Music with Synced Lights...
Ok.· I'm lost.
I've read darn near everything I can find for syncing lights and controlling lights that I can find, and I still can't get pointed in the right direction.· SWMBO has asked little old me to build a light display for our big 4th of July party this year.· Ok, cool, I can handle this.· I've got a handle on where to get the SSR's that I'll need, as well as a prototype for the circuit board to house them.· I've also got a good handle on the method of making the lights stay on,· 2 STP16C156 16 Led I2C controllers will provide all the circuits I need.· I also got an idea or two, or three, on the code.· Ok, this is all fine and dandy.· Now, add the music.· Brings me full circle to: I'm lost.·
The project is like this one, only I need 32 ports of control (still no problem, just different hardware) and synced to music.
http://forums.parallax.com/showthread.php?p=563415
I looked at this product, but it's like an all in one, with many less outputs then I need:
http://www.animatedlighting.com/products/mp3components.asp
So, I guess what I'm asking is... where do I go from here?
And, just for the record, when I said "Ok.· I'm lost," I said about all I know about analog electronics.
Until our bytes cross again, may your chips never smoke, your bits never fall off, your parts bin never be empty and your jumpers never fall off.
KK
KK
·1+1=10
If these signals go out at a given rate, you could interface an SX to it (or other TTL IC to count the pulse...maybe) and then just walk through the song and have things go off at a given number of time blips.
The only other thing you could do is, record your song with some high frequency DTMF type codes at your "action points" and have something filter them and command your lights to do something.
Are you looking to do this all with a STAMP? I'd aim for an SX at the least and if you have your PC supplying the tunes, you might look to the PC to be the scripter and send a coded string to the stamp that would tell it what lights to turn on or what squibs to ignite to light off the fireworks.
Steve
Jon Williams
I was thinking along the lines of using a MP3 song.
THe orignial idea was this...
Encode a MP3 song with ID3 Tags at the correct points in time where I need to change things...
As the song is played, the player will output a pulse when it incounters that TAG...
The BS2P would be counting pulses. Every time it gets this "pulse", it would increment it's counter.
That counter would be an index into a table of the status of all the lights at that point in the song.
sort of like an array of 16 controll bits and 8 address bits , where a 1 would be on, a 0 would be off. The layout of the array in memory is like this:
00000000 0000000000000001 (Time Index 0) Light 1 on
00000001 0000000000000011 (Time Index 1) Lights 1 & 2 on
00000010 0000000000000010 (Time Index 2) Light 2 on
00000011 0000000000000110 (Time Index 3) Lights 2 & 3 on
Then just use the I2C protcoll and sent the new state of all the lights to the STP16C596.
I would use 8 bits for the addressing... the LSN for which stp16c596 to send the data to, and mybe the MSN for banking...
Meaning in theory it could be expanded to 16*16*16 ports (4096) in this mannor...
Or I could chain additional stp16c596's to add additional 16 ports on each address....
I know (from a question in the sandbox) that the I2C speed is 81K per second... so I'would have to choose an addressing system that
keeps the chip count down, and access so I could access any of the ports within nominal amount of time.
The idea is to make it open ended (to add more ports) (The stp16c596 can be chained.... so a single address can contain 16,32,64 ect ports)
In thinking, maybe i'd be better off using a PC and it's resources to generate and run the script, and have the stamp recieve commands, like the array idea..
I'm not byond using the PC to control the idea, but it means a connection to get the address/data to the stamp has got to be fast.
Hmmm...
Time for me to dig deeper into my programming expierence and see the fastest (and easiest) way to communicate to the stamp..
THanks all... and keep the ideas runnin!
KK
I see two ways of accomplishing what you seek, both would take a considerable amount of effort and which to use depends on what level of control you have over the mp3 player. If you have the ability to initiate the playing of the music from the stamp, you could create a table seperate from the music file with the timing and commands where the stamp would initiate the playing of the music, then count along iterating through the table and sending the commands at the appropriate time. I think Jon Willams has experimented with a similar system using Audacity to figure out the timing within the sound file in order to generate the timing list. Look through the ParallaxEFX forums for his talk on this subject.
