Wireless transmission of data... — Parallax Forums
Once again, things are going obsolete...lol. I have been using Linx products with the Basic Stamp for data transfer for a long time. I recently bought the Linx, now CE connectivity, the TRM-433_LT and could not make it work with the stamp. So, has anyone found something that does work with the stamp to exchange data. In my case, it only needs to be one way, but I would take both.....thanks to all
  • XBee works. You might also look the low-cost LoRa module called the RYRL998.
  • Other possibilities (ESP32 more future proof?)
    ESP-NOW
    ZigBEE
    Denno doesn't seem to want to give up the BASIC Stamp. I'm building an ESP-01 bridge for the P1 and P2 so that I can connect devices via the ESPNOW protocol. I suppose one could do the same with a BASIC Stamp if the interface in the ESP-01 was set-up to deal with the nature of the BS2.
    Yeah, that's what I mean. I have been testing the ESP32 as merely a peripheral. Makes a great Bluetooth device by simply directing the UART to the BT and the code is readily available. :+1:
  • dennodenno Posts: 241
    edited 2025-12-05 22:08
    No, I do not want to give up on the Basic Stamp, or the Propmini. I'll start at the beginning, I wanted to learn programming, so with my first computer, the IBM thinkpad, I bought the book QBasic for Dummies while on my sailboat in the Virgin Islands. Then came along Power Basic, and I started learning that...remember the floppy discs?....Anyways, back around 2001'ish, I started with the Basic Stamp. The program was to tell me the simple ON time versus OFF time of my 12 volt refrig system on the boat. And that was with a DELL computer. Ya, I know, moving forward, boat is gone, and now i'm in Michigan (polar vortex now)...and in this house, and car, I presently have, wirelessly, using LINX products, 12 stamps running for outdoor lighting, and temperatures in my house. Yes, Jon, I too monitor temperatures. I even have 2 stamps running in my car wirelessly for transmission and engine temperatures...I have two Propmini's running the thermostats of both the garage furnace and house furnace. I use a wood burner, also, and I monitor the burner temperature using one of Sparkfun's MCP9600 with a stamp. Last but not least, I have a PING sounding my diesel level with a stamp in the tank for my house furness. In general, over the years, the Basic Stamp and the PBASIC, along with PROPBASIC have taught me a lot of programming. So, Jon, I'm not going to give up the stamp. I just bought 5 BS2's off EBAY. I will start using the XBEE's on my next project. And it looks like all the XBEE's are out of stock at Parallax. Presently, I use a Compaq laptop computer....Window's 7.0.....I don't give up things...That's it! BTW, Buck Rogers , did I spell furnace right this time.....
  • JonnyMacJonnyMac Posts: 9,808
    edited 2025-12-05 22:45
    The upshot with the BS2 and with XBee is that you can employ hardware flow control so you don't miss asynchronous messages (if those are allowed in your system). I am also experimenting with LoRa -- it's low cost and long range. I think I mentioned the RYLR998; you can get a module for Amazon for about $12 and they work down to 9600 baud. The down-side from the BS2 perspective is that they send ASCII strings that you have to parse -- this could be a bit tricky with the BS2's limited memory.
  • As mentioned in a previous post, I am trying to use the Linx transceiver TRM-433-LT with little success. I have in the past used Linx transceiver with with great success and the BS2. Basically, I make temperature readings,remotely, using the LM34 and the LTC1298, A to D converter. Then transmitting this data using SEROUT from the stamp to the TRM-433-LT. My question is how to format the output data from the LTC1298 to the stamp SERIN and then out to the above transceiver in a 8,N,1 format that the TRM-433-LT requires.
    With the other Linx transceivers I would just write the code this way: BAUD is 9600 and for the stamp that configures to 16468
    LTC_cs = 0
    SHIFTOUT LTC_data,LTC_clk,LSBFIRST,[config_volt\4] 'to configure the LTC1286's input selection
    SHIFTIN LTC_data,LTC_clk,MSBPOST,[temperature\12]
    LTC_cs = 1
    temperature = (temperature */ Cnts2Mv)/10 ' Convert To Millivolts and divide by 10 for whole degree
    Then using that temperature reading, SHIFTOUT from the Stamp to the transceiver using the 8,N,1 format...
    Thank you for your time
    I just wanted to add that I was able to get (2) TRM-433-LT's to transmit and receive back and forth to two different stamps. And, if anyone has a BS2sx that they would l8ke to sell, please let me know.
    Thank you..
  • @denno
    Actually yes you did on #6, with the last line. So I won't gripe over bringing over an excellent actress and consumer reporter into this. And I might add that description is quite impressive.
    As for your BS2SX question, ping me on the PM portion of the board in about four days, please.
    Mascots not interested.
    Thank you..
    And I checked my collection a while ago. That is one individual which is not part of them.
  • denno, sent you a PM, I believe I can help you out with several items.
    edited 2026-02-12 22:32
    WBA consulting...not sure where to find PM on this sight. Have looked around...thank you...opps, I found your PM....lol
    Scroll to the top and look for an envelope icon. Click on that to get your DMs.
    edited 2026-03-11 00:30
    I just recently acquired a PWMPAL made by Parallax. I can't seem to find a pinout for it or any example code, #28020. I did find/read on the forums by JonnyMac, but no pinout or documentation. Material was dated around 2003. Gosh, I'm getting old, seems a lot of "thru the hole" components are going obsolete, lol. Thank you and please, no ZIP files, as my computer simply will not open a ZIP, and I've tried to sort it out..
    edited 2026-03-11 02:28
    Found this with a generic web search (I think I wrote it while I worked at Parallax).
    -- https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/9/28020.pdf
    It has code examples, but no schematic. There is a table of pins used -- maybe that's enough.
