[PUZZLE] Binary-to-decimal Golf Challenge (fixed; please retry) — Parallax Forums
edited 2012-05-19 02:19 in Propeller 1
A couple recent threads,
got me thinking about the quickest way to convert a 32-bit binary value to decimal in PASM. This makes for an interesting (to me anyway) golf challenge. So I created a framework for a contest to see who can come up with the quickest PASM program to take a 32-bit long and convert it to ten decimal ASCII digits, including leading zeroes. Here's the program framework, into which I've embedded my own entry:
***************** bin2dec Golf Challenge *******************
               DO NOT MODIFY ANY SPIN CODE,
except _clkmode and/or _xinfreq, if needed for your platform.
CON
  _clkmode      = xtal1 + pll16x
  _xinfreq      = 5_000_000
OBJ
  pst   : "Parallax Serial Terminal"
  num   : "Simple_Numbers"
VAR
  long state, binary, time
  byte decimal[11]
PUB  start | seed, value, best, worst, sum, n
  cognew(@bin2dec, @binary)
  pst.start(9600)
  pst.str(string("bin2dec code size: "))
  pst.dec((@end_code - @begin_code + @end_var - @begin_var) >> 2)
  pst.str(string(" longs", 13))
  n~
  sum~
  best := $7fff_ffff
  worst~
  repeat 1000
    seed := rand(seed)
    value := seed
    repeat while value
      binary := value
      repeat while binary
      if (dec2bin(@decimal) == value)
        best <#= time
        worst #>= time
        sum += time
        n++
      else
        pst.str(string("Error", 13, 13, "Input  = "))
        pst.str(num.decx((value >> 1) / 50_000, 5))
        pst.str(num.decx((((value >> 1) // 50_000) << 1) | value & 1, 5))
        pst.str(string(13, "Output = "))
        pst.str(@decimal)
        'repeat
      value >>= 4
  pst.str(string("Success after "))
  pst.dec(n)
  pst.str(string(" tests.", 13, "Number of instructions needed per conversion:", 13, "  Best:  "))
  pst.dec(best >> 2)
  pst.str(string(13, "  Worst: "))
  pst.dec(worst >> 2)
  pst.str(string(13, "  Avg:   "))
  pst.dec((sum / n) >> 2)
PUB rand(r)
  case state++
    0: return 4_199_999_999
    1: return 3_999_999_999
    other: return ?r
PUB dec2bin(str_addr)
  repeat 10
    result := result * 10 + byte[str_addr++] - "0"
DAT
bin2dec       mov       time_addr,par           'DO NOT MODIFY.
              add       time_addr,#4            'DO NOT MODIFY.
              mov       dec_addr,par            'DO NOT MODIFY.
              add       dec_addr,#8             'DO NOT MODIFY.
main_lp       rdlong    x,par wz                'DO NOT MODIFY.
        if_z  jmp       #main_lp                'DO NOT MODIFY.
              neg       timer,cnt               'DO NOT MODIFY.
begin_code                                      'DO NOT MODIFY.
'-------[Begin Your Golf Code]-------------------------------------------------
'       Upon entry, x contains a 32-bit binary value, and
'       dec_addr contains the hub address of the first byte of the result string.
'       Your golf code must write ten ASCII digits to the result string.
              movs      :ld_comp,#second_comp   'Number is less than 8 billion, so start with 4 billion.
              mov       comp,first_comp
              mov       ndigits,#10             'Do ten digits.
              mov       digit_addr,dec_addr     'Initialize digits hub pointer.
              mov       digit,#"0"              'Initialize first digit.
              jmp       #:start                 'Jump into compar routine for "4".
:digit_lp     mov       digit,#"0"              'Initialize next digit.
              cmpsub    x,comp wc               'Is most-significant digit at least 8?
        if_c  add       digit,#8                '  Yes: Add 8.
              shr       comp,#1                 'Divide compare value by 2.
