Programming Multiple Props — Parallax Forums
StephenMooreStephenMoore Posts: 188
edited 2013-10-20 15:44 in Propeller 1
I am using Beau Schwabe's High Speed Prop server code to run a state machine on 5 props. One of the biggest problems is constantly switching serial port connections to make changes on each processor. Is there a way to run multiple instances of the Propeller Tool to dedicate the programmer tool to each processor?
    edited 2012-12-07 18:51
    Edit\Preferences\Files & Folders(tab)\Associate files launch into single editor(uncheck box)
    Edit\Preferences\Operation(tab)\Communication\Serial Port Search (I'm not sure what you do here, but I think this is where you can specify a serial port to use.)
  • StephenMooreStephenMoore Posts: 188
    edited 2012-12-07 19:03
    Thanks. Glad it was simple.
    edited 2012-12-07 21:14
    Acutally I still am unable to startup multiple instances of the Propeller Tool even with Associate Files Launch into Single Editor unchecked.
    I am running Windows 7.
    Is anyone else able to?
    edited 2012-12-07 21:18
    I'm on Windows 7 and I have two instances open right now.
    I usually open the Prop Tool by double clicking on the Prop Tool's desk top icon.
    Did you save the changes you made to preferences? (I forgot to tell you to click "Accept".)
    edited 2012-12-07 22:14
    Sorry... it is indeed working if I click from the desktop.
    Appreciate your help.
    This simplifies dedicating a COM port to a given prop.
    On this same subject, you wouldn't by chance know of any control-messaging schemes already setup for multi-prop programming.
    I am using a system of command registers and status registers. Each prop has its own dedicated write space in a ring buffer of 500 longs.
    It works great but I was wondering if anyone had proposed a sort of "OBEX" standard protocol for this sort of thing.
    Again thank you,
    sm
    edited 2012-12-08 07:27
    Stephen,
    You're very welcome.
    I know Prop to Prop stuff get talked about time to time on the forum. While I'm sure there are many more threads dealing with this topic, I've only have two of these threads linked to in post #5 of my index.
    The only trick I'd add is to use upper EEPROM to store an ID number so all Props can be loaded with the same code and each will know what it's to do based on this number.
  • rs4734rs4734 Posts: 1
    edited 2012-12-19 09:50
    Hello all... I came out here looking for a thread dealing with multiple USB Platform boards talking to each other with minimal synchronization code (if any) and found this thread on programming multiple props at once so I thought I'd try it because I'm doing two at once currently and it worked great. I am, however, running a verrrrry old version of Windows (Windows XP home) and my Propeller tool is 1.2.7 (R2). I did notice that one must be very careful to keep track of which com port number is being used by each or the right program code will be downloaded to the wrong board. I'm currently working on a multi-board control schema for my robotic mower and found that the eight cogs would not be enough due to the number of sensors required but the real scale-tipping issue was the A.I. (artificial intelligence) I want to put into the mix. (rs4734@hotmail.com)
    edited 2012-12-19 10:09
    rs4734 wrote: »
    One method I use to keep one Prop board from receiving downloaded code is to use the Parallax Serial Terminal to block the com line. Use Prefs...\Function(tab)\(uncheck)Automatically disable (close port) when application is inactive.
    By making the above change, the terminal will keep the Prop Tool from using that particular com line. Of course you can also configure the Prop Tool to only use one specific port.
    You lawn mower bot sounds very interesting. I hope you start a thread about it.
    edited 2012-12-19 11:43
    rs4734,
    I followed the above advice and am able to program as many props as necessary with separate instances of the Propeller Tool v 1.3.2. The HS comm program works great. I am still hoping to come up to speed on it myself and maybe condense it into one COG looping between transmit and receive. Each Props' own register space would of course have to be defined and configured before the COGINIT is ran.
    My 5 prop controller runs and appears to have a block of 500 longs available to all processors in real time.
    Another item I would like to work on is adding a "programming Prop" which does nothing more than load the other Props eeproms with their source code. An alternative might be to use a large Flash RAM for all of the code for all processors.
    My thanks goes out to Beau for his very handy interfacing code.
    Also, I am told to go to FORTH as a means to accomplish enhanced system development... right now I am on the learning curve.
    sm
    edited 2012-12-19 11:50
    rs4734,
    Are you launching the Prop tool then selecting each serial port for the board you want to program? One thing I would like to see if you can set the COM port from the command line or startup icon. That way you can have a desktop icon to launch an instance of the Propeller tool for each board you want to program. It would save time whenever you want to launch the Prop tool. In my case I just leave the propeller boards connected to a hub and then there is just one USB connection to make to the PC.
    edited 2012-12-19 13:21
    I am using an USB hub too and I launch each instance from separate folders for each Prop. It helps a little to keep things straight.
