Reset issues on DE0-Nano/DE2-115 — Parallax Forums
ozpropdevozpropdev Posts: 2,793
edited 2014-08-09 09:53 in Propeller 1
Hi P1 FPGA hackers!
I have successfully loaded my little Nano FPGA with the P1 core. Works great!
Loading my propeller program works only once from the Prop Tool.
Any attempt to load code after the first load fails. Even F7 Identify hardware fails.
A reboot in software doesn't help. Even tried toggling DTR from PST with no effect.
Only way to fix the problem is to power cycle the nano and all is good again.
After a power cycle F7 works as many times as you like. Even toggling DTR from PST works.
As soon as I load ram from prop tool , reset becomes inactive after that.
Rich was having the same issue I see.
Apart from this it works great! :):):) Thanks Chip!
Any ideas?
Cheers
Brian
  • TubularTubular Posts: 4,740
    edited 2014-08-07 22:51
    See mindrobots thread about adding an eeprom to fix this
  • ozpropdevozpropdev Posts: 2,793
    edited 2014-08-08 01:30
    Looking at the issue a little closer I have found the following.
    The issue seems to be related to P30 TX and the prop plug.
    Using the DEMO spin code - FullDuplexSerial_test2.spin the fault can be replicated.
      'start the FullDuplexSerial object
      serial.Start(31, 30, %0000, 9_600)                    'requires 1 cog for operation
    If the above configuration is used prop tool will fail on "Load RAM" after the first use.
    Changing the TX pin to 20 instead of 30 for example fixes the reset problem.
    I will attach an EEPROM later tonight and see if this is boot loader related.
    @mindrobots
    Rick,I see you have a eeprom fitted now. Can you try the above spin code.
    Cheers
    Brian
    edited 2014-08-08 04:20
    Brian,
    I went to run your program and now, I'm seeing strange things. I probably was seeing this yesterday since I did mention reset issues in a previous posting but thought it was just not having an EEPROM.
    I went into Propeller Tool do do an F7 on the running Nano and:
    Propeller Tool took forever to start up - to the point of Windows labeling it as "Not Responding". When it did finally start, F7 would cause a reset and then tell me my Prop wasn't there. But it did successfully reset back into PropForth which it read from the EEPROM. F7 would not ID the chip and kept resetting. I need to find a Prop board in my collection that uses a PropPlug to test that behavior on a real Prop - I don't recall it acting like that.
    The forever startup is frustrating - I need to test that. I also need to reboot my laptop, it's been a while and it is Windows, after all.
    I'll certainly be doing more testing with this!
    As to your issue, I'm able to duplicate it also. (Quite accidentally this time)
    I went into Propeller Tool with a freshly powered up and F7'd Nano and loaded the PST demo. It worked but I realized I had the crystal setting wrong from previous testing. I changed the code, saved it and hit F10 and Propeller Tool told me there was no prop there. F7 says there is no Prop there.
    Power off Nano - Prop Tool goes into "Not Responding" (This may be a local PC issue)
    Wait for Prop Tool to get back to normal
    Power ON Nano -
    F7 finds a Prop
    F10 loads PST demo without problems and demo works
    F7 - NO PROP FOUND
    F10 - NO PROP FOUND
    I'm guessing my Nano w/ EEPROM shows similar results except that it does appear to boot back into the EEPROM code. As it sits, I have no way to reprogram it since it is no longer recognized by the Propeller Tool once it resets into PropForth on the EEPROM - This is NOT NORMAL, I reload/reprogram PropForth onto a running Prop all the time.
    Now, I'm off to reboot, have some breakfast and find a Prop board without USB so I can do some side by side testing.
    edited 2014-08-08 04:35
    Thanks Rick. :)
    That sounds exactly what I am seeing here. Hmmm...
    I'm soldering up a test board now to try a few more ideas.
    Cheers
    Brian
    edited 2014-08-08 04:40
    Some sort of timing issues?
    It does cause a reset and the FPGA does respond and turns into a running Propeller that even loads code from EEPROM (we've proven that). It just can't handle responding to the F7 or an F10 in a timely manner.