The second would be for a system in which you cannot easily start the mp3 player through a stamp, this would require more circuitry and extra effort on the sound file. Using a sound editing program you would insert very high frequency audio cues within the sound file itself, using a OOK communication scheme (on-off-keying, morse code is an example, though you dont need as complex of a system), you would encode a series of high frequency pulses (say 19kHz) into the audio stream, to do this reliably you may need to low pass frequency the original sound file to make the 19kHz band clean and free of sound. An audio interface from the mp3 output to the stamp would involve a high pass filter tuned to block out frequencies lower than 19kHz then using an energy detection circuit to convert the 19kHz frequencies into a TTL serial stream to be read by the stamp which would then act upon the serial sequnce to generate the lighting commands. The audio to be played would be passed through a low pass filter to eliminate the 19kHz signal before being amplied for the speakers. Depending on your age, you may not hear the 19kHz signals before filtering them out, but young people (especially females) will be much more likely to hear it, hence the need to filter them out.
·1+1=10
Post Edited (Paul Baker) : 1/11/2006 8:08:52 PM GMT
At sometime over the last year, perhaps only within the last 6 months, I posted one of the only messages I ever posted on the ParallaxEFX forum about an interesting new integrated circuit I'd seen in one of the magazine to which I subscribe. I don't remember too much about it, but its purpose was to aid in synching lights (LED's I think) with music. The one single LSI chip contained most if not all of the various elements required for such a feat.
I tried searching that EFX forum but to no avail, but I will continue trying. I ALWAYS sign my messages as I have signed this one, so that's all you really have to search for, since I've not been active on that particular forum.
Since I can't remember too much about it, I can't make any promises, but it might be worth the look. I do have one other thought, but let me hold on to it for now. It involves using a Stamp to drive a specialized converter chip which will then permit you to connect with a much larger scale theatrical system which supports any kind of lights, dimmers, music, special effects, etc. It's probably more involved and a good deal more costly than you may want to get into. In a sense, the Stamp would act like a "stage manager" (so to speak).
Bruce Bates
if will MIDI tell you what notes are on...and at what level?
I'd say, re-record the music and use a couple of off beat notes with no volume to them. IF the MIDI interface will report that X note is on but volume is 1 (or whatever really low is) then you could have a stamp interface to it that will wait for those notes.
I'm I way out to lunch...mmm, donut!
Steve
·1+1=10
This should be the IC I had in mind:
http://news.thomasnet.com/fullstory/457618/798
I'm sure the National Semiconductor web site will have even more information on it.
Bruce Bates
Yes, the NOTE ON and (interestingly) NOTE OFF commands have a "velocity" byte which sets the initial value. In practice, most sytems don't use the NOTE OFF instruction, they send a NOTE ON with a velocity (volume) of zero.
Jon Williams
·1+1=10
National appears to be offering samples, which can be reached right from this web page:
http://www.national.com/pf/LP/LP3950.html
Bruce Bates
I had the chance some time ago to get into MIDI, but never took it up... I know less about MIDI then I do about analog circuits.
I like the idea of super-imposing an "unheard" audio frequency on the original MP3 song. and then jack that data into the chip Bruce suggested. (I like that chip!) In theory, with that chip in 'frequency mode', I should get at least one channel of control. Make an external filter to ensure only the frequencies I need are being recieved by the chip. And, because I'm using a protable mp3 player, I can use the reverse bypass filter to prevent the controll tones from being sent to the amp / speaker system. Does that sound like "fool proof"?
Edit the MP3 using some software, overlaying my "control frequency" as needed. Next, download the song into the MP3 player...
Connect the output of the MP3 player to both a "band pass" -> (passes the controll frequency into the light controll system), and "bypass" -> (removes the control frequency into the amp / speaker system). (Are these the right terms?)
Set the chip Bruce recomended into "frequency" mode, and get the controll singles at the LED driver outputs.
Program the BS2 with an index array of count -> light changes list
Every pulse from the output of the LP3950, increment the counter, lookup the address and lights to change.. send out the command to the light controll bord.
Points of contention...
a MP3 editor that will let me insert the control frequency...
finding a frequenct the mp3 editor & player will suport that won't interfere with the song.
the rest is somewhat simplified by the LP3950, STP16C596, BSP2 and eeprom (I forget that chip name)...
Can anyone find a falt with this method, or maybe a better way?
And, again, thanks everyone for the input!
KK
In short, MIDI does not care what instruments you have hooked up or what kind of sounds they make, it's just a series of 'note-on' and 'note-off' </Mr. Miyagi mode> and 'program-change' type messages (yes, Jon, I know htere are more <g>)...
I have just seen people get wrapped up in thinking that MIDI somehow is sound and wanted to try to nip that in the bud...
