What to do with my FPGA boards? — Parallax Forums
Ok, my P2V FPGA boards are completely worthless to me now...
What to do with them?
Should I save them for P3?
  • Hi,
    You should do projects of your own. An FPGA is never worthless. :)
    Kind regards, Samuel Lourenço
  • RaymanRayman Posts: 16,221
    Well, when P2 was taking forever to complete, I actually did start to learn FPGA.
    But, I found it to be very tedious...
    I'm glad P2 saved me from that...
  • P3...
  • evanhevanh Posts: 17,163
    A hobby is all about the community. That never dawned on me for a long time.
    Doing a FPGA design without a specific job for it to do would be a very lonely exercise.
  • cgraceycgracey Posts: 14,297
    Hold onto those boards. They should be getting some more use in the future.
  • jmgjmg Posts: 15,200
    cgracey wrote: »
    That sounds ominous !!
  • Rayman wrote: »
    Isn't the Parallax FPGA board called the P123? I think that was intended to mean it could be used for P1, P2, and P3. Keep your board!
    Lol, I don't Chip is implying a prop3 just yet. I'm guessing more models of the prop2 once the money is rolling in. Namely smaller ones and maybe without a thermal pad.
  • After more urgent matters have been dealt with, an enhanced version of XORO32 with a new option for 32-bit equidistribution is one of the things that could be tested on the FPGA boards.
    TonyB_ wrote: »
    Super!
  • This "keep hold of boards" makes me happy.
    Best visit Ken and stock up on goodies. Looks like the ride is not over.
    And how awesome will it be to have P2 chips while making derivative ones?
    Thanks Chip. Ken. Seriously. Tonight, I am banging on what we believe to be viable production. I have been telling everyone I can.
    Now... I forgot stuff. Lol. There may be questions needed to backfill brain cells overtaxed as of late.
  • Chip made a 2 cog image that we couldn't quite get to work at the time, and didn't want to bug him given the critical path.
    The theory was that this image would run native micropython (or erics micropython) significantly faster, due to the more frequency hub accesses
    edited 2019-11-21 11:40
    There is a fixed minimum of 9 clocks to fetch from hubram. The only part that changes is the variable 7 extra becomes variable 3 extra for a 4-cog prop2.
    EDIT: Although, maybe that could be a focus of optimisation for the smaller models.
  • TonyB_TonyB_ Posts: 2,275
    edited 2019-11-21 14:46
    evanh wrote: »
    Is a delay of 9 clocks really needed for a random read, when no further read * is wanted from the next address?
    * excluding extra read cycle when crossing hub long
    Yep, that's the design as it stands. Just like all the stages for I/O, to get good sys-clock speeds required many stages into and out of hubRAM too. There is 16 processing blocks (8 cogs and 8 FIFOs) that can each address hubRAM for either reading or writing. And in the middle is the eggbeater that can feed all 8 hubRAM buses in parallel on every sys-clock.
    Maybe it's possible to be improved upon, dunno.
