Reading tachometer signal...
Hello,
I'm trying to find out what is the best route in reading a tachometer
signal from a motor. I will have to tap into the coil ignition side
wire. The wire shows 12+ volts with the key on ignition with the
engine off then shows ground every time the coil fires when the motor
is running. This will show a low AC signal and maybe higher than 5
volts at higher rpms. I think I'll have to read how many times the
wire will show ground per second. Is there a way to connect it to the
Stamp or will I need some sort of external chip.
Cozz
Cozz
volts. One challenge is going to be the circuit that will interface to the
negative side of the ignition coil. Indeed, the signal is 12 volts and 0 volts,
but
for short periods of time just after the coil ground is "let go" the voltage
will reach close to 300 volts.
I have messed with this several times, and because of my stupidity, I have
yet to design a good circuit that can supress the 300 volt spikes seen on an
oscope as the coil ground is let go. Any ideas out there? Some LC circuit?
In any event, once the interface circuit is done and you have a clean signal,
an opto isolator is in order.
To read the signal with your stamp, you could use the PULSIN command and
measue the HIGH time of the pulse, which will give you the time between coil
events. Another command is COUNT that will measure the number of pulses for a
given
period, but this is unlikely the command you want if you need to fire an
injector or some other thing.
Another note assuming this is a modern engine.......for any given rpm the
time between pulses will change based on engine load.....because as the ignition
timing changes, the time when to fire the coil changes.
Have you considered taking the signal from the Crankshaft or Camshaft
position sensor? The signal from these sensors is often a "clean" 0 to 5 volts
DC
and will be much easier to deal with than the negative side of the coil.
Hello,
Cozz
smartdim@a... writes:
I don't think you will see a low level AC, but you will see 0 volts and 2
volts.
I don't think you will see a low level AC, but you will see 0 volts and 12
volts.
0 and 12, not 0 and 2
output wire (that is going to the distributor) of the coil? If its a
somewhat newer car you might want to piggy back off the crank angle sensor
(CAS).
-Rob
Sent: Sunday, December 21, 2003 10:30 AM
Subject: Re: [noparse][[/noparse]basicstamps] Reading tachometer signal...
volts, but
voltage
an
circuit?
signal,
coil
for a given
ignition
volts DC
> Hello,
> Thanks,
> Cozz
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
coil is fired. In fact, I think that's how a coil fires in the first
place. Charge it like a cap then ground the positve side. I just want
to read the RPM's and nothing more. I don't need to control any
injectors and what not. If this is the case then I really like the
COUNT feature. Should I place anything inline from the coil lead to
the stamp other than a resistor? I'm afraid of burning the Stamp out.
Cozz
and 12
to the
and 0 volts, but
the voltage
I have
seen on an
circuit?
clean signal,
command and
between coil
pulses for a given
fire an
rpm the
the ignition
Camshaft
0 to 5 volts DC
coil.
side of the coil is a DC signal with respect to chassis ground.
Again, assuming a standard vehicle ignition system, it works as follows:
the coil is grounded to build up current in the coil primary windings, then
the ground on the coil is QUICKLY released, which causes the high voltage that
will jump the spark plug gap and of course, ignite the fuel air mixture in the
combustion chamber.
You ABSOLUTELY need some circuit to interface that negative side of the
ignition coil to the Stamp or you WILL burn out the stamp. The Stamp input pins
want a TTL level signal (basically 0 to 5 volts) and a 12 volt signal will
damage
the stamp.
With regards to the voltage you are reading, you mentioned -12 volts.....are
seeing minus 12 volts? What kind of engine is this?
ken
I honestly think it is AC because I read a full -12 volts when the
Cozz
double check the power on the coil. You're maybe right.
What conversion is best to convert from 12 volts to TTL?
Cozz
> If you are talking about a "standard" automobile ignition coil, the
negative
follows:
windings, then
voltage that
mixture in the
> combustion chamber.
the
Stamp input pins
signal will damage
> the stamp.
volts.....are
> ken
cozz.home@v... writes:
It's an old Ford. One side of the coil is always grounded. I'll
Cozz
Cozz,
There are a myrad of ways to convert the 0 to 12 volts to a TTL level signal,
and here are two ways.
METHOD ONE
Safest way to protect your stamp........use a 4n35 opto isolator (this is a
dip 8 package).
Connect pin 1 to the 0 to 12 volts signal THROUGH a 1k ohm resistor.
Connect pin 2 to the vehicle ground
Connect pin 5 to the Stamp +5 volt supply THROUGH a 4.7k ohm resistor
Also connect pin 5 to your Stamp input pin
Connect pin 4 to the Stamp ground
Optional.....connect pin 6 to the Stamp groung THROUGH a 1k ohm resistor.
The "protection" for your stamp will come from the vehicle ground NOT
connected to the stamp power supply ground.
When the coil is not grouned, the Stamp input pin will receive a logic 0
(close to zero volts)
When the coil is ground, the Stamp input pin will receive a logic 1, 5 volts.
