Through-Hole "Smart" RGB LEDs (WS2811-compatible)
JonnyMac
Came across these today -- they seem reasonably priced for simple projects.
-- http://solderingsunday.com/shop/components/pixelbits-bakers-dozen/
It's a pity the Vdd isn't on the outermost leg, but oh well. The 2.54 pitch is nice
I should give credit where it's due: I saw a blurb about these on Hackaday -- and was surprised Eric hadn't already posted about them!
http://samuraicircuits.com/merch/index.php?id_product=57&controller=product
if you change it to "who'd a thunk it?" then... Me.
Back in 2003.
Right down to the 4 pin leadframe that was then just R G B and either + or - .
But I felt it was a natural progression of everything and too obvious, and nothing a college student barely scraping by could actually have any effect on.
So... glad to see these exist now.
Aargh!
I already tied up all my 'fun money' for the next month or two with upgrades to my Logic analyzer...
Still, interesting shop. Will have to visit it again when money allows.
Ooops, I must not post when I'm half asleep:)
Yeah, I guess it's a natural progression. After all we had self flashing LEDs for ages.
Thing is I remember seeing my first 4mm red LED around about 1969. In the days when electric clocks had mechanical displays, and electronic instruments used Nixie tubes. A friend of mine had got one and showed it off in the school yard.
"WTF? You mean it's a diode that lights up? Amazing!"
Been hooked on LEDs ever since.
The rumour is the next version of these leds will support dmx protocol, natively. At some point in the future I guess they'll have their own IP stack and internet connectivity.
20 years from now, everything will have an address. Your toaster will have an address. Every bulb in your house will have an address. Your toothbrush will have an address. Everything will be a "module" that performs some function... and it will be individually addressable. Wirelessly. Watch & see!
and Google will be spying on you through each of them.
LOL, and I thought I was getting crotchety and cynical.
But once I got into them - the do NOT use a standard serial, I2C, or other usual protocol. They use a NZR (Non Zero Return) protocol. Standard serial won't do it - they have (in this case a 400kHz data rate) with very specific relationships between low and high time for each bit transmitted. So I thought I was going to just hit these with SEROUT or "led.ser" but neigh... these need special stuff apparently. Looks much more like the stuff for a Propeller, and less like they would be stamp compatible...
Do you know about JonnyMac's driver?
In case you've missed them, there have been several threads about these LEDs. Here's one I started to show off some patterns and PCBs. JonnyMac's driver is in the OBEX.
JonnyMac, your driver is great! Thanks so much for providing it.
I'm controlling a ring of 12 LEDs with 3.3 volts right now. It seems to work fine. I have some 74HCT245 ICs to bring the signal up to 5 volts for the final device, but so far no problems with 3.3 volts. Maybe issues become apparent with larger chains.
http://www.pololu.com/product/2536
Makes me wonder what my shower head has been telling my toaster.
Great! Not sure about your math though...
the Soldering Sunday price is roughly $15 for 13 or $30 for 26
For 30$ on Pololu you can get 6 packages of 10 making it 60 LEDs for $30.
How did you figure 40 for the price of 26?!?!
OK - gotcha!!
For a moment, I thought it was that "new math". You rounded way up!
Have you created any projects with them yet?
Oh - I misunderstood - thought you bought some from the other place earlier.
NSFW!!!! You have been warned! This may be NC-17+ or R.
Sounds like you are describing the plot of "Idiocracy"!
http://www.youtube.com/watch?v=nVtKrGyUS5o
