High Quality Audio. Prop Dac or other DAC? — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2014-01-21 07:06 in Propeller 1
I am designing a board that will have an SD card and RTC for data logging and other expansion uses, this board has a dedicated Prop so that the main board Prop doesn't have to get squeezed to fit the new requirements. The Main board will send opcodes via a short cable to the new board.
I have spent some time looking at the OBEX and searching the forum for DAC Audio.
http://forums.parallax.com/showthread.php/132857-WAV-File-Magic
From what I can tell Kye and jonny mac have spent a lot of time working on high quality output.
I don't have a board with an SD card today to start testing the objects above. I was wondering if anyone has any opinions on the existing WAV file magic or Stereo Duty object mentioned by Jonny Mac in comparison to a 16bit DAC. The next question would be can the Prop 1 even handle speeds required to read a stereo 16 bit wav file and transfer the data to either 2 DAC's or a dual DAC. The board will incorporate 2 THATcorp 4315 VCA's on the output of the DAC section for gain control,(single supply version that works at 5V), so I am not concerned about handling volume in the audio data itself as the DAC output will be turned off when the audio is not playing. http://www.thatcorp.com/datashts/THAT_4315_Datasheet.pdf
The VCA is to be used to quickly/elegantly fade out the audio if the file to requested to stop immediately, which is very useful in voice prompt applications where a user may make a menu selection while a prompt is playing. The DAC will feed both a built in amplifier to drive speakers approx 2w, and will also provide line outputs for the user to connect external amps/speakers. It would be very nice to simultaneously allow playback to SPDIF using that object, maybe there is a way to closely sync the local DAC with a cog running the SPDIF object.
I currently am using a Vinculum>VS1033 with mp3's, but with the new board the goal is to get away from the Vinculum ( essentially a modified Vmusic2 schematic). The output of the 1033 is very nice, but the Vinculum has to be programmed and both of the IC's are very fine pitch and somewhere a hassle.
Any thoughts on the best DAC quality with the goal of 16 bits stereo?
  • JonnyMacJonnyMac Posts: 9,795
    edited 2014-01-04 10:24
    I don't think speed a problem (assuming 80 or 100MHz operation). A couple years ago a toy company asked me to write a WAV driver for them that would allow them to hack a Propeller into an existing circuit. That circuit used the AD5322 which is a 12-bit stereo DAC, but takes 16 bits of input. In this particular case one channel fed the Vref of the other for volume control. The WAV loop runs at the sample rate of the file, reading a sample and the volume level. At the end of the loop those values are sent to the AD5322 with very simple SPI code:
    ' Sets AD5322 dac channel
    ' -- expects 16-bit value
    ' -- bit15 holds channel (0 for volume, 1 for output)
    ' -- bits 14..12 should be clear
    ' -- bits 11..0 hold output value
    setdac                  shl     aout, #16                       ' shift bit15 to bit31 (MSB)
                            mov     tmp1, #16                       ' shift 16 bits
                            andn    outa, smask                     ' sync low
    spiloop                 rcl     aout, #1                wc      ' move bit (MSB) to C
                            muxc    outa, dmask                     ' move C to DIN pin
                            andn    outa, cmask                     ' clock low
                            or      outa, cmask                     ' clock high
                            djnz    tmp1, #spiloop                  ' more bits?
                            or      outa, smask                     ' sync high
    setdac_ret              ret
    The biggest headache of the project was soldering the uSOIC package to an adapter I could test the code on a PPDB. I managed it, though, and the client said it worked perfectly on their end.
  • T ChapT Chap Posts: 4,260
    edited 2014-01-04 10:34
    Thanks for the info. Would you consider this AD5065 16 bit device something worth starting with? I want to have boards made next week and need to settle on DAC.
    This devices uses a single SPI interface, so that Channel A and B are address in the data stream, with a command to update either channel or both.
    http://www.analog.com/static/imported-files/data_sheets/AD5025_5045_5065.pdf
    This is a TSSOP package with pin spacing of .65m which is not a big deal but I always prefer something larger, 1.27m etc.