  • pik33pik33 Posts: 2,414
    edited 2014-08-08 04:52
    Confirmed on a DE2-115 propplug-less configuration. After running FullDuplexSerial_test2.spin the propeller cannot be detected until the board is reprogrammed (i use .sof programming file now)
    edited 2014-08-08 05:18
    Thanks pik33. :)
    I was about to try it on my DE2 but it's currently setup doing P2 development stuff.
    I'll run some more tests on the De0-Nano and see what I find.
    Cheers
    Brian
    edited 2014-08-08 06:27
    I've rebooted my laptop - this has solved the issue Propeller Tool was having with hanging up trying to talk to the Nano. I must have had some driver confusion after the recent installs.
    Now with that little problem behind us:
    1) Cycle power on your Nano
    2) Start Propeller Toool
    3) F7 will find the Prop and display the signature
    4) F10 to load a program (I think it can be any program, I've seen it with PropForth and also with the PST demo
    5) That program should work fine (as long as there isn't a reset since it is in RAM, DOH!)
    6) F7 will say no Propeller is connected (I need to check this with a real Propeller but I think F7 ALWAYS responds)
    7) F10 will fail with "no propeller found"
    8) recycle power on the Nano
    9) F7 will work
    10) F10 will work but it puts you back to step #6
    11) you never get here because you are in a loop between step #6 and step #10!! :lol:
    This is with a bare Nano - NO EEPROM
    If you have an EEPROM, the reset works and the fP1 (I kind of like that designation, whoever came up with it) loads from EEPROM and runs the program in EEPROM without issue. Reset does not corrupt the FPGA Propeller in any way.
    This makes me think it could be timing with the reset AFTER the initial power on versus the reset after a program has been loaded. Something the reset and the loader process have in common or something the loader trigger that then causes both to fail.
    F7 by itself can be done forever. Once you do an F10, you have corrupted it causing the need for a power cycle.
    EDIT1: DOH! Of course it does!! (Does F7 from the Prop Tool cause a reset? I guess I never paid attention before if it reset my program or not.)
    Propeller Tool and BST work the same so I assume it isn't an IDE issue in any way.
    Time to see what F7 does with a real Propeller......
    EDIT2: Real Propeller results
    Real Prop: With one program in EEPROM (PropForth in this case) and a different program loaded to RAM (PST Demo) , the RAM program runs until you F7 and then the Propeller responds to the F7 and then loads the program from EEPROM.
    fProp (NanoProp): With one program in EEPROM (PropForth in this case) and a different program loaded to RAM (PST Demo) , the RAM program runs until you F7 and the Propeller DOES NOT respond to the F7 but it DOES load the program from EEPROM and it runs successfully.
    This behavior is annoying when you are using F10 (power cycling isn't too difficult) but it makes the fP1 unprogrammable after the first F11 if you put an EEPROM on it. :frown:
    edited 2014-08-08 07:07
    I added an Eeprom into the mix with the same results.
    The Eeprom was programmed by a real prop1 and verified Ok.
    Eeprom boots Ok on DE0-Nano and code runs fine.
    Any form of reset(F7 in Prop Tool,PST DTR toggle or REBOOT in spin) never resets correctly.
    Power cycle is needed every time to reset.
    I'll keep digging....
    Cheers
    Brian
    edited 2014-08-08 10:29
    The bug seems to be simple: cog ram is not resetted by resn. After resetting a propeller, the demo starts to working again, the prop responds to bytes send to it via terminal. It interferes with propeller detect/program code.
    Edit: patching this will not be trivial...
    Edit 2: the demo doesn't start, it was my mistake. I will search for the bug tomorrow, unless someone else find it earlier
    edited 2014-08-08 10:39
    pik33 wrote: »
    Forget this: I don't think so, the code in RAM does not start working - if you don't have EEPROM, nothing appears to happen. If you have EEPROM, it resets and loads from EEPROM.
    I'll have to try it with a pair of blinky programs instead of two serial I/O related programs to prove this theory one way or the other.
