(unknown)
radioshack.com has a good auto relay part number 900-2391. I've used this relay
in many auto-related applications. it costs about $5.00.
You could use 1A 5V dc relays, which can switch most things in a car. For
heavier-duty switching, you could use the small relay to drive a larger, 12V
power relay (for the headlights, for example).
I use ones which have a 7-pin DIL configuration, with the 'center' pins
missing.
Cheers,
Mensaje original
> De: Tyson Whitt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HuGmXw1IRGLH3C2vApCp7fpBki-5_38FBiU0KfrlpCXlmDoofmqNr6x2P5qrhFQcIEsmlcaXWnqinuxzUIXQwy4]tysonwhitt@h...[/url
> Enviado el: martes, 18 de abril de 2000 1:24
> Para: basicstamps@egroups.com
> Asunto: [noparse][[/noparse]basicstamps] (unknown)
> Hi all. I am building a security alarm for my car using the
> Basic Stamp II.
> I'm wondering what type of relays (specs) I should use to interface the
> stamp with my auto accessories (parking lights, horn, dome light, starter
> disable). Any info would be appreciated.
> Tyson
> ______________________________________________________
> Get Your Private, Free Email at http://www.hotmail.com
Any and all data regarding this is appreciated.
The motors I will be driving are automotive motors (power windows or
windshield wiper).
The current is about 4-6A.
Thanks a million.
Gary
From: Chris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7vOPll__SCvx29DVWEbE1-wUCLk3_UNBYTM_Ea7PV8O5KMm2xOyYGhy9Z040LwfLW4839pd3kLWaOOc8sg]c_rosney@y...[/url
Sent: Friday, April 21, 2000 4:53 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] (unknown)
Gary,
As far as i can say, you have 2 options.
1) Get an H-Bridge
Two I know of and have used are the L293 and the more powerful L298.
Both run 2 DC motors in either direction, though i'm not sure about
speed control. Sending differnt pulses to the chip MAY change it's
speed, but I'm not really sure. The 93 can handle up to 1.2 Amps,
while the 98 can take 4 Amps but is a little bit harder to use.
Both cost around $5, if you want datasheets, i'll send them to you.
2) Get servo motors.
Servo motors, though expensive, can be controled directly from the
stamp in 2 directions, at varying speeds, no extra driver needed.
The H-Bridge option is much cheaper though.
-Chris
to Bob Blick and his H-bridge circuit. The H-bridge is relatively easy to
build and to control. DO NOT forget the heat sinks when using these
motors. Bob can be reached at:
http://www.bobblick.com/bob/projects/projects.html
Good luck, Gene.
At 05:54 PM 4/21/00 -0400, you wrote:
>Chris,
>windshield wiper).
>Thanks a million.
>Gary
>From: Chris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xCjwdh3Fe_rigQRQpsSdk0of5IQL4IEpo7rDOG7NF9keSN81-yM9WCWrq7dcJZ8qOGrA-xUrpQdFmfw9Zw]c_rosney@y...[/url
>Gary,
>1) Get an H-Bridge
>-Chris
Gene & Sydelle Norris
mailto:enorris@h...
http://members.home.net/enorris
E. Windsor, NJ USA
>how many stamp lines are required for a servo motor?
Only one. You use PWM to control it.
-Chris
Gary Companion wrote:
> Chris,
> windshield wiper).
> Thanks a million.
> Gary
> From: Chris [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RjdlQ2gNb1hVsY2cT4T7a4RdzD1BXdnM9f_hz7-nN2JXolvYbjE7qfCCOBa-A2cuDy3SDJ6YWw9uV37wSw]c_rosney@y...[/url
> Gary,
> 1) Get an H-Bridge
> -Chris
cheap to complex:
a) simple resistor divider to check a voltage treshold (1-2 pin)
b) RC timing to check voltage (1-2 PIN)
c) ADC chip (4 - 5 PINS)
ACJacques
Vince Fell wrote:
> I am using a BSII as a driver interface on a Barbie Jeep.
> Unfortunately there is no way to see the current state of charge in
> the batteries. Any ideas on how to use the stamp to pull this off?