:start        cmpsub    x,comp wc               'Is most-significant digit at least 4?
        if_c  add       digit,#4                '  Yes: Add 4.
              cmpsub    x,comp wc               'Is most-significant digit at least 2?
        if_c  add       digit,#2                '  Yes: Add 2.
              cmpsub    x,comp wc               'Is most-significant digit at least 1?
        if_c  add       digit,#1                '  Yes: Add 1.
              wrbyte    digit,digit_addr        'Write the digit to the string.
              add       digit_addr,#1           'Increment digit pointer.
:ld_comp      mov       comp,0-0                'Get next compare value.
              add       :ld_comp,#1             'Increment to point to next compare value.
              djnz      ndigits,#:digit_lp      'Go back for next digit.
'-------[End Your Golf Code]---------------------------------------------------
end_code      add       timer,cnt               'DO NOT MODIFY.
              wrlong    timer,time_addr         'DO NOT MODIFY.
              mov       x,#0                    'DO NOT MODIFY.
              wrlong    x,par                   'DO NOT MODIFY.
begin_var                                       'DO NOT MODIFY.
'-------[Begin Your Golf Variables]--------------------------------------------
first_comp    long      4_000_000_000           'Initial digit compare values.
second_comp   long      0_800_000_000
              long      0_080_000_000
              long      0_008_000_000
              long      0_000_800_000
              long      0_000_080_000
              long      0_000_008_000
              long      0_000_000_800
              long      0_000_000_080
              long      0_000_000_008
digit         res       1
comp          res       1
ndigits       res       1
digit_addr    res       1
'-------[End Your Golf Variables]----------------------------------------------
end_var                                         'DO NOT MODIFY.
x             res       1                       'DO NOT MODIFY.
dec_addr      res       1                       'DO NOT MODIFY.
time_addr     res       1                       'DO NOT MODIFY.
timer         res       1                       'DO NOT MODIFY.
Here are my results:
bin2dec code size: 33 longs
Success after 7916 tests.
  Best:  204
  Worst: 204
  Avg:   204
Obviously, I could have unrolled the loop for even more savings, but the program would have grown too large to be practical. Anyway, recognition will be given for minimizing the worst and average values. Please use the framework attached for the fairest comparisons.
Good luck!
«13
  • jmgjmg Posts: 15,200
    edited 2012-05-01 17:17
    Nice idea - you should add a couple of labels, so the SIZE of the code can also be tabulated. (and such size should include any tables, if used)
    edited 2012-05-02 21:50
    Here's my first pass results...
    Phil's Golf Challenge
    Success after 8000 tests.
    Best: 135
    Worst: 243
    Avg: 184
    (Phil's 204, 204, 204)
    I used Phil's code as the base, and kept the labels the same where possible.
    You will note the changes that I had to do...
    1. remove the local labels (i.e. remove the ":")
    2. add a delay when the program starts, plus a message "Phil's Golf Challenge".
    3. I use 6.5MHz xtal but the results will be the same since we are counting clock cycles.
    Don't peek if you are attempting the challenge ;)
    bin2dec_golf_cluso[1].spin
    edited 2012-05-02 22:31
    Excellent work, Cluso99! I like the way that you've reduced the average instruction count.
    BTW, is anyone here familiar with the "double dabble" algorithm? It's the gold standard for converting binary to BCD in hardware logic, gate arrays, etc. But a quick perusal left me with the impression that it would not be efficient to implement on the Propeller.
    edited 2012-05-03 02:26
    Thanks Phil. I have never seen the double dabble algorithm.
    I may have a go over the w/e, Think it will use quite a bit of code though.
    In real life, the program could be sped up by finding the first significant bit, because the expectation would be that the number would likley not be random, and hence more often much less than 10 significant digits.
    My programming on minis was on a computer that was fully decimal... Yes, memory was decimal, and so were the instructions, so a multiply was 1-10 digits by 1-10 digits (both in decimal) and the result was stored in the B operand for a length of a+b so no overflow was possible. Caveat was to ensure the B had a length reserved of a+b. Division was the reverse. Even the instructions were 10 bytes!