    Versus the AD1866 in SOIC, which looks even better for audio.
    www.analog.com/static/imported-files/data_sheets/AD1866.pdf
    This device has separate data inputs for left and right, sharing the same clock:
    The digital input port of the AD1866 employs five signals: Data
    Left (DL), Data Right (DR), Latch Left (LL), Latch Right
    (LR), and Clock (CLK). DL and DR are the serial inputs for
    the left and right DACs, respectively. Input data bits are clocked
    into the input register on the rising edge of CLK. The falling
    edges of LL and LR cause the last 16 bits which were clocked
    into the serial registers to be shifted into the DACs, thereby up-
    dating the respective DAC outputs.
    Without having a lot of PASM knowledge, it is not easy to know if there is a problem of time reading the stereo 16 bit data off the card and writing it, so I wouldn't know if there were a preference for the method of input. In one of the example schematics shown in the datasheet, the LR and LL latches are shown inverted from the device sending the data, so that this would indicate that they are sending the left channel and right channel separately since the falling edge of the LL and LR are what cause the 16 bits to shift into the DAC. In this case, I don't see any real difference in timing from one device to the other, as the data is being clocked in separately and not at the same time. Maybe there could be a method to send the data to the DAC at the same time as a time saving benefit? If a single loop can set the left and right data pins, toggle the clock pin, then I don't see why you wouldn't do both data outputs in the same loop in PASM.
    edited 2014-01-04 13:24
    The chip is designed to work that way and is quite straightforward to implement. Instead of one data pin, you have one for each channel. You have a few more lines in the output loop, but it's not any more complicated that what I showed above.
  • Mark_TMark_T Posts: 1,981
    edited 2014-01-05 04:46
    One option is I2S DACs, 16 and 24 bit ones are extremely cheap these days (WM8524 for instance).
    However this approach needs a master clock that's a high multiple of the sampling frequency, and
    driving these I2S DACs/ADCs is best done by clocking the Prop at a similar multiple.
    I've used 12.288MHz MCLK before, Prop goes at 8 times this and a cog is dedicated to driving the
    LRCLK, BCLK and data lines.
    Can dig out the code if it helps. Built a DDS audio sinewave generator using CORDIC to generate
    24 bit samples at 48KSPS for this chip, it works from 3.3V and generates DC-free 2.0V rms (has
    own internal -3.3V rail generator). It claims -106dB S/N
    edited 2014-01-05 06:48
    That looks very interesting Mark, but since I will already have a number of other objects based on 5m and pll16, I may be asking for a headache changing out the crystal to formats I am not experienced with.
    edited 2014-01-05 09:47
    @Mark_T: I'd be interested in seeing what you've done with I2S.
    @T_Chap: Hopefully, the code you're using is speed agnostic, that is, it adjusts itself to the speed and isn't locked to a specific frequency. Of course, many objects will require a minimum speed, but I can't think of a reason for an upper limit. 12.288 x 8 = 98.3MHz; you'd get a little more performance out of you code that normally runs at 80.
    edited 2014-01-05 10:41
    It has great reviews. I will put both dac's on this board and a/b test it. The board is a FAT + RTC + DAC audio board as an add on module so I have room to add the parts. I will build an extra for you guys if you want.
    edited 2014-01-05 12:51
    I use the 12.288 on the VLSI VS1033 mp3 part, and the reference schematics for that part show the crystal with a 1m res between the pins, and a 33pf to gnd off each pin. This is how I used it on my audio boards. For the Prop, would I keep the same res and caps or lose them, the 5m I currently use on the Prop has never had any res/caps.
    edited 2014-01-05 19:08
    http://www.esstech.com/PDF/ES9023%20PB%20Rev%200.2aPB%20110117.pdf
    On some audio forums, this DAC is referred to as the better option for audio than the WM8524, it is a similat I2S device with charge pump, 24bit.
    Here is a comparable TI DAC
    http://www.ti.com/lit/ds/symlink/pcm5102.pdf
  • jmgjmg Posts: 15,200
    edited 2014-01-05 20:46
    i2s would make sense, as you leverage the large Consumer volumes.
    Has anyone used/mentioned the Nuvoton NAU8402 ?
    https://www.nuvoton.com/NuvotonMOSS/Community/ProductInfo.aspx?tp_GUID=10324f97-b6f3-4a58-bc76-d51f14544b38
    Also a Stereo DAC, with charge pump for 2Vrms analog output capability., no caps.
