Personalized PCB boards — Parallax Forums
edited 2003-04-27 18:16 in General Discussion
Hi all,
I just wanted to know what was the best way to make your own PCB boards.
I need my project to be permanent, and I have pretty good soldering
skills I was just confused about what to get and maybe yall would share
some tips if you have 'em.
Thanx
-Mike
    edited 2003-04-13 23:23
    How complex is your project? Is it worth spending $34 (including shipping)
    to have a professionally made board? Doubles sided, plated-through holes,
    solder mask, silk screen component designation?
    I recently had a board made for a project that had a 16F877, plus 6 other
    ICs, voltage regulator, a half dozen transistors and a bunch or resistors
    and capacitors. I had the board made by Olimex in Bulgaria. It's a nice
    piece of work.
    If you want to make your own, there are a bunch of different ways - a
    GOOGLE search will turn up bunch of sites with a lot of good information.
    Larry
    At 06:02 PM 4/13/2003 -0400, you wrote:
    >Hi all,
    >Thanx
    >-Mike
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Larry Bradley
    Orleans (Ottawa), Ontario, CANADA
    edited 2003-04-13 23:24
    In a message dated 4/13/2003 3:01:16 PM Pacific Daylight Time,
    laxboy687@e... writes:
    > Hi all,
    > Thanx
    > -Mike
    Mike,
    Try <A HREF="www.expresspcb.com">www.expresspcb.com</A>
    You download their easy to use free software, layout a two sided board. There
    are several options on board sizes and cost. They have a standard service,
    three 2.5 by 3.5 double sided board for $65.
    If your board size is bigger, once you finish your layout, you can select an
    option that will calculate board cost. Once you are satisfied, hit a "send"
    button and depending on what service you choose, you will have your boards in
    two to three days.
    I have used this service many times and am happy with the results.......
    Ken
    edited 2003-04-13 23:26
    In a message dated 4/13/2003 3:24:27 PM Pacific Daylight Time,
    lhbradley@i... writes:
    > piece of work.
    > Larry
    Larry,
    $34???? Really? sounds too good to be true... I have been using
    expresspcb. Looks like I might need to look into this company....
    Ken
    edited 2003-04-14 01:15
    Yup. Check www.olimex.com
    $21 for single sided board, $26 for double sided, plus $8 shipping.
    Good quality. Reasonable turnaround times.
    At 06:26 PM 4/13/2003 -0400, you wrote:
    >Larry,
    >Ken
    Larry Bradley
    edited 2003-04-14 01:17
    The difference is that your gerber files must be complete and correct.
    PCB Express doens't care as they use their own software.
    I find it's easier to use PCBExpress for simplicity then to use Eagle
    for it's strenghts. problem is that there are no simple and low cost
    programs that output gerber files.
    Another difference is shipping PCB express has them to you in a few
    days. from Bulgaria, it takes a little longer or the shipping is a
    little more.
    Dave
    shipping)
    through holes,
    6 other
    resistors
    a nice
    > > piece of work.
    ways - a
    information.
    > > Larry
    > Larry,
    > Ken
    edited 2003-04-14 01:52
    Hey thanks all,
    I was actually looking for something I could do at home. I saw some sort
    of kit at radio shack where you layed out the circuit with some stickers
    and then you pour some sort of solvent over the board and you get a PCB.
    Ill look into it a bit more. But ill try this company if it really isn't
    worth getting that kit.
    Thanks again everyone!
    -Mike
    From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jq_yC28gfFuxK0yA5tuo22pk6e1mvkhLreRyGr1kstJ7CsIt1uHZFg0pOfdCE0ItBztlzWZf9HmmzbBX5Q]laxboy687@e...[/url
    Sent: Sunday, April 13, 2003 6:03 PM
    Subject: [noparse][[/noparse]basicstamps] Personalized PCB boards
    Hi all,
    Thanx
    -Mike
    edited 2003-04-14 02:42
    In a message dated 4/13/2003 5:50:33 PM Pacific Daylight Time,
    > Hey thanks all,
    > -Mike
    The "home kit"radio shack thing works for very simple boards and even not so
    simple boards, however, the quality is not that of boards you would get from
    the sources previously posted..