> I am using an LCD display on the Jeep to display other functions
> which could be used to display current battery state.
> Thanks in advance for your advice!
> VF
truly. If you have any specific questions about this technology, I've done
substantial work with this, and as a matter of fact built a 64-segment
sequencer based on a stamp (bringing this back to topic.)
On Mon, 30 Oct 2000, s premena wrote:
> Take a look at electroluminescent rope - 12 colors and
> up to 800 feet long!
> What's the catch? $2/foot and needs high voltage inverter
> to drive it.
> You could wrap separate coils of this stuff around a post
> and light them controlled by your standard VU driver
> chip through special drivers....
> Look at:
> Pocket rainbow and flashing shoelaces... www.playfish.com/coolneon/
> www.elwire.com
> www.coolight.com
> Bunch of other sites mostly for OEMs - here it comes... :-)
> still at $2 per foot it's coming a little slow..
> ________________________________________________________________
> YOU'RE PAYING TOO MUCH FOR THE INTERNET!
> Juno now offers FREE Internet Access!
> Try it today - there's no risk! For your FREE software, visit:
> http://dl.www.juno.com/get/tagj.
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
Also use a large capacitor 1000uF or so to power the Stamp. i.e.
1N???
V+ >---->|
o
> To Stamp +
| 1000uF
o--|(--o
GND >
o
> GND
You might additionally want to place a reverse biased diode across the
transistor as well as the relay.
1K
Signal >--/\/\--o
GND >
o-- E B C --o--> RELAY <--o--->+12V
| 1N??? | 1N??? |
o---->|
o
o
Try placing a 2200uF or so across the HORN terminals
(observe capacitor polarity)
>hello
>i get a stamp circuit that control an relay
>and the relay control a car horn but when conecting
>the care horn the stamp go grazy because of the radio
>interfac of the horn i even used opto isolation it did
>not make much deferens can any one hellp
> C|
RL
> / TR 22222
>stamp pin
b\
> --E--
>please vist stampic the biggest stamp links
>http://www.geocities.com/stampic
>BEST REGARDS
>HATEM RAYA
>Do You Yahoo!?
> >From homework help to love advice, Yahoo! Experts has your answer.
>http://experts.yahoo.com/
Beau Schwabe IC Mask Designer
National Semiconductor Network Products Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
X-eGroups-Return:sentto-1327227-5719-974051196-steves=alphalink.com.au@returns.onelist.com
X-Sender: bkatakis@mindspring.com
X-Apparently-To: basicstamps@egroups.com
Mailing-List: list basicstamps@egroups.com; contactbasicstamps-owner@egroups.com
Delivered-To: mailing list basicstamps@egroups.com
List-Unsubscribe:<mailto:basicstamps-unsubscribe@egroups.com>
Date: Sun, 12 Nov 2000 12:46:25 -0500 (EST)
Reply-To: basicstamps@egroups.com
This file: "INTERNET_SECURITY_FORUM.DOC.pif" was infected withthe: "W95.MTX.dr" virus.
The file was quarantined by Norton AntiVirus. Monday, November 13,2000· 10:10At 12:46 12/11/00 -0500, you wrote:
Go to
http://wwww.antivirus.com
From: bkatakis@m... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tmogmcE7Y-zMZ-johHNBKTnifrBb4_JPviUS393Hszynqpqxddb2-31u-bGP5v_S09mLmpVBUNEXHZoyjl4]bkatakis@m...[/url
Sent: Sunday, November 12, 2000 9:46 AM
Just for your information, you have sent out a virus.
You may want to inspect your computer as you could
have already done damage.
Just thought you would want to know.
Todd
Do You Yahoo!?
Yahoo! Calendar - Get organized for the holidays!
http://calendar.yahoo.com/
To: [url=mailto:undisclosed-recipients:]undisclosed-recipients:[/url]
Sent: Tuesday, 14 November, 2000 04:29
W95.MTS.dr virus.
Be careful!
This file: "READER_DIGEST_LETTER.TXT.pif" was infected with the:
"W95.MTX.dr" virus.
The file was quarantined by Norton AntiVirus. Tuesday, November 14, 2000
07:24
Richard Clemens
clemens@w...
