VHF Transceiver based on Propeller
Hello,
I'm a radioamateur, I finished building my new 2m Transceiver based on a Propeller CPU.
The circuits are ready and working ... now I need only to start building the enclosure.
The radio is working really fine, it uses a propeller as main controller. The prop controls:
- the frequency setting through a PLL;
- the signal strength using an ADC;
- the power supply of the modules;
- the status of PLL lock;
- the status of muting;
- the LCD display.
The software is under development. The main functions are already implemented.
I attached the image of the circuits, the schematics and the source code.
Soon, I'll write a complete document with details.
bye
Paolo
iz0roo@fastwebnet.it
RT2m.SPIN
- the LCD display.
bye
Paolo
AD7YF
Thanks for your appreciation :-)
I attached the PDF files as you requested, I hope you'll read it better.
bye
PaoloCPU1.pdfCPU2.pdfCPU3.pdfRX.pdfTX.pdf
This is a narrow band FM transceiver on 2m band (144-148 Mhz). The microphone is connected to the PLL circuit , it is not connected to the propeller.
Thanks for the PDFs! They're much clearer.
If Parallax should be interested in making a kit I would be glad to provide any information and details.
Next step .. add SSB for DX and bam ! you will have ICOM outta biz in a month .
Iam serious
Peter
73 de la1rha
Ah, I can see the microphone pad on the PLL circuit - but there's definitely one on the CPU circuit connected to P21 - the same one or a circuit change?
I corrected the schematics and attached the new version.
The propeller is connected to the PLL through the A21 pin labeled "M-A21(CPU/2)" in order to produce and send on air the subtones. I still have to write the source code that plays sub tones.