    EDIT: New Experimenting with blinky LEDs on the Nano
    Fast LED blinker in EEPROM
    Slow LED blinker in Propeller Tool
    F10 - loads and runs slow blinker
    F7 - Prop returns a response, resets and runs the Fast blinker from EEPROM
    F7 - same as above....
    Remove EEPROM
    F10 - loads slow blinker and runs
    F7 - Prop returns a response, and does nothing (RAM cleared so there is nothing to run?)
    F7 - same as above
    So, now what do we know??
    I'm not sure, I'm confused.
    @pik33, I think you are on to something with:
    but in my tests, it was the EEPROM program that was loaded and interfering EXCEPT I don't think the program had enough time to load to start sending characters out yet so I'm not sure what was interfering.
    Did you see in the verilog where it doesn't reset RAM?
  • jmgjmg Posts: 15,193
    edited 2014-08-08 13:57
    pik33 wrote: »
    I think this sounds like a 'clean slate' issue - a FPGA reprogram puts the FPGA back into a known start state
    (should be the same as a Board Power cycle), so it sounds like the Prop Reset does not quite have the 'coverage or reach' it should have ?
    edited 2014-08-08 20:06
    Test configuration = DE0-Nano ( NO EEPROM attached)
    Put a second prop plug onto the Nano and ran the FullDuplexSerial_test2.spin demo on pins 4 & 6. Runs Ok.
    Code can be loaded using "Load RAM" as many times as you like, no problems.
    F7 - Identify Hardware works every time. No problems.
    Problem seems to be linked to P30 being used as TX by code?
    edited 2014-08-08 21:33
    re:Problem seems to be linked to P30 being used as TX by code?
    Good work. I'll have to try it out.
    edited 2014-08-08 21:52
    ozpropdev wrote: »
    Now you mention it, I think I may have seen notes on that.
    In that case, the issue is the PC end has a flood of data coming into the port, while it is getting the house-keeping done.
    You could check that with a break-switch, in the TX line, to confirm it really is the food-effect.
    Maybe try different download tool chains ?
    I'd say the PC Sw needs to flush the RX buffer after issuing a reset, and not take too long between Port open, and reset issue, to avoid over run effects. If the Baud rate effects this, it would suggest the byte-count matters.
    edited 2014-08-08 22:25
    In the DEMO FullDuplexSerial_test2.spin it doesn't transmit data for 5 seconds.
    If I load the EEPROM with the standard P30,P31 configuration it fails to reboot after a reset.
    If I change just the Tx to another pin and reload the EEPROM it boots every time after reset.
    In my own code in EEPROM, comms sits dormant until called for.
    Code boots from EEPROM fine, but if a reset is done via any of the above mentioned methods
    it wont reboot again unless I power cycle the nano.
    If the code in EEPROM uses P30 as Tx the only way I can reload the EEPROM with new code
    is to use "Load EEPROM" almost straight away after a power cycle or programming will always fail.
    I sometimes have to use a real P1 to program the EEPROM if its a large program and I'm not quick enough.
    Brian :)
    edited 2014-08-08 23:32
    Investigation results:
    (1) It is enough to do a serial.start to make the Propeller undetectable
    (2) The Propeler is undetectable because it doesn't respond (no activity on Tx)
    edited 2014-08-09 00:03
    My GUESS is it has something to do with booter and the lfsr sequence/version number communication.
    Maybe I can hook my DE2 up running P2 code and capture the Tx/Rx data for a closer look.
    Looks like I'm in for a big night of coffee drinking.... :)
    edited 2014-08-09 00:24
    I removed all code beginning from 'receive' from fullduplexserial. Bug slill active.
    Then I commented this:
    if_z or dira,txmask
    The bug disappeared, the Propeller is detectable.
    Then I restored original fullduplexserial code, only commented this line
    Edit 3. E
    if_z or dira,txmask
    Demo is not working, but the Propeller is detectable.
    Strange bug.