METHOD TWO
Get a 2n2222 or 2n3904 NPN transistor.
Connect the emitter to ground
Connect the collector to the Stamp +5 volts supply THROUGH 4.7k ohms
Connect the collector to the Stamp input pin
Connect the 0 to 12 volt signal to the base THROUGH 10k ohms.
This will give you the same inversion......coil not grouned Stamp gets logic
0 and visa versa.
The stamp will not be harmed by this setup unless there is some failure with
the transistor........and that is why the opto isolator mentioned first is a
safe way in my opinion to interface the coil to the stamp
ken
What about using a hall effect sensor or similar? You could also wrap a
couple loops of wire around a spark plug wire or the + side of the ignition
coil.
There are also opto-isolators that can take 12V. This might be best. You
want to be completely isolated in case of voltage spikes.
Jonathan
Sent: Tuesday, December 23, 2003 7:53 PM
Subject: [noparse][[/noparse]basicstamps] Re: Reading tachometer signal...
> Thanks,
> Cozz
> negative
> follows:
> windings, then
> voltage that
> mixture in the
> > combustion chamber.
> the
> Stamp input pins
> signal will damage
> > the stamp.
> volts.....are
> > ken
> Yahoo! Groups Links
heard to work with untill the TFI cleans it up. I would like to go to
the coil and make it a universal setup of sorts.
Cozz
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@p...> wrote:
> Cozz,
wrap a
ignition
> coil.
best. You
> Jonathan
I was told that the signal from the hall effect sensor was really
Cozz
Strongly recommend the 4n35....but it is a DIP 6 and not a DIP 8 as I
incorrectly stated in an earlier post.
SNIP
> Jonathan
Having worked with Ignition coil pick-up for a tach signal I can tell you for
sure there will be plenty of spikes!
I have had success using a 4n33 with a 100K resistor in series and a 5v zener
across the LED, this limits the current and keeps the
voltage down in both directions. You will also need a cap across the E-C of the
output and a 100k pull-up to allow time to read the
spike period.
KF4HAZ - Lonnie
Instead of using Zener diodes to clamp transients, use a TRANSZORB.
These devices are designed to clamp-off transients (very fast and
high energy levels).
They are better than Zeners or even MOVs.
another post. I'll give those a try. If anything I'll go to the
4n35's.
Cozz
I need to be able to jump from test engine to test engine really
quick. So..
Does anyone know where I could find info for getting the tach signal
from an antenna or wire wrapped around the plug wire? I've heard of
this before but have never seen an actual unit in operation or had
one to copy. I figure I'll just count the time between spikes with
the pulsin command.
Thanks for any help.
Craig
inductive pickup and is cheap, cheap, cheap. You should be able to find a
trigger
signal in the pc board. Just be careful as the flash unit has around 3kv on it.
Alan Bradford
Plasma Technologies
In a message dated 12/26/2003 6:21:21 PM Eastern Standard Time,
n2oinjection@y... writes:
This is great information. I'm attempting a similar thing, but....
quick. So..
the pulsin command.
Craig
The automotive industry has inductive clamp on pickups for spark plug wires.
There are several out there. Here is a link to just one.
Snap Vantage Mt2400 Power Graphing Meter
In a message dated 12/26/2003 3:21:19 PM Pacific Standard Time,
quick. So..
the pulsin command.
Craig
I do have a clamp from a Sun timing light, but my problem has become
a little more troublesome the hardware.
I have a chassis dyno for motorcycles. Getting access to plug wires
is easy on Harleys and import bikes (prior to 1986), but late model
sport bikes have so much body work, it can take 30 minutes to get
the tank, sidepanels and sometimes airbox removed. Then I sometimes
discover the bikes have a coil in cap set up that only allows me a
low voltage signal.
I do have the ability to perform the above , but most customers are
so cheap, they think that the $30 base dyno run shouldin clude the
1/2 hour to disassemble their bike and the 1/2 hour to reassemble it
as well.
So, since I building my own BS2 based interface for the dyno (to
include Wideband O2 data logging) I figured I might be able to pick
up ignition signal with out removing body work. Sometimes I can see
the plug wires with just a little body work removed, but thre is not
enough room for the clamp to get in there. Hence the antenna idea.
I like the idea of disassembling a timing light though. Sounds like
I would at least get an isolated signal. I'll have to look into
that if I can't find an antenna or quick 'wire-wrap' method.
Thanks for the help and ideas.
Craig
> Craig,
plug wires.
> quick. So..
signal
of
with
> the pulsin command.
> Craig
My 2ct. A mike fitted on the exhaust?
ECO
Sent: Saturday, December 27, 2003 9:38 AM
> Thanks for the quick response guys,
> low voltage signal.
> as well.
> Craig
> > Craig,
> plug wires.
> > quick. So..
> signal
> of
> with
> > the pulsin command.