    I see Digikey have NAU8402 in stock, for 100 : $1.0535
    Not sure if this can be used as a DC DAC ?
    edited 2014-01-05 21:08
    I have a question about the master clock. On the ES9203 I linked above, the datasheet states
    256fs or greater is recommend ed for 32kHz to 96kHz sampling.
    For 44.1k does this suggest that the Prop will need to produce a master clock of 44100 * 256 = 11,289,600? This should be easy to handle with either the 5m or 12.288 crystal.
  • pik33pik33 Posts: 2,417
    edited 2014-01-06 02:26
    These DACs need an extreme low jitter clock source. Using 5M crystal+Propeller's PLL to make 11.2896M will give a lot of jitter and this will cause the noise on analog output.
    There are solutions:
    - use 11.2896 MHz crystal for the Propeller and DAC
    - use DAC chip with internal oscillator, for example WM8731
    edited 2014-01-06 04:45
    The ES9023 states that it is "Jitter Immune", having a jitter reduction feature. The WM8731 is a nice part but is quite a bit more work to build having more external parts.
    I will add this TI clock source, so is there a preferred Prop crystal with the master clock now being handled outside the Prop.
    Generated Audio System Clock (PLL1707): fS= 32, 44.1, 48, 64, 88.2,96 kHz)
    http://www.ti.com/lit/ds/symlink/pll1707.pdf
    The PLL1707
    and PLL1708
    are low cost, phase-locked
    loop (PLL) multiclock generators. The PLL1707 and
    PLL1708
    can generate four system clocks from a 27-MHz
    reference input frequency. The clock outputs of the
    PLL1707
    can be controlled by sampling frequency-control
    pins and those of the PLL1708 can be controlled through
    serial-mode
    control pins. The device gives customers
    both
    cost and space savings by eliminating external
    components and enables customers to achieve the very
    low-jitter
    performance needed for high performance audio
    DACs and/or ADCs. The PLL1707 and PLL1708 are ideal
    for MPEG-2 applications which use a 27-MHz master
    clock such as DVD recorders, HDD recorders, DVD
    add-on cards for multimedia PCs, digital HDTV systems,
    and set-top boxes
    EDIT it looks like the 1708 has greater flexibility of control using serial config.
    edited 2014-01-06 10:20
    T Chap wrote: »
    There is also the SI5351A-B-GT, lower cost and smaller, with more frequency control, over i2c, but a little more complex to drive.
    edited 2014-01-06 10:28
    Thanks for the info, I have completed the hunt for parts and am now putting the board together with
    ES9023 DAC
    PLL1708 Clock
    SD Card
    S-35390A RTC
    Prop
    FT232RL
    The only thing I am looking at is if I want to put a buffer on the clock output into the the DAC. Not sure if this is really needed on a trace of less than 1". There are several clock outputs, I was thinking of selecting the clock line by included an 0603R in the path.
    edited 2014-01-06 12:02
    I'd also allow an option for direct CLK from a second NCO.PLL mode.
    That reduces the jitter, less clear by how much exactly - so measuring could be a good idea.
    Also promising could be CSTCR5M00G53Z-R0, with the Prop C's this might pull down to the 4.992000MHz needed. -0.160%
    (my feeling is the Prop C's will over-pull, past the ideal -0.160%)
    or, if 64MHz is ok, Mouser have CSTCR4M00G15C99R0 which is tighter spec, and the lower F will pull less with the lowest Prop C setting. I make jf=1.23MHz lowest jitter solution for (4Mz-0.160%)*16 fPLL_ref = 6.153846153MHz in both cases.
    While you are experimenting, there is a xtal/pll solution that divides by 13 for 47 of 48 times and /14 for 1 of 48 => 13*47+14 = 625 but this will have a jitter-spur at 128kHz in the PLL, and the PLL will not filter that as well - but it may be acceptable.
