P2 Edge power input question — Parallax Forums
What is the maximum voltage that can be supplied to the P2 Edge card? I have read the spec sheet and just want to make double sure 12v is OK.
  • roglohrogloh Posts: 6,363
    edited 2022-08-03 06:23
    The original P2-Edge's were designed to be run with 5V, but this has increased to a higher value in the later versions, so be just careful as to which board version you are using.
    Eg, the silkscreen labeling on my REV A P2-EC board says 5V for VIN, while the P2-EC32MB REV A says 5-16V . I still run both at 5V though.
  • P2-EC Rev C and D should be OK with 12v, Correct?
  • Check the silkscreen label on the board or find the schematic for those. I don't have those boards here.
  • RevB, C and D are all 5-16V range.
    Your 12V supply will be totally fine.
    Perfect! Do we know if this is going to be the standard moving forward?
  • evanhevanh Posts: 17,203
    The breakout carriers kind of need an update to match this. The direct 5V feed to the accessory headers are dangerous to the add-on boards as is.