    Ken
    edited 2003-04-14 03:18
    I use this Toner Transfer System with great success:
    http://www.dynaart.com/DTF/A.PCB.html
    Sent: Sunday, April 13, 2003 8:52 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Personalized PCB boards
    > Hey thanks all,
    > -Mike
    > From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zV-ofr9uK4dpAkp4dlYu1HadYFLXtcySbcNwFV5rx9ey8bGEqhZRdgORNIs3bzAE23cM_JMYSerBhH4zyEv89w]laxboy687@e...[/url
    > Hi all,
    > Thanx
    > -Mike
    edited 2003-04-14 13:40
    For general information:
    Eagle software from www.cadsoftusa.com is available for free non-commercial
    use and the program generates all the gerber files necessary to make a pc
    board.
    Jim
    http://www.geocities.com/jimforkin2003/
    From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HfMBf6Q_UaPL4t5bQ1_I56qryEYo4oKGwD2S8dZuGVLHBTab5fgCB5aAzMtiN6jbwgQesHagG6c]davemucha@j...[/url
    Sent: Sunday, April 13, 2003 8:17 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Personalized PCB boards
    little more.
    Dave
    shipping)
    through holes,
    6 other
    resistors
    a nice
    > > piece of work.
    ways - a
    information.
    > > Larry
    > Larry,
    > Ken
    edited 2003-04-14 13:41
    > Hi all,
    I recommend making them at home with Kepro parts. I shoot my
    own PCBs as I need them. I have made mostly single-sided and a
    few double-sided PCBs. I don't have plated through holes or a top
    silk, but other than that, the quality is as good as a board house.
    Add to that that I can design, shoot, and etch a 4" by 6" board
    within a few hours for about $5. I use my setup to create PCBs for
    my high altitude balloon program and robots. My students make
    several PCBs a year.
    Paul
    edited 2003-04-14 13:42
    Check out Circuit Cellar for my article on making PCBs at home.
    The quality of the PCBs will run circles around PCBs make with
    rub-on decals.
    Paul
    edited 2003-04-14 15:16
    some sort
    stickers
    a PCB.
    really isn't
    > rub-on decals.
    > Paul
    That calls for a link Paul !
    edited 2003-04-14 15:19
    Mike,
    I use the laser printer toner method with great sucess, and it only costs
    about $50 or less to get it set up. I use a Pyrex baking pan with a lid for
    my etchant and tinning solution, and have a lab type hot plate to put it on.
    I can easily make pretty complex boards up to about 4" * 6". Take the
    trouble to tin, it makes assembly MUCH easier.
    If you go this route, ontact me off list anf I'll be happy to detail my
    procedure and equipment.
    Jonathan
    www.madlabs.info
    Sent: Sunday, April 13, 2003 5:52 PM
    > Hey thanks all,
    > -Mike
    > From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xfdv7JhgrTKSzpgBp3j6_f4dnSylHVWSYekGOeIfsQ5TvboMJE32JAnVAz2BI2Uv2wJiFvEl7UFivU4Il-_S6DU]laxboy687@e...[/url
    > Hi all,
    > Thanx
    > -Mike
    edited 2003-04-14 15:22
    Have a look at http://www.wd5gnr.com/pcb.htm
    Al Williams
    AWC
    * Easy RS-232 Prototyping
    http://www.al-williams.com/awce/rs1.htm
    > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pQEylrZ7xrZUwD26eiw_FOS1iuL4dsKcLlNzkv4RS0Aq0jhd3es67lX50B39ooX4-xL6xLNXdEgLB6XT3F6Mlw]jpeakall@m...[/url
    > Sent: Monday, April 14, 2003 9:19 AM
    > Subject: Re: [noparse][[/noparse]basicstamps] Personalized PCB boards
    > Mike,
    > it only costs about $50 or less to get it set up. I use a
    > Pyrex baking pan with a lid for my etchant and tinning
    > solution, and have a lab type hot plate to put it on. I can
    > the trouble to tin, it makes assembly MUCH easier.
    > detail my procedure and equipment.
    > Jonathan
    > www.madlabs.info
    > From: "Mike Dillon" <laxboy687@e...>
    > > Hey thanks all,
    > > sort of kit at radio shack where you layed out the circuit
    > with some
    > > stickers and then you pour some sort of solvent over the
    > board and you
    > > get a PCB. Ill look into it a bit more. But ill try this
    > company if it
    > > really isn't worth getting that kit. Thanks again everyone! -Mike
    > > From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2S1LcW-wpaGQq-ZiNRqDsad7cT4SXzYzrggTMLMLlxMz1fhNRQM3JV4pRhAzFbe-XliQO0qM3W0dgDgDkgHE]laxboy687@e...[/url
    > > Hi all,
    > > boards. I need my project to be permanent, and I have pretty good
    > > soldering skills I was just confused about what to get and
    > maybe yall
    > > would share some tips if you have 'em.
