Newbie In Need Of Help - Working with HC-SR501 Pyroelectric Sensor
Hello, newbie here.
I am working on a project in which I can use some help from the pro's!
I have a HC-SR501 Pyroelectric sensor. I want to create a simple circuit that runs off 9v. Objective is that once sensor detects, it sends "power" to a micro heating element....senor to remain on constant...
In regards to heating element, I am currently using 26 gauge Nichrome wire...I have no other knowledge on a heating element in which will work for my application as I need heating element to either burn out in 3-5 seconds or turn off in this time....or sensor to turn off in that time frame, closing power off to the heating element.
In regards to sensor, I am uncertain if this will even work for my application. I purchased it because of cost (cheap). I need sensor to work in all lightig applications and in darkness...I did pick this sensor because I believe sensor output range is adjustable in which is something I need...
Thank you very much for your input, time and help in advance; it is greatly appreciated
I have attached sensors specs.
I have purchased a few of these to experiment with.
I am looking for sensor to heat up an element once activated.
Heating element will need to shut off or burn out rather quickly...
So I would not put something that uses more than 20mA, and buring up a wire sure use more power.
So go with the NPN curcuit they show, and your wire will be the J part.
You would need 1.58amp to get the wire to 204celcius.