    I have made resistor network cables for the prop to prop and also have actually made a custom resistor network board for prop to prop comm.
    I did it in DipTace but it won't let me upload the file so I included a .dxf.
    edited 2012-12-27 21:46
    I have been using a High Speed Prop to Prop object written by Mr Beau Schwabe of Parallax. The object is fantastic!
    However, I found that to continuously pass variables between props without overwriting RAM, it required two cogs: one cog to coordinate the prop specific data moves into the ring buffer and the HS cog itself.
    So, I took the liberty of modifying Mr. Schwabe's object.
    The attached demo shows how the new object works (very similar to the original). It now contains both RX and TX modules in the same cog and makes provision to protect user memory within the ring buffer.
    For my application of industrial CNC control this will free up 1 cog on each of 5 Props (by my math 5 cogs total). This is really significant. It also eliminates the requirement to duplicate the ring buffer memory to prevent overwrites, so in my instance I save 500 longs on each of the Props for a total of 2500 longs of RAM, again very significant.
    This program is essential for our plans to build powerful low cost adaptable controllers for a range of industrial manufacturing processes. The ease of software development with this approach has saved us over 1500 man-hours in 2012.
    Thanks Parallax!
    sm
  • MicksterMickster Posts: 2,904
    edited 2012-12-28 08:33
    This 5-Prop CNC controller sounds very interesting!
    • Is it G-code driven only or can it be commanded for point-to-point positioning?
    • Closed-loop servo system or stepper?
    • Do you have velocity profiling such as trapezoidal or s-curve?
    • If closed-loop servo, do you have full PID, Feed-Forward, Deadband, Offset, etc.?
    Mickster
    edited 2012-12-28 12:18
    It is all custom stuff. No G-code but similar. There several closed loop digital stepper control algorithms employed.
    I am currently working on a pass through bootloader that will allow me to program the whole Prop array from one interface. Do you have any experience with that particular item?
    I am told to go to FORTH but it seems like a solution could be had in SPIN/PASM alone if I use something like a C3 board with a large amount of programmable FLASH ram.
    The goal is to designate one Prop as the master controller capable of distributing tasks to the COG collective. I know others have worked extensively in this area but I can't quite put my hands on a good starting point.
    The HS prop to prop comm is as close as I have gotten so far.
    sm
    edited 2012-12-28 13:23
    I currently build CNC controls (no G-code) where the HMI is an Android tablet. This aluminum-cased 'rugged-ized' device makes for a very flexible and portable user-interface and our users are loving it. However, the machine control is actually performed by a dedicated servo motion controller which simply receives program data from the Android device and provides status updates back to the device via Bluetooth. I am looking at simplifying the installation and part of the plan is to use my own motion controllers based on the Prop. By simplifying I mean distributing the intelligence. We can have 20+ axes which results in expensive cabling, etc.
    I have the encoder quad-decode working and it appears to be good for > 1.5M counts per second. The PID and Feed-forward, etc. is no biggie but I'm now looking at the velocity profiling (trapezoidal for now).
    A "standard" for me is to utilize dual-loop feedback wherever a transmission (gear-reducer, etc.) is employed, meaning that I have position feedback from the motor and also the load so I will probably end-up with one physical axis per Prop (one motor command output + two encoder inputs) and the ability to also run virtual axes. I am thinking that 115.2Kbaud will be more than adequate for Prop-to-Prop comms.
    Language of choice for me thus far is PropBASIC as it is the most readable language available for the Prop and outputs pure PASM. Can't wait for the P2 as its counters are supposedly configurable for direct quad decode....I wonder what kind of frequency to expect :)
    Mickster
    edited 2012-12-28 14:15
    Sounds really good.
    We use Gecko stepper drives and magnetic encoders with some degree of success. Right now we are not doing torque/current feedback control but have considered it. You have a pretty sophisticated setup going.
    We are very impressed with the ability to distribute control as needed with the HS prop to prop communication scheme. We have eliminated large interrupt driven coding schemes. When we add machine functionality we simply add COG as necessary.
    Do you guys have a website?
    sm
    edited 2012-12-28 14:54
    Website: www.adaptivemotion.com
    We started work on this mid-January 2012. It was on the market by June and is selling very well. The first stage was to test the concept/acceptance of the tablet HMI. Encased in billet aluminum, it feels amazing and well suited to the factory environment. The cool thing is that; should you need to replace it, you can get one anywhere. Set the new one up with the appropriate email account and, automatically, the app for that very machine along with cloud-backed-up data and parameters are loaded instantly....try that with an Allen Bradley or whatever :)
    Mickster
    edited 2012-12-30 21:18
    I have assembled an array of 4 props consisting of a Propeller Professional Development Board with two additional 40 pin Props on the breadboard and also a C3 board. All 4 of the props are joined with an HScomm bus.