    My programming in micros never really dealt with large numbers. Just lots of interfacing, comms protocol conversions, modems, etc.
  • BeanBean Posts: 8,129
    edited 2012-05-03 05:09
    Phil,
    I made a slight improvement to your original code. If the digit is 8, then it skips down to test for 1 since the digit cannot be larger than 9.
    I get a best of 192, worst of 204, and avg of 200.
    I had tried the double dabble awhile back, took too much code and was not faster on the propeller.
                  mov       comp,first_comp
            if_c  shr       comp,#3                 ' [TH] If digit was 8, skip to test for 1 (can't be 4 or 2)
            if_c  jmp       #:digit_1
    :digit_1      cmpsub    x,comp wc               'Is most-significant digit at least 1?
    Bean
    [EDIT] With new version I get Best=168, Worst=204, Avg=200
    edited 2012-05-03 06:45
    Here is a version optimized for code SIZE (pretty important on the propeller).
    This is only 17 instructions + 2 longs of data.
    Timing is best=146, worst=306, avg=214
                  mov       digit,#"0"
    :first_digit
                  cmpsub    x,first_comp wc, wr     ' Do first digit as special case
           if_c   add       digit,#1
           if_c   jmp       #:first_digit
    :next_digit
                  mov       digit,#"0"
    :next_digit_loop
                  cmpsub    x,second_comp wc, wr
           if_c   add       digit,#1
           if_c   jmp       #:next_digit_loop
                  mov       comp,x                  'x = x * 10
                  shl       x,#2
                  add       x,comp
                  shl       x,#1
                  djnz      ndigits,#:next_digit    'Go back for next digit.
                  jmp       #:main_lp               'DO NOT MODIFY.
    first_comp    long      1_000_000_000           'Initial digit compare values.
    second_comp   long      0_100_000_000
    Bean
    [EDIT] New version gives Best=134, Worst=390. Avg=206
    edited 2012-05-03 09:50
    Bean,
    'Two good contributions! Your second one gives me an idea ...
    edited 2012-05-03 10:54
    My original:
    Best: 135
    Worst: 243
    Avg: 184
    plus Bean's 8 cannot be 4 or 2:
    Best: 135
    Worst: 219
    Avg: 176
    '-------[Cluso's Golf Code]-------------------------------------------------
                  movs      next_digit,#comp1       ' setup msd comparison
                  mov       comp,comp1              ' start msd (first digit)
                  cmpsub    x,comp          wc,nr   ' digit > 0 ?
            if_nc jmp       #skip_digit             ' n: then this digit =0
                  shl       comp,#2                 ' make it a "4"
                  jmp       #first_time
    next_digit    mov       comp,0-0                'Get next compare value.
                  shl       comp,#3                 ' make it an "8"
            if_c  shr       comp,#3                 ' if 8, cannot be 4 or 2, so go straight to 1
            if_c  jmp       #digit_1                ' (thanks Bean)
    first_time    cmpsub    x,comp wc               'Is most-significant digit at least 4?
    skip_digit    wrbyte    digit,digit_addr        'Write the digit to the string.
                  add       next_digit,#1           ' setup for next msd comparison
                  djnz      ndigits,#next_digit     'Go back for next digit.
    bin2dec_golf_cluso[2].spin
    edited 2012-05-03 11:26
    Cluso,
    That is quite a remarkable improvement.
    Glad I could help :)
    Bean
    edited 2012-05-03 12:14
    Cluso99,
    Excellent! This is what I like about "crowd-sourcing": there's always a better way!
  • tonyp12tonyp12 Posts: 1,951
    edited 2012-05-03 12:42
    I have not tested it or implemented in to the time checker, but this must be the fastest way?