    Edit: tried to run simple object which only does or dira, #000000_00000000_00000000_00000000. This doesn't cause the bug
    Tried to do the same inside fullduplexserial: bug is active
    Edit2: if fullduplexserial object is stopped immediately after start, there is no bug
    Edit3. I am trying to simplyfy a "bug maker". Removed all code from fullduplexserial pasm, after this
    or dira, txmask
    added infinite loop instead. Removed all demo code leaving only serial.start, wait, serial.stop. Bug is active. Next I will try to remove next part of code to locate what instruction/combination causes the problem. The goal is to make a minimal bug maker.
    I
    edited 2014-08-09 02:14
    This is enough to trigger a bug.
    'FPGA Reset bug maker v. 1112
    VAR
      long  cog                     'cog flag/id
      long  rx_head                 '9 contiguous longs
      long  rx_tail
      long  tx_head
      long  tx_tail
      long  rx_pin
      long  tx_pin
      long  rxtx_mode
      long  bit_ticks
      long  buffer_ptr
      byte  rx_buffer[16]           'transmit and receive buffers
      byte  tx_buffer[16]
    PUB bug
      Wait_1_Second
      stop
    PUB Wait_1_Second     |i
      Pauses the calling cog's execution for approximately one second.
      parameters:    none
      return:        none
      example usage: Wait_1_Second
      waitcnt(cnt + clkfreq)
    PUB start(rxpin, txpin, mode, baudrate) : okay
    '' Start serial driver - starts a cog
    '' returns false if no cog available
    '' mode bit 0 = invert rx
    '' mode bit 1 = invert tx
    '' mode bit 2 = open-drain/source tx
    '' mode bit 3 = ignore tx echo on rx
      stop
      longfill(@rx_head, 0, 4)
      longmove(@rx_pin, @rxpin, 3)
      bit_ticks := clkfreq / baudrate
      buffer_ptr := @rx_buffer
      okay := cog := cognew(@entry, @rx_head) + 1
    PUB stop
    '' Stop serial driver - frees a cog
      if cog
        cogstop(cog~ - 1)
      longfill(@rx_head, 0, 9)
    DAT
    '* Assembly language serial driver *
                            org
    ' Entry
    entry                   mov     t1,par                'get structure address
                            add     t1,#4 << 2            'skip past heads and tails
                            rdlong  t2,t1                 'get rx_pin
                            mov     rxmask,#1
                            shl     rxmask,t2
                            add     t1,#4                 'get tx_pin
                            rdlong  t2,t1
                            mov     txmask,#1
                            shl     txmask,t2
                            add     t1,#4                 'get rxtx_mode
                            rdlong  rxtxmode,t1
                            add     t1,#4                 'get bit_ticks
                            rdlong  bitticks,t1
                            add     t1,#4                 'get buffer_ptr
                            rdlong  rxbuff,t1
                            mov     txbuff,rxbuff
                            add     txbuff,#16
                            test    rxtxmode,#%100  wz    'init tx pin according to mode
                            test    rxtxmode,#%010  wc
            if_z_ne_c       or      outa,txmask
            if_z            or      dira,txmask
    loop                    jmp #loop
    t1                      res     1
    t2                      res     1
    t3                      res     1
    rxtxmode                res     1
    bitticks                res     1
    rxmask                  res     1
    rxbuff                  res     1
    rxdata                  res     1
    rxbits                  res     1
    rxcnt                   res     1
    rxcode                  res     1
    txmask                  res     1
    txbuff                  res     1
    txdata                  res     1
    txbits                  res     1
    txcnt                   res     1
    txcode                  res     1
    edited 2014-08-09 02:58
    Test number #???
    The PASM code will cause a reset problem
    The SPIN code variant does not?
    Huh?
    'FPGA Reset test
    con
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      tx = 30
    pub main
      cognew(@pasm,0)    'this will cause a reset problem
      'dira[tx] := 1     'these spin instruction DONT cause the reset issue?