  • KyeKye Posts: 2,200
    edited 2014-01-07 11:49
    I made a much better wav player recently...
    http://forums.parallax.com/showthread.php/150602-New-WAV-player-(V2)?highlight=wave+player+v2
    It works really good.
    edited 2014-01-07 12:25
    Thanks Kye for the link. I will put a Prop DAC output also so I can test your methods and compare to the ES9023. I have already started laying out the schematic and board to use a multi output clock feeding a multiplexer that will allow me toe select 1 of 4 clocks feeding the DAC. I have added an opamp optional output so I can experiment with filtering ideas post DAC to have some fun with that. The board shown is just a starting point, hopefully I will get this ordered by thursday and get boards back monday, I am pretty excited to test it.
    ES9023 DAC
    SD Card
    S-35390A RTC
    Prop
    FT232RL
    ICS83054I Clock buffer/ 4in 1 out multiplexer Prop will select the clock line
    2 TDA7052A 1 watt amplifier for local speakers
    Burr Brown OPA2xxxx for output filter options
    PLL1708 Multi clock generator
    Audio Side regulators (low noise) MIC5205-3.6 MIC5205-3.3
    edited 2014-01-07 15:01
    JonnyMac wrote: »
    Here's the code of my audio oscillator (complicated by the 7-segment display driver etc), but the
    driver's in WM8524_DAC.spin:
    I've also interfaced to other I2S devices, ADCs too.
    edited 2014-01-07 17:44
    Mark, that is great to be able to study that i2s info.
    Can someone explain in simple english the process of reading the SD card audio data and passing that data to the DAC engine? Does the FAT engine need to grab one sample at a time of the left and right 24bits, and the DAC engine reads it from main memory using rdlong left and rdlong right, update the DAC and repeat? I don't get the part of how the DAC engine syncs to the FAT engine reading the data so that the DAC engine does not repeat the same/previous data if the SD card stops or runs out of data. I am sure that after studying Kye's object this will start to make sense, but it would be nice to know what to look out for.
    In Mark's DAC engine, I see the FRQB is set for the bitclock out and each write the DAC is sync'd to the bitclock:
    mov       FRQB, bclk              ' generate the bit clock via counter
    However, in his code there is no SD card being read as the cordic engine is creating the DAC values.
    edited 2014-01-07 18:28
    T Chap wrote: »
    Normally you would create a FIFO style buffer, where SD write-to-buffer and DAC server read-from-buffer. Provided the SD fetch can average faster than DAC writes (fixed rate), and without pauses longer than the buffer size, then you can have smooth data supply. If SDwritePtr == DACreadPtr you are Full, and wait until SDwritePtr <> DACreadPtr
    edited 2014-01-07 20:18
    I use a double-buffer in my audio engine. When a file is requested, a Spin cog gets launched that uses two buffers with level indicators. The background watches the level indicators and when they are non-zero will play data from that buffer; when done, the background writes 0 to the level indicator -- this tells the foreground to re-fill that buffer if there is data left to play.
    I've attached code from one of my Nuts & Volts columns that uses this. My audio engine plays only 16-bit files (mono or stereo).
    edited 2014-01-07 23:23
      _clkmode = xtal1+pll16x
      _clkfreq = 80_000_000
      _SD_DO = 0
      _SD_CLK = 1
      _SD_DI = 2
      _SD_CS = 3
      _SD_WP = -1 ' -1 ifnot installed.
      _SD_CD = -1 ' -1 ifnot installed.