Someone else can say whether music players have 'audible bandpass' filters or not....the cheaper ones may not.
don't know til you try it though!
Steve
All said and told, I'm hoppin to make a system for much less then the above (see the first post)...
Thanks again all... this is gonna ROCK!
Update: There Ain't no such thang as a free lunch! (or chip!)
Well, I've ordered 2 'free' samples for $8.37 USD... they'll be here in a few days... And, just to cover the bases, I'm off to discover how MIDI is interpeted and sent via the MIDI interface that's the part of every game port on all PC's..
Tom, can you suggest a site that would help me out... from ground zero?
KK
http://www.discolitez.com/
Rick
SWEET!
Well, that about answers the questions on how to do the "hard" part...
(Getting the song... to play and to get synced lights... off the para pra port...)
Now to get how it sends what out to the port... then design the interface accordinging...
Good Show Rockin_RIck... your Rockin??!?! (Ok, pardon the pun, but the shoe fits!)
/me is getting more and more into this project!
KK
jem.dhs.org/~ed/ece499/
And thanks Kelvin... I'm checking that out as well..
KK
FWIW - rockin_rick was a username that I started several years ago on a different, music orientated message board (www.openneo.org/) and it has sorta just followed me.... Not a musician, just a music lover....
Rick
Time based light control :
Lets say you want to control 3 lights, on,off and dimming. You want to play the music and see the lights do what you program them to do. Think about doing it realtime and recording the on,off,dimming data in realtime. The same way a recording in made in a studio. Build a circuit with a dimmer (pot) that your BS2 can read and store data.
Now use one pin on the BS2 to sync the start of the playback, while it is playing the BS2 can be recording the movement of the dimmer for one light. Now do that three times saving the data each time in a new eprom space. Now to play with lights, have your program start the playback and read the data from the three arrays you recorded to control the lights.
You may be able to hook up say 10 slide controls and record 10 lights at once or something like that.
Oh, if you do one at a time, the program should control the light that has been recorded while you record the next one so you can see the effect build as you go.
Kind of like laying out a movie with a movie editor. You could use that too if you could seperate the tracks and import the data to the BS2 , using just a volume level in a track , you would have to condense the data to something the BS2 could use though if your up to it.
Think outside the BOX!
of course your stamp would have to decipher all this and then control the objects. An SX would do it all faster!
I don't know of an easy way to take mp3 type music and midi'ize it!
To me, midi format music tends to sound like muzak (that elevate funk)!
So, if you odn't have access to a popular songs individual tracks, then you might have to do some work yourself!
I'm kinda speaking out of turn....don't know midi well enough to understand its intricacies!
Steve
I'm looking at the possibality of...
something like metron sugested, do a playback of a seq file, in real time with the queus needed to control the lights.
At this point, that's about the best I can do...
the hardest part is going to be keeping in sync, and getting the original sync mark right...
Hmmm I've gone as far as researching how to decode the mp3 file to get the frame "sync"...
Hmmm, whats the resoultion of the rtc that cam with the bonus pack? I could use that for my sync pulses...
Then the hard part is building the seq list of instructions, and getting the inital sync...
More to come...
and, again, thanks to all for everything!
KK
Click on DEMOS in the right center of page.
http://www.sonicimplants.com/ProductDetail.asp?Item=CDStringCollection
Sort of like overdubbing with the midi component.
If you can do that, then you're laffing!!
Steve
I use the Garritan PERSONAL ORCHESTRA software. It is a full orchestra all on a keyboard.
http://www.garritan.com/
I used midi music, but I believe that Cakewalk Professional allows you to have midi syncronized with a wav or mps file, although I have not tried it. The software is a bit expensive.
An article about my fountain with code, circuits, pictures and movies can be found at http://www.chaneyproductions.com/h-2-opus.htm
Vic
I also dicovered a MP3 playback CHIP.. so, there's the hook...
I think I'm going to go this route... MIDI, while much more adapt at adding tracks to the score, can get large, and the communications rates are very fast...· Pratically taking me out of the relm of the stamps.
