ECE388 Embedded Design Project
A group member and I are creating a magnetic door security system. I know theres many out there and ours will probably function no different. We have a magnetic card reader that outputs is a PS/2 interface. We then have a PS/2 to Serial converter. The serial then goes into our microcontroller (P8X32A). This then will check memory and see if the information on the card matches whats in an offboard EEPROM. If the data matches, an accuator is given power for x amount of seconds (hence simulating the door unlocking for x amount of time). The only thing i seem to be really worried about is how will we be able to read in the serial on the I/O pins 1,2,3? The converter has an inturrupt pin that goes off 5uS before the signal transmits. Any suggestions?
Below is the website for the converters and a schematic that is made (not the final version if changes need to be made):
Magnetic Card Reader:
http://www.adafruit.com/products/854
Converter:
http://www.adafruit.com/products/1136
Microcontroller:
http://www.parallax.com/product/p8x32a-d40
Card_Scanner_Schematic_2.pdf
Converter:
Microcontroller:
You can use this to simplify connections
-- http://www.parallax.com/product/28060
The advantage of going this route is you get to see what's coming from the reader -- not what's being filtered by the PS/2-to-Serial interface.
Basically, you can use any pin for serial data, (I would stay away from 28-31 though). Using the FullDuplexSerial or FullDuplexSerialPlus Objects, (found in the Propeller Tool "Library" folder, you assign the pins when you start the object.
Welcome to the forums!
Thank You! That's what I was thinking but wasn't sure because I'm fairly new to how serial data transmits and how to get the chip to sync with the clock of the converter. I know the basics but without the devices (we order them this week) I can't figure out a way to read the data. But knowing for sure any pin can be a serial input pin makes me sleep better at night lol.
The device description is here:
The clocked data port is a three line connection to the host microcontroller which includes an
interrupt pulse, serial data, and an active low ~100KHz clock pulse train. A single byte is sent
to the serial port and then to the clocked data port on the “make” of every keystroke. A serial
to parallel shift register can be used to capture the clocked data from the E1115B. The INT*
signal can also be used to indicate that the data has finished being loaded into the shift
register.Each clocked serial data bit time is approximately 10 usec. The data is output with the most
significant bit first and the output is inverted. Note that either the rising or the falling edge of
the SCLK can be used to clock the SDAT into a shift register as the SCLK edges are 3.3 usec
inside the bit period.
So for the IC I have:
P(0) tied to inturrupt
P(1) tied to SCLK
P(2) tied to SDat
I do NOT have any budget left to buy shift registers, and I have tried many many different example programs from the website. I have the PDF of the book on SPIN and I am still stuck. The main problem I'm having is reading in the clocked data at the right time/ being able to get the data that is being pushed out of the E1115B. (its a PS/2 -> Serial Converter).
If you insist on using the converter you can use one of the I2C objects to read the data via SCLK and SDat or use one of the serial objects to read the same data using the TX and RX lines. In both cases you will also need a ground connection between the converter and propeller board.
Anyway, the converter has 2 options..
1. output a serial character
2. output a clocked serial character
The first option will be the easiest. Just connect the TXD and GND connections.
DR (pin 4) should be linked to 3v3 (pin 8) for 115,200 baud.
There are no interrupts in the propeller chip.
Use FullDuplexSerial and start with
fdx.start(1,-1,0,115200)
1 assumes that the RX is on P1 (port 1 not pin 1 where the prop has ports 0..31)
There is no TX output from the prop so use -1 to indicate this.
The "0" means TTL
115200 for the baud (FYI baud rate is incorrect as baud implies bit rate).
There is a demo for using FullDuplexSerial (FDX) that comes with PropTool.
Perhaps an easy way to get this tested is to run the FDX demo and ensure it works - anything you type on the terminal program (F10 from PropTool) you echo back to the terminal via software in the prop.
Next, change the demo program to use the input port for your reader & converter rather than P31.
You now should see the characters being sent to your terminal.
If I haven't explained this fully, or you have other problems, just ask. There is lots of people just waiting to help you.
