Contest time !!! — Parallax Forums
Contest time !!!
Matt GillilandMatt Gilliland Posts: 1,406
edited 2014-08-26 11:50 in General Discussion
Yesssirrrreeee ARLO!!! It's time for CONTEST!!! (thanks to the gentle urging of Publision;)
Here's the deal...
You all know about our Arlo Robot System - we're getting him into schools and homes and businesses and on and on and on.
To expedite the proliferation of Arlo's, he needs to have a full complement of add-ons, extensions, expansions, do-hickeys and giz-me-doos.
What do you think we should add to the Arlo System next?
Be specific... - "robot arm" ain't enough. What should the device be, what should it be able to accomplish, and what should it enable the robot to do.
Special consideration may be given to those ideas that have an Educational leaning.
UPDATE: END TIME IS THURSDAY THE 24TH AT 9AM PST!
The end of the Contest is Scheduled at 2PM, Friday, July 20th, 2014, Parallax Standard Time
Prize(s)??? Of course, Yes! What are they? I have no idea...but have we ever steered you wrong in a Contest yet? As always we can change the rules at any time - but probably won't unless some of you mis-behave :tongue:
Ready...Set...Go!!!
-Here come da' Judge MattG
«134
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-07-16 14:56
    How about an Emic2 and/or an EasyVR? These could complement each other and could be geared towards an educational theme of some sort.
  • RsadeikaRsadeika Posts: 3,861
    edited 2014-07-16 15:06
    My big thing has always been an automated re-charging system, you would think that that would be standard equipment for a modern day robot. That could be configured as a roll on or roll up to a home base where it makes contact and automatically charges the batteries.
    Ray
    edited 2014-07-16 15:59
    I'm working on IMU + sf02 for automated mapping. That might be expensive for a school budget, but one could start off with the ping to get the code working for short distances.
    edited 2014-07-16 16:01
    The goolge VR might be an alternative to consider
    http://www.dodocase.com/products/google-cardboard-vr-goggle-toolkit
    edited 2014-07-16 16:55
    Did you mean Friday, July 18th?
    Maybe an add-on calendar would be a good idea! ;-)
    C.W.
    edited 2014-07-16 17:55
    It's always been my contention that Arlo (I didn't know that it had a name other than Eddie) should have some sort of body framework like that of the old Hero robots to which controlling boards and prototyping boards could be attached to fill him out a bit. Just having stacked platforms doesn't make him look like a full robot to me, just a base. Additional Bonus points for coming up with a way to make this framework compatible with current building technolgoies like Erector, or Lego. The expensive injection molded outside isn't neccessary, just the inside. The original Hero was documented as being 20" in height.
    I don't know about this contest, but he'd be the kind of robot I'd want..
    Come on Parallax, you guys have the engineering skills (looking at you Matt) and fabrication machines to make this happen.
    I keep editing this, and had one more very important thought. PLEASE KEEP ALL MEASUREMENTS IN METRIC.
    400 x 300 - 29K
    800 x 952 - 95K
    783 x 1320 - 534K
  • mklrobomklrobo Posts: 420
    edited 2014-07-16 18:31
    :frown: Man, I do not have a chance!
  • bomberbomber Posts: 297
    edited 2014-07-16 18:55
    One thing that could be useful if someone wanted to add an external GPS antenna or other high-ish power antenna is some sort of mounting pole. I have noticed some problems with the Kinect sensor causing interference that makes it impossible to get a lock if the antenna is closer than a foot to the Kinect.
    Another idea would be a switch plate that is flush with the exterior of Arlo allowing you to switch it off if it is running away without fear of your hand getting caught between the decks. I also added a missile-style safety switch in place of the existing motor switch so i could stomp on the switch in an emergency. Plus it feels like I am handling something more dangerous when I flip the safety cover up first :)
    1024 x 1365 - 79K
    1024 x 768 - 96K
    edited 2014-07-16 21:56
    Laser or more likely IR-based navigation with sufficient range to enable whole-house navigation. It's high time for Arlo to know where the heck he is, or at least be able to reliably get from A to B to C and back to A again. That's when a robot starts to be useful in the home and at the academic level.
    AFAIK Rovio and ER-1 were the only robots who could figure out where they were, thanks to Evolution Robotics' fabulous Northstar system which projected an IR constellation up on the ceiling. That would actually be my first choice, although it's definitely proprietary and probably pricey. It would be well within the Propeller's capability to process that geometric info in real time. So that's one IR projector in each room and the camera plus some hardware on Arlo.
