Why not lunar communications satellites? — Parallax Forums
lardomlardom Posts: 1,659
edited 2012-09-01 09:51 in General Discussion
I have developed Martian fever and I will rush home to watch streaming video of Martian rocks being vaporized.
My imagination has caused me to wonder why we don't have any communication satellites on the lunar surface? It's got to be tough to lock communications satellites into a stable position above the equator.
I think surface based devices would be simpler to locate and help manage the problem of 'space junk'. What am I missing?
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-08-21 14:35
    Because you can't keep the moon in one spot.
    http://en.wikipedia.org/wiki/Geostationary_orbit
  • W9GFOW9GFO Posts: 4,010
    edited 2012-08-21 14:39
    It takes a long time for the signal to make the round trip to the Moon and back.
    The transmitters would need to be much more powerful.
    The lunar based "satellite" would have sunlight only half the time.
    Landing on the Moon is more difficult than parking in geostationary orbit.
    edited 2012-08-21 15:01
    To receive from the moon you would need a dish that would track the moon
    The moon sets and rises, so you can only see it for half a day at a time.
    The receiver dish would probably need to be 30 feet in diameter.
  • jazzedjazzed Posts: 11,803
    edited 2012-08-21 15:07
    We should enclose the entire moon in metal shields and make the shields spin.
    The goals would be to create a "Moon Craft" with an artificial Van Allen belt to protect against solar radiation (asteroids, etc...) and artificial gravity on the inside surface. The inside surface would have moon-dust-proof bubble enclosures for maintaining atmosphere and astronomic traveller comfort. Some of the shields would have solar panels on them and spin so that they are always facing the sun.
    So the Moon Craft could serve as a communications base using an LED TV for all of earth's people rich or poor to watch Fox news. Could serve as a permanent viable space station, and then eventually a star ship. It would suck all of earth's resources, but that's ok because as the sun gets hotter in a billion years, we could launch the moon into a Mars orbit (and beyond). When the sun goes supernova, the Moon Craft could be launched into interstellar space with a sail toward another solar system that we can abuse.
    And we could probably connect a few million Propellers to it so that it can achieve self-awareness .....
  • lardomlardom Posts: 1,659
    edited 2012-08-21 15:11
    :smile: I followed W9GFO's link. Hmmm...The possibility exists that I may to go back to buying maps to find my way around!
    edited 2012-08-21 15:21
    Here's a mind blower for you: J-Track 3D. Neat Java app shows exactly where all the communications satellites and ISS are. Takes a minute to load. Click & drag on it, zoom in & out per instructions. You can easily see the low-earth orbit (incl GPS) satellites versus the ones way out in geosynchronous/geostationary orbit. Click on any dot and get more info about that satellite. Zoom way in on the low earth orbit ones and you can see them moving in real time. http://science.nasa.gov/realtime/jtrack/3d/JTrack3D.html
    edited 2012-08-21 16:01
    They could set it up in tranquility base, or is that just lunar sea?
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2012-08-21 16:29
    A simple moon based repeater could be fun for hams.
    edited 2012-08-21 16:47
    lardom wrote: »
    ...why we don't have any communication satellites on the lunar surface?
    What am I missing?
    All the conversations would be loony
    edited 2012-08-21 16:50
    The amount of stuff I learn from this forum is incredible.
    I see the point of having a geostationary satellite at 22k mi from the earth. I think there is a possible role for a lunar rover to transmit data that's not as time sensitive. I read that the orbiting satellites require fuel to correct for drift which means they have a limited lifetime. A solar powered lunar rover should have a relatively long lifetime.
    We don't have much need for moon rocks but it could play a role as a mobile communication device.
    edited 2012-08-21 17:15
    lardom wrote: »
    ...wonder why we don't have any communication satellites on the lunar surface? What am I missing?
    Moon people. There's no one on the Moon to communicate with. :thumb:
    edited 2012-08-21 17:19
    The far side of the Moon would be an ideal location for a radio telescope because all the terrestrial radio signals would be muted by the distance and the Moon itself. However you would need a satellite to relay signals to it.
  • RickInTexasRickInTexas Posts: 124
    edited 2012-08-21 17:52
    They do this using the moon as a "passive repeater", it's called moon bounce.
    edited 2012-08-21 18:13
    Will the lunar repeaters be able to boot from SD RAM??
  • bill190bill190 Posts: 769
    edited 2012-08-22 08:37
    Here is a pdf graphic of commercial communication satellites in geosynchronous orbit around the equator. This graphic can be printed out in large poster size. Just take the file to a business which does copying and also has very large printers.
    Where there are several satellites in a line, some of those are for services like Dish TV. (One satellite dish can point to one direction and receive from several satellites at the same position.)
    http://www.boeing.com/defense-space/space/bss/launch/980031_001.pdf
    edited 2012-08-22 08:44
    mindrobots wrote: »
    Did you say looney repeaters?
    edited 2012-08-22 23:53
    I never got in to Moon bounce. but I can tell ya AMSAT is really cool ! .
    I emplore every one to read the Apollo lunar surface journal .. you will be in awe the deatails that happen .
    edited 2012-08-23 20:01
    The moon also has a very irregular gravity field, so gravitational influence changes based upon the area of the moon you are orbiting, so average orbits are consistent, but where you are during each orbit varies considerably.
    edited 2012-08-23 22:30
    Some reasons I can think of to not do one:
    Latency is higher.
