modified versions of the BS2 OEM schematic which can be found at the following location:
http://www.parallax.com/detail.asp?product_id=27291
NEW LINK
The following files are included inside the ZIP file:
·· Number·2 is the minimum components required for a functioning OEM BS2 that still includes brownout detection.· If you don't need brownout detection number 3 is the same schematic minus the brownout detector (13811).· Bear in mind that the 13811 is totally optional.· You can even allocate a spot for it in your final product and the BS2 will function whether the 13811 is there or not.· All it really does is attach to Vss, Vdd and the RESET line.· When the voltage falls below around 4.7 volts it pulls the RESET line low.· So you can get by without it, although you may have strange results during power sagging/brownout conditions, including loss of program control.
·· Remember, there is no facility to reprogram the BASIC Stamp in these circuits.· You have three options.· One is to use one of the many RS-232 programming adapters I have seen which would include all the circuitry missing from the original schematic.· Your second option is to reprogram the EEPROM in a standard OEM BS2 and swap the EEPROM out.· I have done this myself.
·· Now for those of you who want to be able to simplifiy the design and still have the ability to program the BS2 in circuit AND make use of the USB port, you use the first schematic, which essentially uses our USB2SER development tool to program the BS2 in-circuit.· This way you do not have anything but a 4-pin header and the bare minimum circuitry required.· When you need to reprogram it will work much like programming an SX in-circuit, through a 4-pin header.· Remember, the 13811 could also be removed if you absolutely had to.
·· I hope some of our forum users are able to make use of these schematics, but now for the fine print...These schematics are not supported by Parallax but are merely provided as a guideline for developing your own stand alone integrated BASIC Stamp applications.· Please do not contact Tech Support for assistance with these.· I am posting them as educational material only!·
· Enjoy!
Parallax Engineering
Post Edited (Chris Savage (Parallax)) : 1/8/2009 7:10:37 PM GMT
NEW LINK
zip
88K
In terms of programming the OEM Stamp-Lite, Chris·indicated that·"You can use one of the many RS-232 programming adapters I have seen which would include all the circuitry missing from the original schematic."· I really don't want to be a pain, but I am having an awful time finding a simple schematic of what one of these RS-232 programming adapters would look like.· I have seen·several of them, but they all seem to work a bit differently.
HVW Technologies RS-232 Driver Module
http://www.hvwtech.com/products_view.asp?CatID=163&SubCatID=197&SubSubCatID=198&ProductID=289
Kronos Robotics Easy RS232 Interface Kit
http://www.kronosrobotics.com/xcart/customer/product.php?productid=16167&cat=291&page=1
Acroname Serial Interface Connector
http://www.acroname.com/robotics/parts/S13-SERIAL-INT-CONN.html
Pololu Deluxe Serial Adapter Kit
http://www.pololu.com/products/pololu/0126/
AWC RS-I Serial Interface Adapter
http://www.awce.com/rs1.htm
How would I know if any of these would work?· Would they work as a "direct connect" our would I still need the 4.7k resistor between Rx and TX?· Would I still need the 1N914 diode on the RX line?· Are these components only needed because of the USM2SER?
·Does anyone have a complete schematic (most likely based on a MAX232 or MAX233E) of how to build one that would be able to program the OEM Stamp-Lite?
Post Edited (Steve Joblin) : 1/26/2006 4:01:02 PM GMT
Ryan
Ryan Clarke
RClarke@Parallax.com
For example, lets say I used Al Williams' AWC RS-I Serial Interface Adapter
There is no schematic for it, but just from the picture it looks like a MAX232 with four caps.· Are you saying that I could hook it up with jumpers without any other components (like the 4.7k resistor between Rx and TX or the 1N914 diode on the RX line?
Post Edited (Steve Joblin) : 1/26/2006 4:46:30 PM GMT
·· What might be better to do is compare the original schematic to the two LITE schematics.· Don't focus on the USB version, those changes are for the USB2SER only at this point.· Any RS-232 circuit you connect to either LITE circuit should be the equivalent of the parts removed from the original circuit.
·· One thing to bear in mind is that the SOUT line is driven HIGH, not floating and pulled HIGH as the SIN line is.· What this means is that your circuit should expect that SOUT is driven.· I hope this helps.
csavage@parallax.com
so how would I find an example schematic of an RS232 circuit that would be the equivaqlent of the parts removed from the original circuit? Do you have one?