For those who need a free scan/repair, go to the Trend Micro web site via
the following link:
http://www.antivirus.com
Go to home users-> Free Scan
This will fix your problem. For those using MS Outlook, go to the Microsoft
web site and get the Outlook update to protect yourself automatically.
Thanks!
From: ecourt@b... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=i9MRtKfeFqNwgdgO54QmFte76EJLw21-MCYoHaNr6a6jymZ7tJHjad85IGLWyDMOQgfb4qXLXg6hCzFyKQ]ecourt@b...[/url
Sent: Tuesday, November 14, 2000 1:29 AM
To: undisclosed-recipients
It was the son of the virus that I received on the Stamp list 3 days ago.
Many of the list members reacted positively and I followed the idea from
Brian Gillis, loaded the 7MB of PC-cillin, free for 30 days.
I scanned my disk, it corrected or destroyed 25 files.
I hope now that I am clean.
With apologize,
ECO
To: <basicstamps@egroups.com>
Sent: mardi 14 novembre 2000 16:45
Subject: RE: [noparse][[/noparse]basicstamps] (unknown)
> Another Virus has been let loose in this group.
> the following link:
> Thanks!
> From: ecourt@b... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VS4VjZDklGlSnB3r1ainAIKIQFpWyhDvQJ39g3bCgZa9uGesd-YJ5RPk4FcIuu0-dWkMaP4nyAd3R6DB]ecourt@b...[/url
> Sorry for the virus that I not voluntary sent yesterday.
> With apologize,
> ECO
ECO,
Unfortunately, immediately after receiving the above note.....I received a file
named:
WIN_$100_NOW.DOC.pif
Which ALSO contains a virus!!
The body of your message actually contained no text and the subject line was
blank.
Why the attachments???
Rus
Rus Hardy
"Lucky Devil"
Atrophies - Ghoulishly Original Awards & Trophies
http://www.bluedestiny.com/Atrophies/
SpiderBucky & SpiderThrifty - Boney Superheroes
http://www.bluedestiny.com/SpiderBucky/
Keeper of the Bucky-n-Thrifty Flame
http://www.boneyardbargains.com/
"my mind wanders....I'm just along for the ride"
message with an attachment that was probably a virus.
Ray McArthur
Sent: Wednesday, November 15, 2000 11:55 AM
Subject: Re: [noparse][[/noparse]basicstamps] (unknown)
> With apologize,
> ECO
> From: Brian Gillis <Brian@G...>
via
> > the following link:
Microsoft
> > Thanks!
> > From: ecourt@b... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3qGZQjlhXVvUhTR70JjSXYFRAKV-RQTqb9EC4jCZQngxDoCDvrN1hWyWgCBcpr1I0B1Db6B4eQ8c]ecourt@b...[/url
At 12:07 PM 11/17/00, you wrote:
> friends,
> risk.
> Stevenson
> http:www.devvcom/docry.hl
>1928.
> DEMOCRACY
> NOTE
> without.
> CITIZENSHIP
> anarchy
> of
> rights.
> democracy.
> Atwood
> republic."
> General.
> FAIL
> before.
> offensive."
> 25 th
> Meaningless
> Government
> 7012
> 07060
> 753-7347
> ourselves."
> Choosing
>Download NeoPlanet at http://www.neoplanet.com
thermocouple to a stamp? I want to use this as part of a radio telemetry
system to monitor exhaust gas temperature on an R/C boat. Thanks.
Roy Wilmer wrote:
> Dear friends,
> Please read this. I am sorry for this mass emailing and if you wish to remove
> me from any lists I understand. It will for me be worth that risk.
> Ed Stevenson
> Check this out also http://www.devvy.com/democracy.html
> Many of you have seen the reprint of this document. If you have, it's worth
> reading again. If you have not, it is worth reading, studying, and reciting
> to your
> friends, family, and neighbors. It is copied from Training Manual No. 2000-25
> that was published by the then War Department, Washington, D.C., November
> 30, 1928.