    Expense of deployment / low returns in general. The current plan to put a telescope at L2, for example, makes a lot more sense. Way more good science to get at from there than from around the moon.
    High availability requires complexity compared to geosynchronous sats here. Would need complex hand-offs to be always on. Seems to me just putting stuff on the moon itself would be better in this respect. One or both of the Google founders has talked up using the moon as a data center. (Brin and Page) I like that idea more than I do a satellite system. Kind of cool too. If we were to ever really botch it here, the data would be there waiting for us to boot strap ourselves up to the point of being able to make use of it, assuming the engineering worked on those time scales. As an idea, it's pretty out there, but strangly plausible and compelling to me.
    Moon is close enough to observe in high detail here, or from our orbiting sats. True, we don't get a good look at the dark side. Seems to me, that's a possible case for a lunar observation type satellite. Not sure what there is to look at though. In any case, it could just queue it's data, sending when it's possible to do.
    edited 2012-08-24 05:34
    @potatohead, I'm glad you referenced the Google founders. I don't feel so bad now. A 'data center' on the lunar surface makes sense to me. I would go so far to argue that latency and 'handing off' are non issues. They would not provide the same services as orbiting sats so queuing data would be fine.
    I've discovered that geostationary sats require fuel to adjust for drift which means they have a limited lifetime. That could be an issue in a bad economy.
    In another thread erco suggested a solar powered robot-base from which smaller more agile robots could recharge and get their marching orders. I think that's a great idea.
    edited 2012-08-24 06:50
    Just curious, does anyone know what the time dilation is between the Earth and the Moon? I mean you cant just base your answer on the speed of light and the average distance of 382km that separate the Earth and Moon... which would come out to about 1.27 seconds, The masses of the Earth and Moon also play a part in the dilation of time between them that needs to be calculated into the equation as well, so I imagine it would be a bit different. Also the distance between the Earth and Moon varies by about 50km adding an approximate 167ms difference in time.
    edited 2012-08-24 07:34
    lardom wrote: »
    More specifically, a mobile robot base. IIRC the Sojourner rover used its stationary base as a relay station, but that meant it couldn't stray too far away from home base.
    edited 2012-08-24 07:51
    If I remember correctly, GPS satellites' time difference is sped up by the effects of less gravity and slowed down by their higher velocity. The velocity effect is much greater than the gravity. If these differences in time weren't accounted for then GPS fixes would drift by a few miles each day.
    I would guess that the time dilation for the Moon is much, much smaller than for GPS satellites. Its velocity relative to Earth is quite slow. Since mass and velocity have opposite effects on time, and the Moon is slow (3,500 km/hr) yet 1/6 the mass of Earth, my gut says that they would come close to canceling each other out.
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2012-08-24 08:02
    Hi Beau;
    The rule of thumb is 2.5 S round trip.
    Relativistic time dilation due to gravity is vanishingly small.
    The signals travel at very very close to the speed of light.
    So, distance variations are by far the most significant factor in the delay time.
    (Ok, there is some delay in the transmitter and receiver but that should be fixed.)
    (Also, though not called time dilation there are significant Doppler frequency shifts
    caused by the motions of both the Moon and Earth, mostly the Earth.)
    Duane J
    edited 2012-08-24 11:47
    The soviets actually put two solar powered rovers on the Moon, and drove them around for months: http://en.wikipedia.org/wiki/Lunokhod_programme
    An interesting wrinkle is that anything on the surface of the Moon is in the dark two weeks at a time, so the lunokhods had lids that could hinge shut and nuclear heat sources -- not power, but just to keep the electronics within temperature spec during the long cold lunar night.
    edited 2012-08-24 12:07
    For obvious reasons in those days it would never have happened but just imagine if we had the international co-operation we have these days then how much information could have been collected and how advanced as a species we could be today?
    I'm sure we'd be living on the moon at least by now in spite of those that put financial obstacles in the way.
    Had all that money not been wasted on the cold war.
    edited 2012-08-24 15:20
    Yeah, 2.5s RT is about right, I was reading about a moon bounce experiment between two stations on opposite sides of the globe and it was 2.6 seconds.
    BTW NASA has a Lunar Reconnaissance Orbiter that has capabilities for an RF communications link for future lunar missions. It is pretty cool, gathering images and other data and sending It back to terrestrial receivers.
    http://www.nasa.gov/mission_pages/LRO/main/index.html
  • TorTor Posts: 2,010
    edited 2012-08-25 04:20
    W9GFO wrote: »
    If I remember correctly, GPS satellites' time difference is sped up by the effects of less gravity and slowed down by their higher velocity. The velocity effect is much greater than the gravity. [.. ]
    It's the other way around, surprisingly - about -7.2 ns/day special relativity time dilation, and +45.8 ns/day general relativity time dilation. Added together the GPS satellite's clock gains approximately 38.6 ns/day, according to wikipedia, and also this article (PDF): GPS essay
    As for Beau's question, it was asked in this physicsforums' thread, and although the thread doesn't contain the actual numeric answer it does contain the equations.
    -Tor
  • MoskogMoskog Posts: 556
    edited 2012-08-25 08:11
    ...average distance of 382km that separate the Earth and Moon... ...the distance between the Earth and Moon varies by about 50km...
    Could almost touch it! If we speak metric here you should add another 3 zeros to the numbers. But I'm sure you knew that.
    edited 2012-08-25 10:11
    Moskog,
    Boy, that would fill the night sky wouldn't it? ... yes and additional 3 zeros - lol