      'outa[tx] := 1
      repeat
    dat
    pasm          or        dira,_tx_pin
                  or        outa,_tx_pin
    me            jmp       #@me
    _tx_pin       long      |< tx
    Cheers
    Brian :)
    edited 2014-08-09 03:05
    ozpropdev wrote: »
    What if you use P30, and physically break the Tx line to the PC ?
    Trying to nail if it is something the P30 does on the FPGA board, or the Data arriving at the PC that is the issue.
    edited 2014-08-09 03:27
    The problem is Cog1-7 related.
    The pin state is held high after a reset blocking further comms.
    Setting the pin low before a reset eliminates the reset issue.
    I'm doing more tests to verify this now.
    Brian :)
    edited 2014-08-09 04:15
    Ok
    Heres the simple code I used to verify thr reset issue.
    pub main
      'mycode
      coginit(5,mycode,0)
      repeat
    pub mycode
      dira[30] := 1
      outa[30] := 1
      repeat
    Calling "mycode" from Cog 0 works Ok.
    Starting "mycode" in cogs1-7 blocks reset.
    Setting pin state low (outa[30] :=0) fixes reset issue.
    Cheers
    Brian :)
    C
    edited 2014-08-09 04:17
    Patched.
    In file cog.v about line 333 is :
    always @(posedge clk_cog)
    if (setouta)
        outa <= alu_r;
    if (setdira)
        dira <= alu_r;
    and should be
    if (setouta && nres)
        outa <= alu_r;
        else if (!nres)
       outa<=0;
    if (setdira && nres)
        dira <= alu_r;
      else if (!nres) dira<=0;
    The reset signal didn't reset outa and dira.
    Please test if it works in your environment.
    edited 2014-08-09 05:16
    Thanks pik33
    I only have Quartus II 13.0 web edition which does not allow me to open projects.
    I tried downloading version 14.0 only to find its for 64bit machines. So I can't compile your patch.
    The Altera webpage keeps bouncing me back to the same place.
    Apparently there's a 32 bit version somewhere out there. I'll try again tomorrow.
    Cheers
    Brian
    edited 2014-08-09 05:42
    The original project seems to be done in 13.1.
    You can download 13.1:
    http://dl.altera.com/13.1/?edition=web
    There is 32 bit 13.1, and no 14.0
    or you can simply start a new project in 13.0, show it the directory where you have source files and use top.tdf as a main entity.
    Set verilog version to SystemVerilog.
    Then compile and run
    .. or try this .sof (untested, I have no DE0-nano)
    zip
    240K
    top.zip 240.2K
    edited 2014-08-09 06:07
    I hope to test it sometime today..but first I need to do all my Saturday chores.
    I havs a Nano running and a BeMicro CV, I was hoping to get my DE2 up and running this weekend with pik33's P1 Block.
  • rjo__rjo__ Posts: 2,114
    edited 2014-08-09 06:55
    I have compiled successfully under quarts web 13.01 32bit using XP.
    I noticed a warning about a device wide reset
    DEV_CLRn pin will set, and not reset, register with preset signal due to NOT Gate Push-Back
    (ID: 13003)
    #13003, which is explained here http://drlnet.dyndns.org/help/quartus/webhelp/mergedProjects/msgs/whnjs.htm
    "CAUSE: You enabled the device-wide reset (DEV_CLRn) pin for the current design's target device. As a result, Analysis & Synthesis enabled the NOT Gate Push-Back on some registers in the current project. For devices that have the DEV_CLRn option, these registers will be set rather than reset when DEV_CLRn is enabled.
    ACTION: No action is required. However, if you want the Quartus II software to be reset rather than set the registers with preset signals, turn off the NOT Gate Push-Back logic option for those registers."
    I don't know if this has anything to do with this problem and won't have time to look at it until the baby goes to sleep:)
    In other discussions, this setting is related to J-tag instability... so, it certainly sounds like it could be the villain.
    Rich
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2014-08-09 08:51
    @pik33 I added your suggested changes to the cog.v file and re-compiled from top. . I was able to run Forth then some simple C stuff without having to power down. Thanks
    I have had a DE0_Nano since January 1013,
    @Rick Verilog is much more fun than Forth.
    Ron