    DAT
                  org  0
    asm_entry     mov       temp,par   ' get 32bit binary
                  mov       mystring,allzero      'reset to allow repeats
                  mov       mystring+1,allzero    'reset to allow repeats
                  mov       mystring+2,allzero+1  'reset to allow repeats
                  movs      keepsub,#highval      'reset to allow repeats
                  movd      strpnt,#mystring      'reset to allow repeats
                  mov       loopcnt,#10
    keepsub       cmpsub    temp,0-0 wc
    strpnt  if_c  add       0-0,nibble
            if_c  jmp       #keepsub
                  ror       nibble, #8 wc
            if_c  add       strpnt, my512
                  add       keepsub,#1
                  djnz      loopcnt, #keepsub
                  jmp       $       ' result: a zero terminated byte ascii string at mystring
    highval long  1000000_000,100000_000,10000_000,1000_000,100_000,10_000,1_000,100,10,1
    allzero long  $30303030, $30300000
    nibble  long  1<<24
    my512   long  1<<9
    loopcnt       res 1
    mystring      res 3
    temp          res 1
    edited 2012-05-03 12:53
    tony,
    'Looks intriguing. Format it for the framework, and see if it works. (Otherwise, it doesn't count. :) )
    edited 2012-05-03 13:40
    Turns out that 8,4,2,1 is not the fastest...
    I also tried 4,2,2,1 and no luck either.
    This is my best so far, although I can get less spread results such as 163,179,172
    Best: 131
    Worst: 199
    Avg: 156
                  cmpsub    x,comp0         wc,nr   ' digit > 0 ?
                  jmp       #first_time
                  cmpsub    x,comp          wc      ' at least 2?
            if_nc jmp       #digit_1
            if_c  add       digit,#2                ' y: +2
            if_nc jmp       #digit_1
    first_time    cmpsub    x,comp          wc      ' at least 2?
    '       if_nc jmp       #digit_1                              'makes worse
    digit_1       shr       comp,#1                 ' divide by 2
                  cmpsub    x,comp          wc      ' at least 1?
            if_c  add       digit,#1                ' y: +1
    bin2dec_golf_cluso[7].spin
    edited 2012-05-03 14:32
    Cluso,
    Wow! That's a really nice (and surpising) result. I would not have guessed that 2,2,2,2,1 would beat 4,2,2,1.
    edited 2012-05-03 14:54
    Cluso,
    Yes, that is surprising. But I'm thinking it is because as soon as it fails any of the "2" tests, you can jump right to last "1" test.
    Bean
    edited 2012-05-03 15:29
    Since this is building an ASCII string, how about adding options for
    a) Leading Zero suppression (Integer)
    b) Leading Zero Suppression, with a user defined decimal point. The string would include a decimal point
    eg "0.01234"
    Sign is probably easiest managed outside the conversion, as well as units append.
    Given the length is now more dynamic, a null append would let the caller manage this.
    edited 2012-05-03 15:50
    jmg,
    'All very good ideas for a finished product, but not part of the puzzle's core. You seem to like suggesting things for other people to do, but why not join the fun and contribute a solution of your own? :)
    edited 2012-05-03 16:02
    It's too bad there isn't an easy divide by 10 using minimal iterations on a 32 bit binary.... it can be done, but you don't save any code or clock cycles.
    edited 2012-05-03 16:05
    It's too bad there isn't an easy divide by 10 using minimal iterations on a 32 bit binary ...
    You mean like multiplying by $1999_9999? :)
    edited 2012-05-03 20:00
    Phil: Yes, I was really surprised. I thought your 8421 with the few jumps would be fastest.
    But I couldnt sleep last night so I was just mulling over the loop in my semi-sleep mode and added the instructions for the 22221 loop and they were shorter by a couple of instructions. With the extra jmp out to 1, that clinched the deal. Of course, the worst rose as the average shrunk. I did get a 163,179,172.
    BTW I tried tony's solution but didn't get it to run. Maybe something I did, or something he left out. It certainly looks intriging with a lot of short loops.
  • CogSaverCogSaver Posts: 17
    edited 2012-05-05 20:41
    My version (unrolled, and using constants for all "cmpsub's") gives the following result :
    Best: 119
    Worst: 119
    Avg: 119
    CogSaver
    edited 2012-05-05 20:47
    'Looks good. Can you post the code, please?
    edited 2012-05-06 10:26
    Here is my final version, I went for execution speed at the cost of program size,
    probably not the most elegant solution, but it gets the job done.