    > > Thanx
    > > -Mike
    > the Subject
    > the Subject
    > > and
    I wrote an extensive article on making your own printed circuit boards at
    home using an ink jet printer. It worked in conjunction with the Express PCB
    software. The issue was August 2001 and is still available from Nuts and
    Volts http://www.nutsvolts.com
    -Kerry
    >board.
    >Jim
    >From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mlffltG3Ue9UQMPdAObfKIaaDkuDRyMIDigWQZ5dPzabE3q-ieNxezGurZGF0yP0A3QyiWH16gl3D20]davemucha@j...[/url
    >little more.
    >Dave
    >shipping)
    >through holes,
    >6 other
    >resistors
    >a nice
    >> > piece of work.
    >ways - a
    >information.
    >> > Larry
    >> Larry,
    >> Ken
    Very respectfully, your obedient servant.
    Kerry
    Admin@M...
    WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
    Kerry Barlow
    p.o. box 21
    kirkwood ny
    13795
    607-775-1575
    edited 2003-04-14 15:23
    commercial
    make a pc
    > board.
    > Jim
    > From: Dave Mucha [noparse][[/noparse]mailto:davemucha@j...]
    correct.
    Eagle
    cost
    I think SIMPLE and LOW COST makes an oxymorn ? Eagle is not simple,
    and the free version, last time I looked has limits of board size.
    Probably not a conecern for the hobbiest, but once you get over about
    3x4 inches you are up against the wall.
    Dave
    edited 2003-04-14 15:35
    It's a January issue, either 2000 or 2001. I'll look it up. the article
    is called "A Class Act", in case someone can find it before me.
    Paul
    > > rub-on decals.
    > > Paul
    edited 2003-04-14 20:56
    Hello:
    For simple projects you can get from Radio Shack a PCB that has the same
    hole pattern as their prototyping boards.
    You can get the proto working and then solder the circuit to the PCB or
    you can place the PCB over the prototype board while you are debugging
    then lift the board with the components and solder. I use the former
    method because not all parts will attach to the prototype board with the
    PCB in-between.
    Another way to make a circuit that's permanent is to use stick-on copper
    traces and pads over a plain board that has a 0.1" pattern of holes.
    Yet another way to make a soldered circuit is to use board with a
    pattern of holes on 0.1" centers where each hole has a solder pad. Just
    install parts and solder wires between them as needed.
    Regarding PCBs, I have found that the best you can expect from a single
    sided process is to route a single 0.020 trace between two IC pins that
    are on 0.1" centers. Express PCB can now do 6 mil lines so you can
    easily get two traces between adjacent pins and maybe even 3, but I have
    not tried this new narrow line.
    Have Fun,
    Brooke
    edited 2003-04-14 22:33
    Thanks everyone,
    I got exactly what I needed, I think ill try the laser printer/toner
    method, with Viewpoint 8.2. I got it off the ExpressPCB website and will
    try that out.
    Thanks again, some great info!
    -Mike
    From: Mike Dillon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Zlxw3oGGL2C1xXswYJnJyJ4ywXEZTnGkdpoAqJMEFof-bMcsdDWTXYIaURIwn60CmpIiysVkfbQDH-xq3a2K]laxboy687@e...[/url
    Hi all,
    Thanx
    -Mike
    edited 2003-04-15 15:11
    I've tried the toner transfer method too..lousy results. Out of 20
    tries I got maybe two boards and they still had to be inked in with a
    sharpie in places. The paper package warns about 'finicky' results
    with a narrow window of success. And yes it was the first two boards
    that worked. That figures. The toner washes off the boards with MEK.
    Now we're using Eagle Cad to a laser printed transparency to
    presensitized boards with perfect results. The toner washes off the
    transparency too btw. So they are reusable.
    But hey good luck. I hope your success is better than mine.
    Paul
    --- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
    wrote:
    > Thanks everyone,
    will
    > try that out.
    > -Mike
    > From: Mike Dillon [noparse][[/noparse]mailto:laxboy687@e...]
    > Hi all,
    boards.
    share
    > Thanx
    > -Mike
    Subject
    edited 2003-04-15 15:30
    In a message dated 4/15/2003 7:25:15 AM Pacific Daylight Time,
    prcoy@y... writes:
    Is what you speak of the same as an Iron on transfer? I have had good
    results with the iron on transfer. With a laser printer, you print you layout
    onto a special paper. Then iron the paper onto a clean copper board, peel the
    transfer off the board and etch.
