Reading CSV files from an SD card — Parallax Forums
SarielSariel Posts: 182
edited 2011-08-23 10:18 in Propeller 1
Ok.. I have looked over the Gadget Gangster site on this very issue, but thier explanation does not really help me try and do exactly what I would like. What I am looking for is a method that will take a series of 128 binary longs that are stored in a .CSV file and dump it into a variable array (called "L[0]" to L[127]") for use elsewhere in my program. I am getting a lot of garbled data whenever I try this:
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
   DO  = 12      'Set these pins to match your SD connections.
   CLK = 13
   DI  = 14
   CS  = 15
OBJ
   sdfat : "fsrw"
   debug : "FullDuplexSerialPlus.spin"                   ' PST Driver
VAR
  Long DATA
  Long l[128]
PUB Main| mount, r, counter
  Debug.start(31, 30, 0, 57600)                         ' Start Debugger
  waitcnt(clkfreq*2 + cnt)   'Increase the 4 if more time is required.
  mount := \sdfat.mount_explicit(DO, CLK, DI, CS)
  if mount < 0
    debug.str( string( 13, "Failed to mount", 13 ) )
    abort
  debug.str(string(13,"SD was card found and mounted fine.",13,13))
  sdfat.popen(string("master.csv"),"r")
  counter:=0                 'Setup a counter starting at zero.
  repeat                     'Start a repeat loop.
    r := sdfat.pgetc         'Get a character from master.csv
    if r == 44            'If character is a comma
      l[counter] := @data
    if r > 44             'If the character "greater than 44"
      data[counter]:=data[counter]+r      '  send character to data string.
      counter++                           '  increment the counter.
      counter++                           '  and again since there is always a CR
  repeat counter
    debug.bin(l[counter], 32)
  debug.str(string("Closing file and unmounting SD card.",13))
  sdfat.pclose
  'Unmount the card and end program.
  sdfat.unmount
Here is the CSV file I am working with. Please note that I would rather not change the formatting if I did not absolutely have to, since it is generated by another Excel file
master.zip
This is just the start of something bigger. Eventually, I would like to write the same formatted CSV files to the SD card, allowing the user to type the file name on a keyboard. But for now, I just want to concentrate on getting the data off the card, before I try to write it back.
Can someone show me the error of my ways, or at least point me in the right direction?
    edited 2011-08-19 10:21
    You're making some erroneous assumptions ...
    1) When your program sees a comma, you do "l[counter] := @data" assuming that the character string in data will be converted to a binary number. What you get in the array is the address of data.
    2) When your program sees a non-comma character, you do "data[counter] := data[counter]+r". I don't know what you're trying to do, but it doesn't do anything useful.
    I suggest you look at the BS2_Functions object from the Object Exchange and the SERIN_DEC method particularly. This uses a call to SERIN_CHAR to get a character and you could replace those calls with sdfat.pgetc. SERIN_DEC shows you how to read in a string of digit characters to a buffer and convert the digits into a numeric value. It uses a CR as the delimiter, but you could change that to a comma and CR.
    edited 2011-08-19 11:57
    Sariel,
    I've found Excell doesn't like to play nice with csv files.
    I use the Propeller as a data logger almost everyday. I save my data using comas as delimiters.
    When I had the Prop save the file as a csv file, Excel wouldn't open it correctly.
    I needed to save it as a txt file and use the "Import" feature in Excel. (I know of at least two other forum member who had the same problem.)
    I believe Excel uses and expects tabs as delimiters. IIRC tab is ASCII 9 (I'm not sure).
    There might be a way of having Excel use comas instead of tabs in the csv files.
    I personally just use comas as field separators. Each line should end with a carriage return (ASCII 13).
    I have the Prop save these files as txt files on a SD card and then either import them into Excel or "open with" OpenOffice.
    I generally use OpenOffice more than Excel now.
    Here's a section of code:
    Sd.writeCharacters(@rf_rxbuf + 1)
            Sd.writeCharacter(44)
            Sd.writeCharacters(@timeArray + 5)
            Sd.writeCharacter(13)
    When I import the data, the above code writes, in Excel, I get two columns.
    (The first column) rf_rxbuf holds data received from a wireless module. I use "+ 1" to have the Prop skip the first character of the string when it writes to the SD card.
    timeArray holds a time-stamp (again I want to skip the first 5 characters)(this data makes up the second Excel column).
    "Sd.writeCharacter(44)" inserts a coma (creates a new Excel column).
    "Sd.writeCharacter(13)" inserts a carriage return (creates a new Excel row).
    The method names are to Kye's "FATEngine.spin". I believe the method names have been changed in his new SD drivers.
    I know you're asking about reading from an SD card but you said writing to the SD card was also one of your goals.