      Best:  83
      Worst: 83
      Avg:   83
    I also noticed that the Hub access window comes into play for some potential
    minor improvents when writing back the ASCII string.
    File :
    bin2dec_golf_V2.spin
    The sequece of numbers generated seems to repeat itself, and higest digit
    never goes above 1. (Hence the commented out lines in my program)
    With the lines uncommented the timing jumps up to 87 instructions.
    For reference the numbers that are generated is a repeat sequence of
    1358954497
    0084934656
    0005308416
    0000331776
    0000020736
    0000001296
    0000000081
    0000000005
    CogSaver
    edited 2012-05-06 13:34
    CogSaver wrote: »
    Best: 83
    Worst: 83
    Avg: 83
    and the code Size, including tables ?
    CogSaver wrote: »
    The sequence of numbers generated seems to repeat itself, and highest digit
    never goes above 1.
    1358954497
    0084934656
    0005308416
    0000331776
    0000020736
    0000001296
    0000000081
    0000000005
    Well spotted, seems a poor test pattern.
    Given all code is using CMPSUB, I'll nominate values of 4199999999 and 3999999999 be added to the test values.
    edited 2012-05-06 14:32
    Not so much a poor test pattern as buggy test code. I realized early on that just sending it ?seed values was not going to cover very many small values. That's when I added the repeating shift, but it was an incomplete conversion. In the process of fixing that, I discovered a bug in the Simple_Numbers library object, which I had to work around. After that fix, I realized that it would now be possible to incorporate numbers above $7fff_ffff (I.e. < 0), which I have now done. However, the error report for these numbers, if there is an error, will not show the proper input number, since it still relies on Simple_Numbers.
    Anyway, a corrected version of the program now appears in the top post. It also reports the combined program and table size, but without including any res variables.
    BTW, jmg, I'm still waiting to see an entry from you, since you seem so keenly interested in commenting on this thread.
    edited 2012-05-06 15:00
    Why the focus on an entry from me ? - is competition entry now a condition of posting in the forum ?
    - I do have an interest in Binary to Decimal, (and the logical practical extensions, of leading zero suppression, and decimal point handling) but I'll leave the finer code shuffling to the PASM experts.
    My comment "Given all code is using CMPSUB, I'll nominate values of 4199999999 and 3999999999 be added to the test values" still stands, especially for those cases using jumps.
    If you try to report a MAX, I'm surprised these values are not mandated in the tests ?
  • Mark_TMark_T Posts: 1,981
    edited 2012-05-06 15:05
      Best:  91
      Worst: 91
      Avg:   91
    Basically I missed CogSaver's little trick with the last digit. Not sure that degree of unrolling is particularly good news on the Prop(!)
    edited 2012-05-06 16:54
    I fixed the error reporting for values > $7fff_ffff. I've also forced 4_199_999_999 and 3_999_999_999 into the beginning of the mix, although it's not clear what their significance is. Those who have already entered, please plug you code into the new template from the first post and try again.
    edited 2012-05-06 17:25
    Cool. How this matters, depends on the code.
    If you look at #14, which uses jumps to skip adds, the MAX path on that is now number dependent, so it ideally needs tests for the most adds. (so least skips) - which may not always be a lot of 9's.
    ie I think 9's are needed for #14, but for #9, it might be 7's - so perhaps such code should identify the worst-case-test value ?
    edited 2012-05-06 19:53
    With no modifications, other than uncommenting the lines to make it work for any "first digit" my numbers came up as follows.
    bin2dec code size: 121 longs
      Best:  87
      Worst: 87
      Avg:   87
    For completeness i figured that I make an attempt at minimum codesize with the following result :
    bin2dec code size: 22 longs
      Best:  127
      Worst: 387
      Avg:   191
    bin2dec_golfNewCS4.spin
    CogSaver