> > Craig
> Yahoo! Groups Links
compressors. There was a contact mic bolted to the head, and we could see
rpm, as well as various harmonically related vibrations that could indicate
bad bearing, etc...
Perhaps a simple contact "mic" would do the trick.
Mike Sokol
www.modernrecording.com
mikes@m...
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Saturday, December 27, 2003 5:35 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Reading tachometer signal...
> Craig
> ECO
> From: "Craig" <n2oinjection@y...>
> > low voltage signal.
> > as well.
> > Craig
> > > Craig,
> > plug wires.
> > > quick. So..
> > signal
> > of
> > with
> > > the pulsin command.
> > > Craig
> > Yahoo! Groups Links
> Yahoo! Groups Links
to be pretty good at picking up ignition noise, and perhaps it can be hacked
to suit your needs.
In a message dated 12/27/2003 12:39:49 AM Pacific Standard Time,
low voltage signal.
as well.
Craig
Seems to me that if you wrap an insulated wire around the plug wire, & tie
one end to the motor the other will give you a signal that you can use, The
more turns the more voltage, so you decide if turns or amplifiation with an op
amp would suit your needs,
regards,
Leroy
Date: 2003/12/26 Fri PM 06:20:20 EST
quick. So..
the pulsin command.
Craig
Yahoo! Groups Links
regards,
Leroy
quick. So..
the pulsin command.
Craig
Yahoo! Groups Links
regards,
Leroy
quick. So..
the pulsin command.
Craig
Yahoo! Groups Links
HALF a turn around the ignition wire is enough to ignite a small Neon
bulb.
If you have a screwdriver with a Neon light in it to detect the live
wire of 220 Volts is will light as soon as it is placed close to an
ignition wire.
It is a nice and cheap tool to find out which sparkplugs in your
engine are working OK :-).
Be carefull, this could easily blow up your OpAmp!!
Klaus
--- In basicstamps@yahoogroups.com, <leroy@f...> wrote:
> Craig,
wire, & tie
use, The more turns the more voltage, so you decide if turns or
amplifiation with an op amp would suit your needs,
> regards,
> Leroy
> quick. So..
signal
of
> the pulsin command.
> Craig
Subject and Body of the message will be ignored.
> Yahoo! Groups Links
How about using this neon bulb to trigger a photo-transistor. That would
seem to bullet-proof, and completely isolated to boot... Stick both in a
little piece of black PVC and cover the ends with e-tape.
Mike Sokol
mikes@m...
-William of Occam-
Sent: Saturday, December 27, 2003 2:55 PM
> Mind You,
> bulb.
> ignition wire.
> Regards,
> Klaus
> > Craig,
> wire, & tie
> > regards,
> > Leroy
> > quick. So..
> signal
> of
> > the pulsin command.
> > Craig
> > Yahoo! Groups Links
> Yahoo! Groups Links
> bulb.
> ignition wire.
The only problem may be that the neon can't flash fast enough -- but you
may be able to use a photo-resitive cell and measure the relative
brightness of the neon to get an approximate speed.
I used this method to build a ringer interface on a telephone about 25
years ago, long before they had these phone flashers and stuff for the
hearing impaired.
cheap automotive timing lights that were just a big neon bulb. It would be a
simple enough test to rig. An o-scope would be the definitive test, but
certainly a B-stamp could catch the pulses until they ran together from too
many RPMs. Just keep upping the revs until your counter went stupid and said
zero RPM.
Mike Sokol
mikes@m...
301-739-6842 (Office)
301-964-5682 (Mobile)
-William of Occam-
To: "Basic Stamp List" <basicstamps@yahoogroups.com>
Sent: Saturday, December 27, 2003 3:20 PM
> Dang, you beat me to it.
> hearing impaired.
> Yahoo! Groups Links
http://www.statorgator.com/
The r/c heli version outputs a 5V level signal.
> I do have a clamp from a Sun timing light, but my problem has become a
> I have a chassis dyno for motorcycles. Getting access to plug wires is
> easy on Harleys and import bikes (prior to 1986), but late model sport
> bikes have so much body work, it can take 30 minutes to get the tank,
> sidepanels and sometimes airbox removed. Then I sometimes discover the
> bikes have a coil in cap set up that only allows me a low voltage
> signal.
Thanks for all the input guys. Looks like I have few experiments to
try. Thanks for the help. I'll kep you all posted on my progress.
I'm sure I'll be back with other BS2 questions when I get further
along.
Craig.
--- In basicstamps@yahoogroups.com, "Mike Sokol" <mike.sokol@m...>
wrote:
> I thought about the neon trigger speed issue, but seem to remember
really
would be a
test, but
from too
stupid and said
> zero RPM.
> Mike Sokol
> mikes@m...
> -William of Occam-
> From: "Bill Boyer" <daweasel@s...>
but you
about 25
for the
> > hearing impaired.
That would
both in a
Subject and
> > Yahoo! Groups Links