    Next best would be IR beacons or laser reflector stickers which would give Arlo line-of sight pathways. Each beacon emits a unique pulsing IR code on 38 kHz, or better yet 56 kHz to reduce interference with standard consumer remote controls. Arlo knows which beacon is which and simply follows the IR signal to navigate to the beacon. There could be umpteen to 255 unique beacon codes to traverse complicated paths in large areas. Alternatively, Arlo emits a pulsed laser signal (low and parallel to the floor for safety) which detects a passive reflective sticker affixed to a baseboard. The duty cycle used by my beloved Hamamatsu S6986 system is very low (better for safety). That coupled with a PIR sensor shielded in a narrow optical baffle, to shut off the laser if human motion is detected directly ahead for safety reasons.
    The Pololu IR beacons are transceivers for two-way communication, which adds some nice features.
    Optical encoders are used periodically for dead reckoning in order to maintain course if Arlo's view of the beacon or reflector is momentarily interrupted by someone walking between them. A full complement of IR, ultrasonic, and bump sensors are used for collision avoidance.
    All very doable with cheap hardware, I've laid the groundwork for you, Matt:
    IR Beacon tracking: https://www.youtube.com/watch?v=3rHuFFe6HRc
    Laser reflectors: https://www.youtube.com/watch?v=beoNr5vsbGw
    Dead reckoning: https://www.youtube.com/watch?v=PX0IhUqnwrk
    edited 2014-07-16 22:29
    Vision.
    As Arlo is no longer tied to the MS robot platform, with its Kinect, a robot of this size and application needs a vision system, even if it's just a blob tracker. Maybe you can adapt the latest CMUcam that Kwabena did, writing a layer for Arlo's control board to make good use of it. I'm not saying you should use the CMUcam 4, as I think its form factor is as an Arduino shield, so this may need a custom board. SimplyTronics here?
    Vision, even simple blob and color tracking, is a very important aspect of school lab robots. While not knocking some of the other ideas, things like Emic and VR are already standing products in the Parallax lineup, and can be ordered at any time.
    Oh, that reminds me, you need to get crackin' and write C wrappers for all these things. I think Andy has Ping, 2-axis accelerometer, and a few others for the Boe-Bot Activity Board, but really, Arlo needs wrappers for every major sensor yuze guys sell, and that would be applicable to school settings for this robot.
    edited 2014-07-16 22:56
    Northstar is/was patented, and now the patents belong to iRobot, which bought out the assets to Evolution. iRobot may have a licensing structure, but I recall it was pretty steep under ER.
    What iRobot calls "Northstar" on its consumer robots is not, I think, the same celestial navigation system ER developed. They talk about "channels" so I think it's radiometric or IRmetric. The robot it's used with was developed under ER, so maybe they just borrowed the cool name.
  • Paul K.Paul K. Posts: 150
    edited 2014-07-16 23:36
    Make a complete kit available. You do offer all the parts individually but, a complete kit is a lot easier to make decision on.
    Looking at the bot from an educational point of view. First step make it move then turn it to a balancing platform. A small add on gyro/acc board would be cool.
    I think being able to convert the tail dragger version of the robot to balancing bot has a huge learning curve. Not to mention the sensors that could be added on to steer it along its way in the processs.
  • W9GFOW9GFO Posts: 4,010
    edited 2014-07-16 23:43
    Earlier this year at CES I saw an indoor navigation system that used time-of-flight beacons. It was intended for warehouses or supermarkets. Each beacon would run several months to a year off a battery (depending on update interval) and had something like a ten to twenty meter range. Only three or four would be required for an average size house. It was accurate to about 10 cm.
    edited 2014-07-17 03:26
    Some sort of display!
    Even if it's just a couple of 8x8 LED matrixes.
    There's not much that's better for debugging a robot than a display with realtime status updates.
    Two lines getting closer and closer as it approaches a wall, flashing '-' signs when it needs a recharge...
    Switching between '+' and '-' while charging...
    Recharge equipment should be wireless.
    edited 2014-07-17 07:12
    LOL! Yes, it's FRIDAY THE 18th! (shame on me) :tongue:
    -MattG
    edited 2014-07-17 08:11
    -MattG
    Shortest contest ever. Pourquoi?
    edited 2014-07-17 08:29
    There is a desire / consensus to extend this Contest until Monday @ 9am PST? It would allow working peoples to chime in over the weekend...Yep.
    It would also allow those with slower moving brain-cells (you know who you are) to come up with some spectacular suggestions too.
    After conferring with myself - the Contest is officially extended to Monday the 21st with a finish-line time of 9am PST.
    -Matt "changing the rules again" G
  • ChrisL8ChrisL8 Posts: 129
    edited 2014-07-17 08:42
    RoboPeak $400 Laser Scanner http://www.robopeak.com/blog/?p=278 . It is the next step after Kinect to allow SLAM.
    The good ones are $5,000
    The cheap ones are $1,000,
    but there is this a new one out for about $400 that has ROS (Robot Operating System) drivers:
    It is a little more cumbersome than the fancy ones, but it appears to do the job well from the tests so far.