    VAR
      long cog
      long buf[512]
      long bufnum
    obj
    fat :   "kyefat_lfn"
    pub demo | i
    fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, -1, -1, -1)
    i:=fat.mountpartition(0)
    start(11,10)
    'buf:=sample.getbuf
    repeat
      fat.openfile(string("wav.wav"),"R")
      repeat
        repeat until bufnum>1024
        i:=fat.readdata(@buf,1024)
        repeat until bufnum<1024
        i:=fat.readdata(@buf+1024,1024)
      until i<>1024
    pub getbuf
    return @buf
    pub getbufnum
    return bufnum
    PUB start(left, right)
    longfill(@buf,0,512)
    bufptr:=@buf
    stop
    leftcounter := ((left & $1F) + constant(%00110 << 26))
    rightcounter := ((right & $1F) + constant(%00110 << 26))
    outputmask := |<left | |<right
    cog:=1+cognew(@init, @bufnum)
    return cog
    PUB stop
    if cog>0
      cogstop(cog-1)
    cog := 0
    DAT
                            org     0
    init                    mov     ctra,leftcounter
                            mov     ctrb,rightcounter
                            mov     dira,outputmask
                            mov     bufptr2,par
                            mov     time,cnt
                            add     time,delay
    loop                    mov     ptr,bufptr
                            add     ptr,bufcnt
                            rdword  lsample,ptr
                            shl     lsample,#16
                            add     ptr, #2
                            rdword  rsample,ptr
                            sar     lsample,#16
                            shl     rsample,#16
                            sar     rsample,#16
                            add     bufcnt,#4
                            and     bufcnt,bufmask
                            mov     over,#6
                            wrlong  bufcnt,bufptr2
    p2                      add     i1l,lsample
                            add     i2l,i1l
                            mov     topl,i2l
                            sar     topl,#8
                            mov     fbl,topl
                            shl     fbl,#8
                            sub     i1l,fbl
                            sub     i2l,fbl
                            add     i1r,rsample
                            add     i2r,i1r
                            mov     topr,i2r
                            sar     topr,#8
                            mov     fbr,topr
                            shl     fbr,#8
                            sub     i1r,fbr
                            sub     i2r,fbr
                            maxs    topr, maxval
                            mins    topr, minval
                            add     topr, #$80
                            and     topr, #$FF
                            maxs    topl, maxval
                            mins    topl, minval
                            add     topl, #$80
                            and     topl, #$FF
                            shl     topr, #24
                            shl     topl, #24
                            or      topl,a
                            or      topr,a
                            waitcnt time, #46
                            mov     frqa, a8000
                            mov     frqb, a8000
                            waitcnt time, #256
                            mov     frqa, topr            ' Output.
                            mov     frqb, topl            ' Output.
                            djnz    over,#p2
                            jmp    #loop
    leftcounter             long    0
    rightcounter            long    0
    outputmask              long    0
    time                    long 0
    delay                   long 256
    lsample                 long 0
    rsample                 long 0
    bufmask                 long %0000_0000_0000_0000_0000_0111_1111_1111
    ptr                     long 0
    temp                    long 0
    bufptr                  long 0
    bufcnt                  long 0
    bufptr2                 long 0
    over                    long 0
    topl                    long 0
    topr                    long 0
    fbl                     long 0
    fbr                     long 0
    i1r                     long 0
    i1l                     long 0
    i2l                     long 0
    i2r                     long 0
    maxval                  long 127
    minval                  long -127
    a8000                   long $80FF_FFFF
    a                       long %0000_0000_1111_1111_1111_1111_11111111
                            fit     496
    Here is my driver - one of older version. You have a buffer and an counter. The Spin procedure is watching a counter and loads a chunk of data when needed. The ASM driver increases a counter every time it is getting data from it. The AND instruction causes it to loop endlessly within a bufffer memory.
    edited 2014-01-09 13:11
    Since I have the PLL1708 clock driving multiple clocks(256*44100, 384*, 768*), is it practical to consider having a clock feeding a Prop counter and have the counter fire the pasm loop to send a sample to the dac? For example, there is a clock at 768 * 44100 that could drive a counter, if the Counter starts counting from zero, gets to 768 the DAC is sent the data for that sample. The counter is cleared and starts over, counts to 768 and the next sample is sent. The thing I like about the idea is that the clock can change to to correct sample rate for each file.
    I am adding a Prop dac for testing and comparing some of the various drivers. I have seen your guys discussing several r/c values. I'd like to hear what methods of r/c plus any filtering you might be doing for best results. I added a +/-3v supply and bipolar op amp output that can be inserted and allow for some gain.
    Edit. 768*44100 = 33,868,800. Not doable assuming 4 prop clocks per pulse required. 256 or 384 is doable I believe
    edited 2014-01-09 13:54
    T Chap wrote: »
    There could be a couple of choices here.
    i) Clock the Prop in direct mode (no prop PLL) from the external PLL, and run at that MHz. This is going to be slower, and vary with rate, but may still be ok. It does force you to use an external PLL.
    ii) Feed the external PLL into a COUNTER as POSEDGE mode, and now CTR incs at a sampled Fi, but is checked at fsys,
    The master CLK is from the external PLL and the small data-edge jitter will likely be quite ok, as there will be a small pipeline effect, and sampling variation should be 12.5ns
    I think the Prop is good to 50% of the fSYS speed, due to the pin-sampling, at 50% signal duty cycle.
