Howdy, how do I switch to "Project view"? reading the manual but the options seem different than what the manual says, I'm running SimpleIDE 1.0.2 (RC2)
This is a link to the SimpleIDE's manual, on page 14 there's pictures of the "project view" and "simple view" and I want to go from simple view to project view
You actually need to do this in two steps. First, go to "Tools -> Properties" to bring up the properties dialog. Choose the "General" tab and click the option in the lower right for "View Mode" (see attached image). Once you've done that, THEN you'll have the option to set project view mode in the tools menu. It's overly confusing.
I think Parallax designed the view mode setting this way to prevent novice users from accidentally enabling project mode. They feel that the project mode will confuse novice users, and they may be right.
Jason, thanks for posting the instructions to set project view. I wasn't aware that SimpleIDE could be set so that it comes up in project mode on startup. I've always had to hit the project view button after starting SimpleIDE. This will save me from having to do that now.
http://learn.parallax.com/sites/default/files/content/propeller-c-reference/landing/SimpleIDE-User-Guide-9-26-2.pdf
and SimpleIDE 1.0.2 (RC2)
Look in the tools menu. It should say "Set Project View" if you're in Simple View (page 10 of the user guide).
I already did that and that option isn't available, that's the weird part!
That was it, Thanks! : ]
Jason, Thanks!
That is confusing.
Forgot all about this thing. It used to ask for a password
