P2 WAITCNT — Parallax Forums
P2 WAITCNT
Hello,
this command does not exist in P2.
How can I recreate this on the P2?
  • I believe this has been replaced with WAITX.
  • pic18f2550pic18f2550 Posts: 400
    edited 2021-03-04 11:10
    If I read the description of "WAITX" correctly, you can stop the COG by n CLOCK pulses.
    I have to start a program loop, with different length, but always at the same time.
    This was no problem with WAITCNT because a value was simply added to the counter.
  • AribaAriba Posts: 2,697
    WAITCNT is now called WAITCT1..3 in PASM and you use it together with ADDCT1..3. So you can handle 3 different time periods.
    It's all described in the documentation (see chapter: Events)
    In Spin2 it's just WAITCT().
    Andy
    See the p2 tricks and traps reference thread for p2 replacement code
  • Thank you.
  • JonnyMacJonnyMac Posts: 9,787
    edited 2021-03-04 21:20
    As the waitct? instructions do not reload the timer, you have to use addct? first.
    pub blinker(pin, count, hitix, lotix) | t
      org
                    getct     t
    .loop           drvh      pin
                    addct1    t, hitix
                    waitct1
                    drvl      pin
                    addct1    t, lotix
                    waitct1
                    djnz      count, #.loop
      end
  • How does waitcnt behave when the time is up?
    The code is processed without interruption and the associated flag is cleared?
    In the example, I simply want to limit the repetition rate to a maximum value.
    Falling below this value is not a problem.
    CON
      _clkfreq = 20_000_000
    pub blinker(pin, hitix, lotix) | t
      org
                    jmp       #.go
    .loop
                    '' routine unbekannter länge
                    '' der zeitbedarf ist unter oder über hitix
                    waitct1
    .go             getct     t
                    addct1    t, hitix
                    drvh      pin
                    '' der zeitbedarf ist unter oder über lotix
                    waitct1
                    getct     t
                    addct1    t, lotix
                    drvl      pin
                    jmp      #.loop
      end
  • evanhevanh Posts: 17,163
    Yes.
                    waitct1
    .go             getct     t
                    addct1    t, hitix
                    waitct1
                    getct     t
                    addct1    t, lotix
    Correct use of recurring GETCT. It starts a fresh timeout each time.
    edited 2021-06-29 12:06
    Since the variable t is reloaded each time overflow occurs,
    the values hitix and lotix should be set to 2 less.
    Then everything should fit.
    I wouldn't bother unless it costs nothing. It won't be consistent upon overruns.
  • I think JNCTx could replace WAITCTx if
    (a) absolute precision is not needed
    (b) waits must be interruptible.
    Replace
            waitct1
    with
    .loop       jnct1   #.loop
    Am I correct?
  • A background is the runtime monitoring of several program pieces.
    This should already be accurate.
