soic-20 chip size — Parallax Forums
soic-20 chip size
jdoleckijdolecki Posts: 726
edited 2023-01-16 04:07 in General Discussion
Are all chips labeled soic-20 the same size foot print on a circuit board?
I have an old chip I cant find a drawing for.
  • VonSzarvasVonSzarvas Posts: 3,639
    edited 2023-01-16 08:29
    Almost Yes. Check the IC width matches. Whilst the length and leg-pitch will follow a standard for SOIC-20, some ICs can have 2 or 3 width options.
    And for assembly the plastic body can vary in length, so keep enough space on your PCB based on your actual part, and not the dims from a generic footprint.
  • Having opened the datasheet I can see there's no packaging info.
    In those cases, the manufacturer will most-always have that info at their website.
    https://www.renesas.com/eu/en/support/technical-resources/packaging
  • evanhevanh Posts: 17,326
    Man, they don't make it easy. Best I found from Von's link was https://www.renesas.com/eu/en/document/unknown/982306 Extracting page 35 gives the attached.
  • thanks everyone
  • jmgjmg Posts: 15,200
    Usually :)
    The most common, by far, is the 0.3" wide package, often called SO20W, or SOP20L
    This from a CAD package list
    geda_SO20W:SO20W:SO20W:Small outline package, wide (300mil)
    but there are also less common
    geda_SO20M:SO20M:SO20M:Small outline package, medium (200mil)
    geda_SO20N:SO20N:SO20N:Small outline package, narrow (150mil)
    I've seen some MCU's offered in the SO20N, (which becomes a simply longer SO16N), but the TSSOP20 seems to be the
    most common 20 pin gull wing package in 2022/2023
    Digikey also gives info on that FCT807 part :
    74FCT807BTSOGI ... Surface Mount. Package / Case. 20-SOIC (0.295", 7.50mm Width). Supplier Device Package. 20-SOIC