> Official Definition of DEMOCRACY
> NOTE
> Here are four (4) facsimile section reproductions taken from a 156 page book
> officially compiled and issued by the U.S. War Department, November 30,1928,
> setting forth exact and truthful definitions of a Democracy and of a Republic,
> explaining the difference between both. These definitions were published by
the
> authority of the United States Government and must be accepted as authentic in
> any court of proper jurisdiction. These precise and scholarly definitions of a
> Democracy and a Republic were carefully considered as a proper guide for
> U.S. soldiers and U.S. citizens by the Chief of Staff of the United States
> Army.
> Such definition stake precedence over any "definition" that may be found in
the
> present commercial dictionaries which have suffered periodical
> "modification" to
> please "the powers in office. Shortly after the "bank holiday" in the
thirties,
> hush-hush orders from the White House suddenly demanded that all copies of
> this book be withdrawn from the Government Printing Office and the Army
> posts, to be suppressed and destroyed without explanation. This was the
> beginning of the complete red control of the Government from within, not from
> without.
> Prepared under the direction of the Chief of Staff.
> CITIZENSHIP
> This manual supersedes Manual of Citizenship Training The use of the
> publication "The Constitution of the United States," by Harry Atwood, is by
> permission and courtesy of the author.
> CITIZENSHIP Democracy:
> A government of the masses. Authority derived through mass meeting or
> any other form of "direct" expression. Results in mobocracy. Attitude
> toward property is communistic--negating property rights. Attitude
> toward law is that the will of the majority shall regulate, whether is be
> based upon deliberation or governed by passion, prejudice, and impulse,
> without restraint or regard to consequences. Results in demogogism,
> license, agitation, discontent, anarchy
> CITIZENSHIP Republic:
> Authority is derived through the election by the people of public officials
> best fitted to represent them. Attitude toward law is the administration of
> justice in accord with fixed principles and established evidence, with a
> strict regard to consequences. A greater number of citizens and extent of
> territory may be brought within its compass. Avoids the dangerous
> extreme of either tyranny or mobocracy. Results in statesmanship,
> liberty, reason, justice, contentment, and progress. Is the "standard
> form" of government throughout the world. A republic is a form of
> government under a constitution which provides for the election of
> (1) an executive and (2) a legislative body, who working together in a
> representative capacity, have all the power of appointment, all power of
> legislation, all power to raise revenue and appropriate expenditures, and
> are required to create (3) a judiciary to pass upon the justice and legality
> of their government acts and to recognize (4) certain inherent individual
> rights.
> Take away any one or more of those four elements and you are drifting
> into autocracy. Add one or more to those four elements and you are
> drifting into democracy.
> Atwood. Superior to all others.--Autocracy declares the divine right of
> kings; its authority can not be questioned; its powers are arbitrarily or
> unjustly administered. Democracy is the "direct" rule of the people and
> has been repeatedly tried without success. Our Constitutional fathers,
> familiar with the strength and weakness of both autocracy and
> democracy, with fixed principles definitely in mind, defined a
> representative republican form of government. They "made a very
> marked distinction between a republic and a democracy * * * and said
> repeatedly and emphatically that they had founded a republic."
> "By order of the Secretary of War: C.P. Summerall, Major General, Chief of
> Staff. Official: Lutz Wahl, Major General, The Adjutant General.
> WHY DEMOCRACIES FAIL
> A Democracy cannot exist as a permanent form of Government. It can only
> exist until the voters discover they can vote themselves largess out of the
> public
> treasury. From that moment on the majority always votes for the candidate
> promising the most benefits from the public treasury with the result that
> Democracy always collapses over a loose fiscal policy, always to be followed
> by a Dictatorship.(Written by Professor Alexander Fraser Tytler, nearly two
> centuries ago while our thirteen original states were still colonies of Great
> Britain. At the time he was writing of the decline and fall of the Athenian
> Republic over two thousand years before.
> "Did I say "republic?" By God, yes, I said "republic!" Long live the glorious
> republic of the United States of America. Damn democracy. It is a fraudulent
> term used, often by ignorant persons but no less often by intellectual
> fakers, to
> describe an infamous mixture of socialism, miscegenation, graft,
> confiscation of
> property and denial of personal rights to individuals whose virtuous
principles
> make them offensive."