    The two additional prop chips and the C3 board are all programmed through the PPDB chip using Chip Gracey's LoadPropeller object. It requires 9 pins on the programming chip but I only use one USB port to program all four props. After I am done programming, the programming prop itself joins the prop network as a functioning processor. It also serves as a serial port pass through for debugging each prop with a single instance of Parallax Serial Terminal interface.
    The program I am using looks like this:
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    'Propeller enumeration
      #1, C3, Prop1, Prop2
    'Programming pin definitions
      #2, RESn1, RX1, TX1
      #5, RESn2, RX2, TX2
      #8, RESn3, RX3, TX3
      Prop = C3
    '  Prop = Prop1
    '  Prop = Prop2
    OBJ loader : "PropellerLoader"
    DAT
            loadme file "server.binary"
           ' loadme file "client1.binary"
           ' loadme file "client2.binary"
    PUB LoadPropeller
      case Prop
       C3:
        loader.Connect(RESn1, RX1, TX1, 1, loader#ProgramRun, @loadme)
       Prop1:
        loader.Connect(RESn2, RX2, TX2, 1, loader#ProgramRun, @loadme)
       Prop2:
        loader.Connect(RESn3, RX3, TX3, 1, loader#ProgramRun, @loadme)
    My question is this. Has anyone found a good way to do conditional compilation so that I can automatically select the appropriate load file and programming pin selections?
    As it stands, this system does simplify program loading versus fumbling around with four separate USB connections.
    sm
    edited 2013-01-01 21:26
    One final update to this post...
    I realize everything I've tried to develop here has been re-inventing the wheel but...
    I used the PropLoader object as a means to program a network of props. As a point of information, the props are connected with the HScomm object which I condensed to one cog (both TX and RX) which runs without input from any other cogs, but the PropLoader object works through pins RESn, P30 and P31 for each prop. One propeller is dedicated as the programmer chip and is connected to each propeller programming interface (8 props max = 24 pins). After it is done programming it is loaded with any other program to work within the network (e.g as a math co-processor, serial interface for debug, etc)
    I wrote a program in LabView to call various functions from the Propellent.DLL file. First it compiles the desired propeller program and then compiles a dedicated PropLoader program for the affected prop and downloads that program to the loader Propeller. Finally it reloads the loader Propeller with its regular spin program. All of this is done with one mouse click. I have attached the LabView vi if anybody is interested. The net result is you simply make edit changes to your spin programs in any editor, save them and hit click in LabView. Everything happens over a single USB port and up to 8 different props get loaded with their appropriate programs.
    I am done with this little exercise and have a couple of comments to make:
    1) Interfacing multiple props seems like a real advantage and needs to be proposed in an application note in a very straight forward manner
    2) The program I wrote in LabView could be functionally available in the Propeller Tool... it is just not that complicated.
    3) Since we started using multiple propellers in our projects we have made real gains in product development. This item is by no means becoming obsolete even though the current attention seems focused on P2. I would love to see some enhancement tools made available from Parallax, Inc.
    Kindest regards,
    sm
    edited 2013-10-20 13:29
    This is an update to the multiple propeller loader program that I wrote in LabView.
    I modified the program to read the Propeller system configuration (which pins and programs are used) from a spreadsheet file (.csv). It is a lot easier to use. However, in order to run the Labview program (MultiPropLoader.exe) you must down load the Labview Run-Time Engine from the following link:
    http://joule.ni.com/nidu/cds/view/p/id/4059/lang/en
    The Run Time Engine is needed for any computer that runs a Labview Application but does not have the Development Software loaded.
    The following flowchart describes what goes on.
    If you open my PropConfig.csv with a spreadsheet program you can see where the pin and spin program definitions go. I use the spreadsheet to label all of my Propeller IO but all you need is the header section. The program adjusts for the number of Props in the system from the first entry in the spreadsheet.
    All you need to do is include your .spin programs all in the same directory and everything is managed for you during the download with just one USB connection.
    This is a Labview version but I would like to do the same thing in Python using the Propellent.dll.
    Or, maybe the author of the Propeller Tool v1.3.2 would include this programming strategy right into it.
    sm
    1024 x 736 - 78K
    504 x 182 - 30K
    Stephen: Thanks for posting. No time to look atm. I use multiple props too - makes a lot of sense to me.
