Car diagnostics with BS2
Has anyone here attempted putting together something to do car diagnostics with the BS2?· From what I see, it looks like all you'd need would be an LCD, the proper connector, and the specs for the interface.
Dave
Dave
So far it's incorporating a LCD "guage cluster" of sorts displaying O2 count readings (averaged for accuracy), RPMs, fuel pressure, vacuum/boost, and quite a few temp readings of various parts. Wiring has become pretty intense though.
I also plan on having another system to control the tranny, including shift points, manual electronic shifting, torque converter setpoints, etc., but I have not quite dived into that yet as I am still pretty busy getting everything worked out with the LCD display stuff. Last step is engine control, but at the point I am unsure if a Stamp would be best.
Or are you referring to something like datalogging using the car's existing hardware?
-Blake
Dave
You're definately not the first person to think about it....nor the last.
I'm planning on using this as my latest "big project" (just been itching for something to do).
The easiest part of your first post to get is the connector and the LCD....try and find the spec on the Net, for FREE that is.
Nobody seems to have posted the protocol in detail.· All I've found is that Gm is something like PWM and Ford is Variable PWM....and the ISO (Eurpean) wasn't stated.
I had to order a book with the protocol (a few $'s) but looks like I won't get it in time for Christmas, ah well.· I was hoping to take the book to the parents while on break, but I hope to get in to it after new years and post results here.· OF course, having said that, do feel free to dive in and crosspost your results as well.· I don't intend to dissuade others from doing it.
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
What book did you order and what protocol was it for
Uhm....I grabbed it off of Amazon.com
Here's the link:
http://www.amazon.com/exec/obidos/tg/detail/-/0971541140/104-6877387-6887105?%5Fencoding=UTF8&v=glance
·I saw a reference to this particular book off of a website (can't remember which one...) and it doesn't look too bad.· Definately cheaper than the protocol specs from the standards guys!
Steve
Achilles, what year is your wifes car? From my experience from modding cars, OBDII stuff (usually around '96 cars and up) is always more of a pain in the Smile than OBDI, and the equipment is usually a difference of night and day as far as cost goes, like the scanners places like Autozone use. In fact, OBDII to OBDI swaps are pretty common to keep costs down. But I dont have any real experience with it as far as trying to interface with it, but have heard it is no walk in the park.
Steve, let us know how that book is, I have also wanted to figure out how to interact with the PCM, but havent quite gotten there yet!!
Post Edited (The Lazy Destroyer) : 12/21/2004 12:40:20 AM GMT
Not sure what is here yet but it looks like some good data.
Larry Gaminde
It'd also be cool in a geeky sort of way if you could datalog drives for your car...
And, if I'm not mistaken, it will give a brief description....or just a label along with the code (I'M NOT SURE ABOUT THIS ONE...might just be the newer NEW cars!).
Anyhow, with your vehicle off....insert key and turn to the on position (do not start the engine though), do this 3 times; So it's on-off; on-off; on-off.
Then 'on' the last time and you should get some gauge checks and lamp checks and then it should spit out your trouble code on that little digital odometer display.
This will LIKELY work on your newer vehicle....might not on the '98.· Then again, this might be a "BIG 3" thing and not a foriegn thing....
Anyhow, it works on north american vehicles for sure!
Steve
It is dated June of '93 as a submission for recognition as a Standard....I don't know if this means it became standard...but since I haven't been able to find current standards on the net, I'll assume that it was reworked somehow.· But maybe not....
Anyhow, at the least it gives an idea how it might work.....
Thanks Larry
Steve
Some threads ago I saw a chip that would act as a interface between a OBD and a Stamp. I think the cost was in the neighboor hood of $35. I realize the stamp can easily handle the chip does, but the cost in memory might enough to sacrifice your LCD screen.
I'll add the website for the chip when I get home.
I was under the standing that '98 and newer were all OBD2.
and my Jeep is a 2002 and DOES work with the on-off trick.
Then I do a quick search and the first site says, "for ODB1 vehicles do the on-off trick <paraphrasing>....and counting the blinkety blinks!"
Anyhow, I couldn't find anything that directly said mine was an OBD2....but certainly this guy < http://www.stu-offroad.com/misc/obdii.htm·> has a '98 TJ with OBD2.· No reference to the on-off thing.
He used this product from these guys: http://obddiagnostics.com/
This site sells the BR16Fxx IC for interfacing between a laptop and the car computer.· Good site actually,
I've included a couple other pages off this site.·
And certainly after 1996/1998 most vehicles went to OBD2.· So, I'm certain this on-off trick that I'm doing is being done on an OBD2 vehicle.
Steve
http://www.elmelectronics.com/obdindex.html
One of the chips converts OBD II to RS232, which is very usefull.
I've also picked up a book off of Amazon.com to help a little (It's not the ISO/SAE protocol descriptions).
The ELM datasheet gives enough information to get the generic trouble codes and decode them easily enough.· It'll take a bit more work to get the manufacturer specific codes....just a different register to look in on the car computer!
Anyhow, I hope to get the circuit punched together this week and maybe a quick test too.· I expect to have ground buss issues (as the cars gnd is a couple volts higher than the stamps)....but the datasheet is pretty good for telling how to get around that....might just use opto's to isolate (that's the easiest me thinks!).
http://www.elmelectronics.com/DSheets/ELM322DS.pdf
here's a quick link to the datasheet (hope that works!).
Anyhow, they weren't too expensive...but KNOW what protocol you're car uses!· The Manufacturer's service manual will tell you....I have a chrysler product which stated a different protocol for what my '02JeepTJ actually uses....so some manufacturers' switch between models...beware!
Steve
I just finished hooking up my circuit and tested it to my laptop.·
We're getting a whack of Canadian weather at the moment and I'm not eager to sit outside and try the other end of the comms.
But just for now I've been able to talk to the IC.
Here's the circuit I used and a quick image of what to expect at the prompt.
In the schematic I ran out of 3904's and used a 2N2222...also, there's a requirement for a 9.1V Zener.· I had to use 2 4.7Vzeners inseries.·
And ended up using 1uF caps instead of the 0.1uF.· Success nonetheless.
Upon power up of the circuit, the ELM322 IC responds to a successful startup with it's name and version followed by the ">" as it's prompt (image included).
My thought is to interface with this IC and do the simple stuff with the stamp.·
It's really all that challenging so far as interfacing the stamp to a nicely prepped rs232 line, so eventually I'll try to reverse engineer the ELM in order to replace it with the stamp.· Babysteps!!
Steve
·· I know *I* will be eagerly awaiting the results of your findings...Years ago we tried to develop an interface for the Z80 ACM we built...As you have no doubt found out, specs are hard to find without spending $$, and without a guarantee on a return, we gave up.· Now I'd be happy to connect my BS2 and read the codes without having to count pulses...Counting pulses is how I did it years ago...
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