> Westbrook Pegler: New York Journal American, January 25th and 26th, 1951,
> under the titles- Upholds Republic of U.S. Against Phony Democracy,
> Democracy in the U.S. Branded Meaningless
> Order original from:
> Americans For Constitutional Government
> P.O. Box 7012
> Watchung, N.J. 07060
> (201) 753-7347
> "This idea that government was beholden to the people, that it had no other
> source of power is still the newest, most unique idea in all the long
> history of
> man's relation to man. This is the issue of this election: Whether we
> believe in
> our capacity for self-government or whether we abandon the American
> Revolution and confess that a little intellectual elite in a far-distant
> capital can
> plan our lives for us better than we can plan them ourselves."
> Ronald Reagan's Speech at the 1964 National Convention: A Time for Choosing
> --X-X-X-X-X-X--NeoPlanet-MIME-TEXTandHTML--X-X-X-X-X-X-X247638611-X-X
> Content-Type: text/html; charset=US-ASCII
> Content-Transfer-Encoding: 7bit
and a couple of LM358's to get instrument quality devices. The 594 is an
expensive chip which provides cold junction compensation and a very linear
output. If you don't need that level of precision, or want to keep the cost
down, I've had fair success with a couple of op-amps and an ADC. Type "J"
will only take you up to 800 degrees F. I believe "K" will go to 1200. If
you check the AD line, I believe there is a chip for each one.
Chris Loiacono
From: Eric Bourlet [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Lvs1KzSvfyaIm7l67wA0FEp16pL8bOez5cG4g3YfqIRo1TmswPEB5wYNxHz0Cop9BKWWmqYOCYKSUbk]ebourlet@g...[/url
Sent: Friday, November 17, 2000 6:45 PM
I need to measure temperatures to around 1200f . Has anyone interfaced a
Have your friend go to www.yahoogroups.com.
Tom O'Brien
to offer a Stamp with a 10/100 RJ45 ethernet connection and program upload
via FTP or similar... they said "not at this time... but would bring it up
at the next engineering meeting".
I'd suggest send them an email asking about it too... obviously if there's
enough demand for such a thing, they will make it.
I suggested to them I'd want a builtin DHCP client so I could just "plug it
in" a 10/100 network.... the serial port idea is easy and simple... but it's
also "old". :-)
To: "Grupo Basic Stamp" <basicstamps@yahoogroups.com>
Sent: Tuesday, January 30, 2001 1:04 PM
> Has anyone connected the BS2 to a ethernet network?
> Alberto Zamora Estrada.
> Phone: (506) 220-6736.
> Cell: (506) 374-3846.
> Fax: (506) 220-8684
> Investigaci
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Beware of the attachment, contains virus.
Regards, Steve
I'm using a Mac. I am impervious to these pitiful viruses :-)
-Chilton
Sure, I haven't seen a virus that runs on a Mac in about 5 years. I
have a pretty massive collection, to be honest, so if you actually do
have one that runs on the current MacOS, I'd love a copy.
-Chilton
Has anyone notified Yahoo ? They may try to spread it in other threads.
Bruce
> -Chilton
bushing on the motor shaft. This could be set up to give you a "wobble"
that can serve the "vibration" effect, and the motor speed could be
controlled by integrating the PWM or PulseOut functions of the Stamp.
Russ Bassani
Sent: Monday, March 05, 2001 9:57 PM
| Thanks, I will have to look for another way
| K-Jay
| Solid state relays are normally full on or off. Furthermore, they are
| usually slow switching and not meant for pulse work.
| Ray McArthur
| Sent: Monday, March 05, 2001 1:59 PM
| Subject: [noparse][[/noparse]basicstamps] Driving a Solid State Relay
| >Can a SSR be driven in such a way to produce
| >a variable voltage output using a BS2.
| >I would like to control a vibrator that's connected
| >to a rail that parts slide on. I need to be able
| >to adjust the "Speed" of the vibrator. Is this
| >possible using the Pulsout or the PWM commands.
| _________________________________________________________________
| Get your FREE download of MSN Explorer at http://explorer.msn.com