Ok, this project just got larger... basic concept is this now this:
Sections:
· #1) The controller.· The heart and soul of the project.· Designed to take a true 16 bit address,
····· then·0 of 15 ports within that address then supply that port with one of the following options:
····· 0 = off
····· 1 = 25% duty cycle
····· 2 = 50% duty cycle
····· 3 = 75% duty cycle
····· 4 = Amplitude Setting 1
····· 5 = Amplitude Setting 2
····· 6 = Amplitude Setting 3
····· 7 = Amplitude Setting 4
····· 8 = Amplitude Setting 5
····· 9 = Freq Setting 1
···· 10 = Freq Setting 2
···· 11 = Freq Setting 3
···· 12 = Frew Setting 4
···· 13 = Freq Setting 5
···· 14 = Freq Setting 6
···· 15 = On
···· The Amplitude settings will be provided by 1 LP3950 Color LED Driver with Audio Synchronizer in Amplitude mode.
···· The Freq settings will be provided by 1 LP3950 Color LED Driver with Audio Synchronizer in Freqency mode.
···· Details on the LP3950 Color LED Driver with Audio Synchronizer: http://www.national.com/ds/LP/LP3950.pdf
···· Continous Duty Cycle outputs will need to be created.·
···· The object is to duplicate the PWM command, so the stamp is free to·continue working.·
···· I'm thinking of using something like a 555 with a digital pot for tuning.
···· All options will be gated (4066 chip) to addressed port.·
···· This means the system buss will have all of the listed output options,·the address line, and port address line.
···· Basic layout:
······ The primary 16 bit address addresses 1 box.
······ The secondary 16 bit address selects 1 of 16 ports within that box.
······ Each box will have it's own private STP16C596M to provide for address decoding.
······ Each port has it's own private STP16C596M to retain it's own settings.
······ Settings will be gated to the SSR via 4066 as directed by the output requirement.
···· Intended Operation:
······ Get box address, get port address, get configuration, send each address and config out on system bus.
······ Presudo code:
······ SendToBox:
······ Read Index, BoxAddress
······ Read Index + 1, PortAddress
······ Read Index + 2, COnfiguration
······ SEROUT AddressBus, 16780, [noparse][[/noparse]BoxAddress]
······ SEROUT PortBus, 16780, [noparse][[/noparse]PortAddress]
······ SEROUT DataBus, 16780, [noparse][[/noparse]Configuration]
·······RETURN
······ Details on the STP16C596M:· http://www.st.com/stonline/products/literature/ds/10154/stp16c596.pdf
···· Notes: The system bus will have all of the following contained on private lines.
······ Lines 0 to 15, Output Options as listed above.
······ Line 16 = Grnd
······ Line 17 = VSS
······ Line 18 = Box Address line
······ Line 19 = Port Address Line
······ Line 20 = Data line
······ Line 21 = Latch Line (used to latch the STP16C596's data)
······ Line 22 = Reset line (used to get all Boxes to listen on Line 23)
······ Line 23 = Reast data (Outputs 16 bits of 0's to force all outputs to off)
· #2 MP3 Player for internaly played music for Syncing.
···· MP3 playback provided by STA013 chip. http://www.pjrc.com/tech/mp3/sta013.html
···· File system provided by ALFAT chip.·· http://www.ghielectronics.com/uALFAT-SD.htm
···· D->AUDIO conversion provided by······ http://www.cirrus.com/en/pubs/proDatasheet/CS4334-35-38-39_F3.pdf
···· VERY general operating idea is:
···· INIT the MP3 Player.
···· INIT the file system.
···· OPEN the MP3 DATA file set up for feed to MP3 Player
···· OPEN the Light DATA file
···· START PLAYER.
···· Every time the DAC completes a conversion, PULSe to a divide by counter.
···· When Divide by counter reaches 0, execute the SendToBox routine (as above).
···· The divide by counter is to take the BPS or VBR count (as derived by the actual conversion of the digital data)
···· and get a .5 to 1 second clock freq to drive the reader code.· The reader code would be modified to read from file.
···· The only thing I'm not 100% sure on is how to get the pulses from either the DAC or MP3, or where to queue them·at.
···· Additionally, I may need to add ram.· I don't know if the ALFAT can supply data to the MP3, the·lights and
···· still have a clean play back.
Ok, I know this is a big post, but it covers a lot of research·completed.· As always, I'm open to ideas.· I'm about done with the research stage, and·gearing up for·prototyping the main board and the first box board.· The only thing that·remains is the program to create the·light·data file.· Well, I've been programming for way too many years to skip out on that challange!· I've already found a .net app that will·read a given MP3's frame headers. (means I can make a time line....)
Basic Schmatics and drawings for the controller to follow shortly...
(Geez, after all this, and my babbling, I do hope at least one person is interested in this project)
Thanks for everything, everyone!
KK
kelvin
