Shadow length Implimentation
I wanted to implement above code for to avois shadowing.i have included c file.Intially without above algorithm i used to calculate tracker desire=90- conv_elevation;this actually tilt angle of panel when kept alone for tracking
Here i wanted to calculate shadow length and need to determine tracker position,
D=min array spacing 4 meter
D'= max shadow length; to be calculated
h= height of ob traction=1.2 meter
Can some tell me how implement above algorithm. how to related D' and h,x.
I wrote an Excel file that does "Shadowning" calculations .
This may be helpful.
Duane J
I have implemented based on nrel Code. Where i get , zenith ,azimuth , elevation angle . The code being worked fine for single tracker unit. Now i have array of panel. Can some suggest me how to implement what will be angle based on shadow length.
shadow length calculation done here.
http://www.mysolarpannels.com/optimum-angle-for-solar-panels/
general equation
http://www.esrl.noaa.gov/gmd/grad/solcalc/solareqns.PDF
Here i am attaching Excel part for calculation implemented,Let me know how to relate shadow length vs α-solar radiation angleNOAA_Solar_Calculations_day.xls
