Windows 10 Upgrade Out of User Control — Parallax Forums
cgraceycgracey Posts: 14,320
edited 2016-03-07 17:18 in General Discussion
I knew this was coming:
1226 x 799 - 64K
«134
  • Oh, how helpful! They're letting you choose :D
  • I already updated to Windows 10 which caused me to update to Linux Mint :). I did keep Windows 10 as a dual boot so I can play some Windows only games. I also shut up Cortana on my Windows 10
  • cgraceycgracey Posts: 14,320
    edited 2016-03-07 18:16
    Seairth wrote: »
    I clicked the 'X', for now. Thanks for that link. It seems there are several ways to inhibit the upgrade there.
  • RaymanRayman Posts: 16,423
    edited 2016-03-07 18:32
    Win10 is actually pretty good.
    But, whatever you do, don't pick "Express Settings" when installing.
    If you do, everything you type goes to Microsoft... (and a lot of other info).
  • Rayman wrote: »
    I think all my info went to some little shop of horrors in India with a hand written sign over the door "Windows Technical Support". Every so often they call me and tell me my computer will crash very soon.
  • Had that tech support calls also on win 7. On win 10 I have issues with Quartus and my fpga not showing as a com port.
  • I've been ignoring that offer on a machine in a dental practice I do support for for months. It goes away but always comes back with a little more insistent language. A lot of the proprietary dental/medical software is quite sensitive to things like OS version updates - been there already and don't want to go back to the scenario of tens of thousands of xray images being completely unavailable due to the licensing server being a bit touchy about such things... No fun.
    -Mike
  • It's a warning, Chip. Wrap up P2 development, before you lose control of your computer.
  • Rayman wrote: »
    Agree with Rayman, I like Windows 10. It's much better than 8 or 8.1 (and even 7). Also, definitely do not do express install. You need to be able to tell it not to switch everything to MS apps and enable a bunch of Smile you don't need. Plus, absolutely turn off peered updates.
    For me, pretty much everything is faster on 10 than it was on 7.
    edited 2016-03-07 23:11
    Windows 10 install reminds me of a scene from Ferris Bueller :-)
    I upgraded to W10. I must say I do like it. I have done most of the simple turn off reporting to base.
    BUT, you cannot prevent it upgrading when it wants :(
    My internet is via cellular mobile and hotspot. Last month W10 did an upgrade of about 3GB. I was at my download limit when the upgrade occurred. Bingo... $30 in over-limit download fees :(
  • BeanBean Posts: 8,129
    It is very easy to stop Window 10 from updating automatically. Just set your network connection to "metered".
    Tubular wrote: »
    That's kind of what I was thinking, actually.
  • Some years ago I worked on digital signage projects. Glad I don't, now, because I can imagine the failures, just like this...
    http://www.smh.com.au/technology/technology-news/not-genuine-windows-embarrassing-tech-snafu-in-melbourne-cbd-shopping-centre-20130121-2d23d.html
    Here's some more in the same vein. I'm not sure I like autotellers/atms running windows
    http://pcfailures.tumblr.com/
  • Port the Parallax compatible IDE and Scribbler GUI to Windows app and use it to your advantage.
    Thanks Bean and Roy. Done!
    One step closer to just using a P1... Compiling on P1 now running with my OS and FAT32 :)
  • Roy, Cluso99:
    In Win10, Have you seen any issues or differences with drivers? Can you still easily setup and change network settings? I've noticed a trend in Microsoft to 'hide' these things as Windows advances.. (Company IT dept says NOT to upgrade company machines, over these concerns.)
    I'm not a Windows fan, But I'm looking for the next upgrade that might last as long as 2000, or 7..
    Free, and worth every penny comes to mind..
    rabaggett,
    I know what you mean.
    However Windows is most certainly not free.
    I considered I had no choice as the laptop came with Windows 8, but immediately upgraded to 8.2. W10 is superior to W8/8.1. I still use XP on other laptops and I run an old program that will not run on W10 64bit.
  • I purchased a Dell XPS15 i7 with 16GB RAM a few weeks ago and tried to install Linux Mint but there was some problem with recognizing the 512GB SSD so I gave up temporarily as I had other issues to worry about. Anyway it is running Win10 and I don't mind it too much, well after I replaced the File explorer with Clover so I could use multiple tabs and a few other tweaks anyway. The thing is that this machine has a 4K touchscreen and when I do boot Linux it doesn't support touchscreen gestures and all the fonts are incredibly tiny etc. At least with W10 I seem to be able to use it well enough and of course I also installed Chrome, FIrefox, DipTrace, TeraTerm, Protel, BST and Prop tool etc.
  • Download and run the GWX Control Panel - it can remove and disable the Windows 10 upgrade - Do a Google search
    http://ultimateoutsider.com/downloads/
  • Great app, Ron! Thanks for the link.
  • I haven't had any issues with drivers or network stuff. I run Win10 Pro on 3 machines.
    Note: I don't really run any old or ancient applications. I also update windows and my drivers fairly often.
  • Can this thread be moved to General?
  • If Chip give his consent, this thread can be moved.
    Go ahead, Courtney.
  • I recently purchased a laptop that had Windows 7 Pro on it with a free upgrade to 10 available. Since my other systems have 7 Pro and XP Pro, I decided to let the upgrade run. So far no complaints. A slight learning curve but not too bad.
    Right-click on the start button to get access to almost settings you want...