    If the ExtPLL has 50% duty, 33.8MHz should give about 4.525ns of skew margin on 40MHz sample.
    You could check this with a ExtPLL-> COUNTER -> WAIT -> PinChange, and time the delays & jitter on PinChange, from the external edge.
    edited 2014-01-09 14:10
    Thanks for the ideas. Maybe it is simpler just to drive the samples from pasm, probably not any real net benefit just for audio playback anyway.
    edited 2014-01-09 15:13
    T Chap, I think you'll find the V2 WAV player produces excellent quality audio. It uses pik33 and Mark_T's noise shaping technique which is wonderful.
    edited 2014-01-12 17:57
    Thanks for the info provided earlier in the thread. I am sending out for the boards to be made tomorrow and should have them back Wednesday, if all goes well I will have some boards made by Thursday. I am looking to get someone that is familiar with coding PASM audio playback from the FAT engine( or other SD card method ) to put an object together for the DAC I am using. It can be seen by "googling ES9023 data sheet". I have a budget of up to 500 to do this (or at least get it to testable point). If you can work on it and prefer to remain anon as far as the forum goes, that is fine too, just shoot me a message in pm.
    The goal is to initially play back 16bit stereo wave files from SD. After that gets up and running I want to have the option for 24bits, the DAC wants padded values if less than 24 bits is sent. I will send out the board to someone ( if that can be arranged ) when I have one ready, but without some method to test the DAC, I am not sure how to know if the board works on the clock and DAC section.
    In case someone is interested, here is the plan:
    A PLL1708 clock will generate a master clock which is output on any of 4 outputs, the clock itself will need an SPI driver to configure the clock and outputs.
    The master clock pins SCK00 and SCK01 feed a highspeed OR gate, that feeds the DAC. The clock outputs SCK02 and SCK03 feed an OR gate that goes back to the Prop in case that method warrants testing, else the PASM will generate the 44.1k timing for data output.
    The board has configurable sections, but those are not important at the moment until some audio will play, then I can sort out how well the audio section worked out.
    There are other simple details but that can wait.
    The board is multi purpose, RTC and data logging, it will receive serial commands from a master controller board with simple opcodes to tell it what to do. I did include 3 buttons that can be used just for testing, then I will write the SPIN code to parse incoming instructions. I can't use a method that requires the files to be stripped of anything. I need a client to be able to load on a file based on some naming criteria only, then the file can be selected by a number from the main board. IE 5000.wav 5001.wav etc.
    I did include a Prop DAC output and will want to compare both options on the board.
    Sorry, can't seem to get a non blurry schem to show up, the site is compressing to much.
    1024 x 379 - 112K
    1024 x 888 - 149K
  • richaj45richaj45 Posts: 179
    edited 2014-01-14 13:01
    @T_Chap
    I am wondering how is the PASM code going to sync up with the I2S DAC?
    Is the master clock from the PLL going to a Prop pin and then through counters to generate the Left/Right clock (LRCLK) and bit clock (BCLK) that the PASM code will monitor to know when to send out data bits?
    If so, then maybe overclocking the Prop, maybe 100MHz, to reduce sampling jitters caused from the PASM waiting for a LRCLK edges.
    I have done this stuff in Verilog RTL which had no jitter problems since the flops were synced to the bit clock.
    Sound like much fun.
    cheers,
    rich
    edited 2014-01-14 13:09
    To be honest, some of that is TBD. I have the PLL1708 clock routed to the DAC, but I also routed the other clock outputs (slower clocks) to the Prop in case I wanted to have an option to read clocks in. I have contacted the company for the DAC ES9023 to see if it would really be required to sync the master clock to the PASM code as well, waiting to hear. I am hoping to find a way to not have to use the external clock in the PASM, but rather just generate the LRClk, bit clock, and Data only with the PASM generating the timing. The DAC boasts jitter free operation. I think it will be a lot of fun.
