Multiple Props integrated on same card — Parallax Forums
DoofusDoofus Posts: 28
edited 2013-06-01 03:01 in General Discussion
Is there a card available that hosts a number of Prop I chips?
just asking.....
    edited 2013-05-29 15:12
    Is four Propeller chips good enough?
    I think I ordered five of Jazzed's boards. Most have been cut into small single or double Prop boards. I still have a few with all four Propellers waiting to be used in some awesome project.
    While I haven't found many applications for four Propeller chips, I frequently use two Propeller chips in projects. The second Prop is usually a graphics slave controlling a touchscreen.
    edited 2013-05-30 01:40
    It really depends on what you require with those props. I use 2 and 3 prop pcbs.
    I like to use solderless breadboards. With several connected together, they can host 100 or more Propeller chips. Using the DIP form factor, if one goes bad, it's easily replaced.
