Anybody know of ...
Hello:
Does anybody know who would manufacture a Prop board identical to the center of the Parallax "Propeller Proto Board"?
That is the square center of the board that contains the Prop chip, reset button, 64k flash and a crystal with the pins just connected to the 0.1 inch pitch holes.
I could by the board and try and cut out the middle but that is messy.
cheers,
rich
cheers,
rich
Tubular's Underbelly also uses this same pin layout. I'm not sure if Tubular sells his Underbelly boards.
The mini is nice but i can never understand wasting I/O pins by not bringing them out.
cheers,
rich
Yeah, several of us used to cut down proto boards for that inner square.
I eventually made up a self contained square that adds a regulator and microSD and 8 leds on the vga pins inside the square. That's what you see in my avatar (front side).
On the back of these boards there's a set of C3 compatible memories - srams, flash, a second microsd
as per this thread (good memory, Duane)
http://forums.parallax.com/showthread.php/129292-quot-Und3rb3lly-quot-Upgrading-the-Propeller-Proto-Board-to-C3-style-memory?highlight=und3rb3lly
Its on the smorgasboard, I think, but I have a few variants if you tell me more about what you're doing.
I am not totally sure what you are looking for, but it seems like one of the products mentioned might be a good fit.
Same pinout as the DIP40 Propeller, but includes the crystal, EEPROM, and programming header. Even better when paired with a PowerTwig.
Any one want to put design the center of the dev board and i will pay or the fabrication?
cheers,
rich
It has a board from Cluso, WBA and myself on there, and heaps more. My underbelly board brings all 32 i/o out the same way as the center of a proto board. You only need to solder the prop, eeprom, regulator and reset button if thats what you need. Things like leds, uSD socket, and all the stuff on the back is in parallel with those 32 broken out i/o pins, so they're optional.