    ROS Drivers:
    http://www.ros.org/news/2014/06/robopeak-announces-ros-drivers-for-the-rplidar.html
    This is serious stuff because now you are doing the same thing that Google does to create self driving cars, just on a lower budget scale. No pretending with sonar/IR, or even Kinect, it is real Laser scanning with high enough resolution to create maps and localize the robot within them.
    Here is a quarter million dollar robot: https://www.willowgarage.com/pages/pr2/order
    It also runs ROS and relies on laser scanners.
    The Arlo can basically do the same thing as that $280,000 robot, using the same software stack, if it has a laser scanner and some time put into engineering a well thought out mounting system.
    $400 is dirt cheap for a Laser Scanner right now, and if Robopeak can do it, it is amazing. It seems like an expensive accessory, but a fully built Arl is $1000, so it is within the same budget category.
    I know this isn't something Parallax gets to build, but you could certainly work with Robopeak to license and distribute it, or maybe they do need some manufacturing mojo?
    Their Laser Scanner is not unique, it appears to be a near replica of one found in the Neato Vacuum cleaner robot, so the design may be open? Maybe?
    Certainly, what Parallax could do is engineer and produce a quality mounting system for the Robopeak laser scanner for the Arlo.
    Or just create a nice mount for the Kinect or ASUS Xtion so our robot's can watch Star Trek:
    Please note that while the computer model is a TurtleBot, that is really running on an ActivityBot (connected to a computer running ROS of course). I just hadn't gotten around to building a new robot model file yet when I was at that point.
    And as you can see from my other post, the ActivityBot is really a poor mount for the Kinect: http://forums.parallax.com/showthread.php/156480-Arlo-s-got-the-Power-Distribution-Board-and-you-can-too!?p=1279101&viewfull=1#post1279101 :)
    P.S. When my Alro parts arrive it will navigate with a Kinect/ASUS Xtion 3D camera, but I'm keeping my eye on that Robopeak Laser Scanner and saving my pennies.
    1024 x 510 - 56K
    If the August 2013 SERVO issue is out by then you can get some ideas based on what I did to an old Stingray chassis that I had..........
    Robert
    edited 2014-07-17 09:55
    ...an old Stingray chassis that I had..........
    Robert
    Since when is the Stingray old, Mr. HERO Robot? :)
    edited 2014-07-17 10:00
    Proof we need to have more contests specifically for the date-impaired. And MattG is the perfect contest master for it!
    edited 2014-07-17 13:22
    I resemble that remark! :tongue:
    -MattG
  • rogersydrogersyd Posts: 223
    edited 2014-07-17 15:45
    Golly! a power-distribution system for such a bot would be great! .... oh wait.... :)
    There are so many cool things already available that I would consider a line of adaptors and holders that make those existing gadgets easy to mount to the arlo body. (Similar to the various ping holders that are availalbe but for the prop cam, gas dectors, VPN1513, etc.)
    Im sticking with my stingray for now, but the arlo sure is neat.
    edited 2014-07-17 15:59
    rogersyd wrote: »
    Your'e kiddin', right?
    http://forums.parallax.com/showthread.php/156480-Arlo-s-got-the-Power-Distribution-Board-and-you-can-too!?highlight=ARLO
    edited 2014-07-18 18:41
    Phew! The original contest schedule was under 48 hours. By extending the cutoff to Monday, you've expanded that window 250%. Very wise if you're serious about the next big idea. You can't rush genious!
    edited 2014-07-19 07:35
    Old as in old, no. Old in that Parallax no longer sells that kit... Here are a few pictures that shows what I did to the Stingray and something similar could be done for the ARLO chassis. It could be done as an optional add on kit for it.... That is my suggestion and something I could help Parallax with... You can click on any of the images to get larger pictures. The first one shows the base, the next the top part of the body, and the last shows what it will look like once I make the plastic lower panel. You'll be able to read all the details on the robot once the August issue of SERVO is out...
    Robert
    I'll post more details and some extra information about it on my site here:
    http://www.robotworkshop.com/robotweb/?page_id=628
    640 x 1189 - 95K
    640 x 854 - 87K
    640 x 1155 - 92K
  • NikosGNikosG Posts: 705
    edited 2014-07-19 13:23
    Nice ideas !!!!!
    My suggestion is somthing very simple but very functional especially for indoor use.
    A kind of fender with spring with elasticity (see the next image )
    For the Arlo Robot this fender could have 4-parts or 2-Parts.
    886 x 879 - 176K
    edited 2014-07-19 14:47
    Bumpers sure are a good idea!
  • RDL2004RDL2004 Posts: 2,554
    edited 2014-07-19 15:21
    WiFi, it needs some kind of WiFi connection. How else will it connect to the IoT?
    edited 2014-07-19 19:39
    Are flamethrowers and missile launchers right out? They can be dramatic and very interactive.