    What is everybody doing for drilling the holes for DIP packages? I can never
    seem to get all the holes straight which makes installation of the IC
    difficult at times.
    edited 2003-04-15 16:12
    Paul, what color was the transfer paper you used?
    the same happened to me with a plastic blue sheet, until I found the paper based
    white sheet from DynaArt Designs and used their Superfuser to iron the toner.
    The tricky part is trying to transfer the toner with an iron, you have to test a
    lot to get it right. I paid $300 for the Superfuser, there is a better
    substitute for $150 see:
    http://www.dynaart.com/DTF/E.DTF/E.DTF2.html
    Sent: Tuesday, April 15, 2003 10:11 AM
    > Paul
    > wrote:
    > > Thanks everyone,
    > will
    > > try that out.
    > > -Mike
    > > Hi all,
    > boards.
    > share
    > > Thanx
    > > -Mike
    > Subject
    edited 2003-04-15 16:22
    I have had pretty good success with the "iron on" blue colored special paper
    using a laser jet printer. One trick
    is to wait until the pc board cools down to room temp before peeling off the
    blue paper.
    As for drilling the holes for the DIP packages. I used a cad program for the
    art work.
    For the pads for each pin of the DIP, I used a donut with very small hole in the
    center. This helps the drill bit
    get centered when you start to drill.
    Fred
    > prcoy@y... writes:
    > difficult at times.
    edited 2003-04-15 16:37
    Here are a couple links I have been meaning to try but haven't.
    http://www.fullnet.com/u/tomg/gooteepc.htm
    http://www.beamrobotics.com/library/techniques/buildpcb_trnsfr.html
    http://www.rwc.yertiz.com/pcb.htm
    I have tried using the release paper from a large 'sticker/label' run thru
    a copier (link #3), but it was hard not to smear the design. I use Eagle
    software. I am building a small CNC pcb mill. It has been very time
    consuming but fun and educational!
    http://www.hobbycnc.com/
    http://www.crankorgan.com/brute.htm
    Dan
    edited 2003-04-15 16:38
    > difficult at times.
    I don't have a trick here other than to drill carefully (tough to do
    when you have so many of them).
    Paul
    edited 2003-04-15 17:50
    For simple, 1 layer boards, how about putting the
    components directly on top of the etched copper? The
    traces are drawn in the normal sense instead of
    inverted so you don't have to be backwards to start
    with. The ICs are deadbugged and soldered directly to
    the copper as are the related discrete components.
    Troubleshooting is easy as you can follow the copper
    traces between parts.
    This is something that I have done to save on drilling
    and for low run prototyping.
    > Daylight Time,
    > prcoy@y... writes:
    > results. Out of 20
    > be inked in with a
    > 'finicky' results
    > transparency to
    > difficult at times.
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do you Yahoo!?
    The New Yahoo! Search - Faster. Easier. Bingo
    http://search.yahoo.com
    edited 2003-04-15 17:58
    In a message dated 4/15/2003 9:52:38 AM Pacific Daylight Time,
    kc6pob@y... writes:
    Deadbugged???
    Would I be correct to assume this means you bend the leads of your components
    and turn them into surface mounts?
    edited 2003-04-15 18:22
    Why yes, that's what I assumed.
    > kc6pob@y... writes:
    > Deadbugged???
    components
    edited 2003-04-15 19:21
    These are the Dynrt sheets. not the peel off kind.
    Two solutions to drilling, #1 clamp a perf board (with .1 holes) to
    use as a guide and use #60 (.040") carbide drills (not "high speed"
    type) #2, We have a Dremel drill press bolted to a small 8"x11" X-Y
    table we got from Ebay. altogether came to around $100 but makes
    perfect .1 spaced holes or even .01 if you want to get picky. We plan
    on adding some stepper motors to it later to make a router/drill out
    of it.
    Paul
    > prcoy@y... writes:
    20
    with a
    results
    boards
    MEK.
    the
    good
    you layout
    board, peel the
    can never
    IC
    > difficult at times.
    edited 2003-04-15 19:26
    I haven't heard that term in years!
    It used to be used in the context of having to add an IC to a PC board
    after it had been built. You glued the IC on the board (or on top of
    another IC) upside down (with the legs pointing up, like a DEAD BUG!), then
    wired it into the circuit. The UPSIDE DOWN is necessary to call it
    "deadbug" - if you do it right side up, to copper pads, the bug ain't dead!
    Larry
    >kc6pob@y... writes:
    >Deadbugged???
    Larry Bradley
