Reading the output state of a smartpin — Parallax Forums
Is it possible to read back the current logical state of a smart pin? I need multiple PWM output pins where the Y values are written by cog A. With a second cog B I'd like to process analogue feedback. I have to establish a blanking time when the ADC input samples are ignored for several µs after a state change of a PWM output to suppress switching noise and to allow settling of the SINC filters.
My idea was to monitor the PWM pin states and compare them to their last values in my ADC polling loop. If the states differ I set a counter and the next N values are ignored. However, this doesn't work (directly) because for smart pins the IN value reflects the event bit and not the pin state. Is there a possibility to bypass this without wasting an extra pin (and use the -3..+3 source selector)?
I need many pins, 4 PWM and 4 ADC pins per motor for each of 4 motors means 16 PWM and 16 ADC pins. Wasting another 16 for feedback is something I'd like to avoid. I could "emulate" the PWM counter and calculate the transition times in software but that doesn't look "smart" at all.
  • RaymanRayman Posts: 16,225
    The source selector would work
  • But it requires an extra pin? If not, how can I read the pin state? Not via INA/INB or TESTP because theese show the event flag "period completed" instead of the actual pin state, don't they.
    Normally, an I/O pin's output enable is controlled by its DIR bit and its output state is controlled by its OUT bit, while the IN bit returns the pin's read state. In smart pin modes, the DIR bit is used as an active-low reset signal to the smart pin circuitry, while the output enable state is controlled by a configuration bit. In some modes, the smart pin takes over driving the output state, in which case the OUT bit gets ignored. The IN bit serves as a flag to indicate to the cog(s) that the smart pin has completed some function or an event has occurred, and acknowledgment is perhaps needed
    A counter, updating at each base period, counts from the frame period down to one, then from one back up to the frame period. Then, Y[15:0] is captured, IN is raised, and the process repeats.
    Yes, you need another pin.
    But that one pin could cycle through its six neighbors
    It is kind of unfortunate that a smartpin is blind to itself
    In my mixed signal scope example, there are six digital channels shown. Three are in NCO mode and three are spying on these NCO neighbors
  • Ok, I see. Then I have bad luck because I've already finished layout and board assembly. The four PWM pins for one motor have consecutive numbers so I can't reach them all with only one extra pin.
    Then I have to pre-calculate the blanking windows and run a software counter to track the PWM state. Shouldn't be too complicated although I have hoped to get rid of that cycle-counting with the P2 smart pins.
    Thanks, Rayman.
    I saw mention of interrupts in your other thread...
    I'm not exactly sure what would happen if you set interrupt on state change of a pin that is in smartpin mode...
    I'd guess it wouldn't let you track the actual state of the pin, but hard to say...
  • Yes, I remember somebody has drawn a very big and detailed schematic of the smartpin logic with all the muxes and signal routings. But as often, I can't find it. It's not in the "Smart Pin Supplementary Documentation" by Jon Titus. With that schematic it should be possible to find out if there's a signal path to readback the pin state or not.
    But anyway, it's also possible to predict the PWM state change with a simple counter. There are 32 ADC samples per PWM frame. For demodulation of the AC signal I have 3 possibilities based on the compare result of the sample number (n) and the PWM value (v=y<<8) reduced to 5 bits:
    a) sample is before state change (n-v < 0): add to bin0, c0++
    b) sample is in the blanking window (0<=c-v<3): ignore
    c) sample is after blanking window (n-v>=3): add to bin1, c1++
    The final result is (bin0/c0) - (bin1/c1) with c0 = number of samples in bin0 and c1 = samples in bin1. That only takes several assembler instructions, probably even less than reading the pin state and compare to the last state.
  • I've found the "Smartpin diagram" thread:
    http://forums.parallax.com/discussion/171420/smartpin-diagram-now-with-p-p-bit-mode-table/p1
    But it's not the diagram I meant in the last post, there was an even bigger and more detailed one somewhere.
    Chip, can you hear me?
    We need a P2 data sheet! A real one with ALL the information.
  • edited 2020-12-23 19:25
    ManAtWork wrote: »
    It's my opinion that the last person you would want to write the data sheet is Chip. Most of the what he knows about the P2 is obvious to him so he would be unlikely to relay information in a way that most people would understand. Just look at most of his demonstrations.
  • evanhevanh Posts: 17,163
    ManAtWork wrote: »
    I have my guessed logicsim diagrams at end of that same link - http://forums.parallax.com/discussion/comment/1495168/#Comment_1495168
    There is also Chip's block diagram he compiled direct from his schematics of the I/O pad ring - https://forums.parallax.com/discussion/comment/1494131/#Comment_1494131
    edited 2020-12-24 07:39
    ManAtWork wrote: »
    ... However, this doesn't work (directly) because for smart pins the IN value reflects the event bit and not the pin state. Is there a possibility to bypass this without wasting an extra pin (and use the -3..+3 source selector)?
    No, when a smartpin mode is selected, with M > 0, then IN always shows the smartpin event state. You can only then use a nearby pin input to observe the logic level of that physical pin.
    PS: This is indicated in Rayman's block diagram with the M == 0 dotted line inside the smartpin block.
    PPS: Maybe the dotted line should have an arrow head added to it.
  • Ok, I see. Thanks for the clarification.
    Then I have to do it with the counter and comperator method. I'll try that.