·· Yes, I do have one...The original schematic for a BS2 OEM is linked above.· That schematic shows all the "extra" parts I removed from the schematic to create a LITE version.· You could effectively make a programming dongle for RS-232 using that part of the schematic.· You would just include those parts and then you could plug it in to the LITE schematic (into the SIN and SOUT pins).
cheers ... brian riley, n1bq, underhill center, vermont
Tnx .... lot of good info here
·· This should be 4.7 volts, although I haven't looked at the 13811 in some time.
I finally tracked it down to the Parallax document "OEM BS2 BOM.pdf" the MN13811 is a 4.1 volt threshold.
Thanks for the help. My USB2SER arrived today, off to the workshop tomorrow nad see what I can do.
·· I know the question has come up before about how to connect directly to the interpreter through the serial port using a MAX232 (or similar) Line Driver and there were no previously published articles that I was aware of.· As of today one of our customers has used the schematics in this thread as a guide to perfect this and connect directly to the BS2p40 interpreter chip (SX48).· The following schematic he came up with and wanted to share it with anyone else trying to connect in this manner.· From the customer:
Chris,
I came up with this design, modified my board and it is successful.· If you want to add this to your zip files I am forwarding this along.· I have been testing code and using the PBasic Stamp Debugger·without any issues.··I appreciated your help and therefore am sending this to help others.·
George Calvas (Ford Motor Co.)
·· Bear in mind that the BASIC Stamp requires echo on the RX/TX lines for the Editor to recognize the BASIC Stamp.· In this manner the diode is required due to assertion of the other line across the 4.7K resistor.· George has successfully married this theory on the RS-232 side of the MAX232.· He hopes this helps someone else.· Take care everyone!
Can you just confirm the inputs and outputs... on the left side of the schematic...
MAX232A Pin·8 goes to Interpeter Serial Port XX
MAX232A Pin 9 goes to Interpeter Chip·Pin XX
MAX232A Pin 11 goes to Interpeter Chip·Pin XX
on the right side of the schematic...
PB_PC_TX goes to Serial Port Pin XX
PB_PC_RX goes to Serial Port Pin XX
The diode goes to ?
Post Edited (Steve Joblin) : 1/26/2007 3:37:35 PM GMT
MAX232A Pin 8 goes to Interpeter Serial Port XX
MAX232A Pin 9 goes to Interpeter Chip Pin XX
MAX232A Pin 11 goes to Interpeter Chip Pin XX
and what's up with that diode? it's just hanging out there! The diode goes to ?
I’m sorry; the lines are labeled so I thought you knew where they went from there. That will vary between different interpreter chips as to the exact pin number, but the functional pins are listed same as on the PC side. As for the extra diode, it appears he used some sort of dual-diode package because it was available and is using only one diode from it. You only need the one diode. If I ever have an opportunity to build something using this schematic and known parts and draft a version similar to those posted. For now this, like the others, is as-is information. Take care.
the schemetic you posted contains the PIC16C57, can i swap that chip with the F version and make a BS2 at home?
as the cheapass i am i have all the parts i need at hand (yes from old electronics), and i only have a PIC16F57.
and i really (i mean really) dont want to buy a C version if i can just use the F.
hope this makes more sense
That said, even if you wanted to break the law, you couldn't because you can't extract it... it is burned into the chip.
The Interpeter is what makes the Stamp a Stamp... think of it as the "secret sauce". It would be like Coke publishing their formula on the internet.
You can program a PIC yourself using some very inexpensive programmers and free IDE's off the internet... however, none of them enable you to program in BASIC (at least not the free ones).
Let's take an example... The BASIC STAMP II costs $44... compared to a PIC chip that costs just a few bucks... but you will need a programmer (Let's say you can make one yourself for about $30) and PICBASIC Pro costs $250.
If you are planning on making products in large quantities, the BASIC Stamp is not cost effective, but for educational, hobby, and small quantity manufacturing, you can't beat it!!
- Stephen
It is not possible to extract the firmware from the chip…You must purchase the chip with the firmware already programmed into it. Take care.
I would like to thank you for your help on setting up this schematic.· It was assembled today, and it worked great with the USB2SER adapter.·
