New streamer ADC input modes — Parallax Forums
I was thinking how we can stream data out DACs, but not ADC data in. I will augment the streamer's WFxxxx modes to sum IN data from ADCs, so that we can have automated high-speed data acquisition.
Streamer WFxxxx new modes sum ADC signals and write them:
WFLONG
8 ch into 8 nibs, up to 15 clocks per sample
4 ch into 4 bytes, up to 255 clocks per sample
2 ch into 2 words, up to 65535 clocks per sample
1 ch into 1 long, up to max clocks per sample
WFWORD
4 ch into 4 nibs
2 ch into 2 bytes
1 ch into 1 word
WFBYTE
2 ch into 2 nibs
1 ch into 1 byte
  • cgraceycgracey Posts: 14,280
    edited 2018-10-27 08:54
    At 225MHz, the 8-channel mode could convert 8 ADC pins into concurrent 4-bit samples at 15MHz. Or into 3-bit samples at 32MHz.
  • jmgjmg Posts: 15,194
    So this is like an ADC DMA, where the COG 'sets and forgets' ?
    Does this auto-wrap ?
    jmg wrote: »
    Yes and yes.
  • nifty!
    I don't think we'd need a 32-bit sum mode. 16-bit would be the practical limit.
  • This is DELUXE! I imagine some interesting DSP like things.... delays and reverbs will be trivial.
    I think it could digitize NTSC in the background. I wonder how decent it would look played back.
    Imagine if we had flash converters in every pin. High speed data acquisition would really be fantastic.
    edited 2018-10-27 09:10
    I wonder, if we even had 4-bit flash converters, what higher resolution we could achieve through oversampling.
    cgracey wrote: »
    Does it cost much to add 32b ?
    I've got some external integrator ideas, that should push well past 16 bits ... (P2 is purely digital)
    In this case, the capture result would need to stream, but I think that's the same pathway as ADC ?
    jmg wrote: »
    cgracey wrote: »
    Yes, the stream comes through the IN bit.
    re-reading these 2 posts
    cgracey wrote: »
    cgracey wrote: »
    WFLONG
    I think that's saying the 32b capture is already in there ? In that case. I'd keep it, for > 16b cases, even if all 32b are not useful, more than 16b could easily be.
    edited 2018-10-27 09:52
    cgracey wrote: »
    This means doing some redesign at the level of the pad ring, or I'm losing something?
    At the present design (the one we already have), have you resorted to any ONC18: G/MS available Deep N-well features, for noise isolation at the most sensitive analog areas?
    jmg wrote: »
    cgracey wrote: »
    cgracey wrote: »
    WFLONG
    I will implement the 32-bit mode, also.
    edited 2018-10-27 17:15
    Yanomani wrote: »
    cgracey wrote: »
    At the present design (the one we already have), have you resorted to any ON C18: G/MS available Deep N-well features, for noise isolation at the most sensitive analog areas?
    Each pad has one giant deep N-well for all the 3.3V circuitry. I wonder if it would be good to divide that wells up, in order to isolate things like the ADC.
  • this may make it possible that one COG streams Data in the HUB another COG manipulates it and a third could stream it out continiously?
    Or is there just one streamer for all COGs?
    curious,
    msrobots wrote: »
    curious,
    Every cog has a streamer.
    edited 2018-10-27 19:24
    Roy is right, DELUXE!
    Chip, I was right. Amiga of microcontrollers. The stuff people are going to do with this thing! (I got plans, who doesn't?)
    Can't wait to see all that happen.
    Re: super fast 4 bit oversampling. From what I read, doing that needs some white noise, and or imperfection in the ADC to actualuze improved resolution. There has to be something to average.
    cgracey wrote: »
    WFLONG
    Thinking about uses for this, those 'up to' mean you could stream bytes, but have 5 or 6 valid bits, with 32/64 sysclks pacing ?
    How does the ADC itself behave at these high sample rates ?
    It seems there will be some slew-rate spec in there, meaning you cannot take 2 x 4 or 5 bit samples, and expect them to read opposite rails instantly.
    That slew will be C-sample and Current Source related.
    What is the low-bit-numbers slew rate ?