    Duane
  • JonnyMacJonnyMac Posts: 9,566
    edited 2011-08-19 12:31
    I have a program that parses decimal values from a CSV file. This method reads one line from the file -- in your case this will be one 32-bit value:
    pub readln(pntr) | c, len
    '' reads line of text from open file
    '' -- terminated by CR or EOF
    '' -- removes linefeeds if present
      len  := 0                                                     ' index into string
      repeat
        c := \sd.pgetc                                              ' get a character
        if (c < 0)                                                  ' end of file
          if (len == 0)                                             ' if nothing
            return -1                                               ' return empty
          else
            quit
        if (c == CR)                                                ' if CR we're done with line
          quit
        else
          if (c <> LF)                                              ' if not a line feed
            byte[pntr++] := c                                       ' else move c to buffer
            len++                                                   ' update character count
      byte[pntr] := 0                                               ' terminate end of line
      return len
    Converting your buffer back to a number should be easy; you can do it with this:
    pub bin2dec(pntr, len) | bval, c
    '' Converts binary string at pntr to decimal value
    '' -- removes non-binary characters at head of string
    '' -- allows underscore character in binary string
      bval := 0
      repeat                                                        ' remove non-binary header
        c := byte[pntr]
        case c
          "0".."1":
            quit
          other:
            pntr++
      repeat while (len > 0)                                        ' convert string
        c := byte[pntr]
        case c
          "0".."1":
            bval := (bval << 1) | (c - "0")
            pntr++
            len--
          "_":
            pntr++
          other:
            quit
      return bval
    I use the bin2dec method in the AP-16+ to convert a set of flag bits from the SD card; for example:
    SFX=0000_0000_1111_0011
    ... to a number I can use the code. I like having the underscore character in my numbers to separate groups, hence the method skips over them.
  • SarielSariel Posts: 182
    edited 2011-08-19 12:33
    Mike---
    BAH! good catch! I'm still trying to get used to this concept of accesing Data via address. By the number of questions everyone else has responded to regarding that, no suprise that I still make an error in that once in a while.
    Honestly, that is a bit of code that I forgot to comment out from the Gadget Gangster example
    Thanks for the suggestion. I will read through it and tear it apart this weekend before I have to come back into work on monday.
    Duane--
    Honestly, It is ok that excel cannot read the files back. In the end of this project, I want to give the user 2 ways of generating files for reading by the prop.
    1.) Input taken from a formatted Excel file that saves to a .csv
    2.) Propeller-generated via program that dumps 128 longs.
    For a clearer picture of what I am doing, here is my Excel file. What's going on is that user enters in the wiring on the "Pinout" Sheet, then goes to the "Cable Data" Sheet, and hits the "Make CSV" button. That will maake the current sheet dump to a CSV. User then copies it to the SD card, and my program will read that information, and use it for the test.
    I will look into everything you guys said. THank you for your replies.
    NEW Cable Data Master(MKII).xls
  • rokickirokicki Posts: 1,000
    edited 2011-08-19 14:59
    Duane Degn wrote: »
    Sariel,
    I've not had these problems. Can you attach one of the comma-separated value files that
    you say Excel can't load? If you would, I'll probably be able to tell you what's wrong with it.
    -tom
    edited 2011-08-19 15:31
    Tom,
    I don't have Excel on this computer so I can't test to be sure a file wont open or not.
    I just know I've made the suggestion to "Import" a txt file rather than opening a cvs file in Excel to several people on the forum they agreed it solved their difficulty.
    It's not longer an issue for me since I use OpenOffice most of the time.
    Duane
    edited 2011-08-19 20:55
    When I wrote that article, I was using a computer that had a serious program flaw with my installed copy of Excel. I used Google docs (spreadsheet) which does play nice with Comma delimited files. It's as close as a free signup.
    OBC
    edited 2011-08-22 10:24
    Ok. I think I have at least a half-way grasp as to what is going on now, but something still is not quite right. JohnnyMac, I have combined your two methods into one, and put a repeat counter into it so that I can read all 128 values from my file, store it as the variables I need it to, and dump info to the PST. ...and something odd is happening. When I read my "master.csv" file, I get garbage in the PST. no numbers, no letters, just a bunch of repeating garbage. I have verified it is not a com port setting, or faulty cable by running one of my other bits of code from the same exact piece of equipment, and the PST behaves normally.
    When I read "data.csv"(from GadgetGangster example), I get 2 values to print out (both 0's). Thinking there may be some extra header garbage that microsoft puts into the CSV file that is not visible in notepad, I re-created the master.csv as first a normal every-day txt file, and and kept one copy as a txt, and another renamed as a csv (hopefully eliminating the header Smile), it still won't read it. Either one. (yes, I am changing the string in line 42 to reflect the file I want read). Here is the code that I am trying to use now, and the associated CSV and TXT file I am trying to get to work.
    data_master.zip
    CON
      DO  = 12
      CLK = 13
      DI  = 14
      CS  = 15
      LF = 10
      CR =13
    OBJ
       SDFat        : "fsrwFemto"
       Debug        : "FullDuplexSerialPlus.spin"
    VAR
      Long l[128]
      long ioControl[2]
      long counter
      long c
      long len
      long bval
      long pntr
    PUB Main | mount
      waitcnt(clkfreq*2 + cnt)   'Increase the 2 if more time is required.
      debug.str(string(16))
      sdfat.start(@ioControl)                         ' Start SPI driver
      mount := \sdfat.mount(DO, CLK, DI, CS)
      if mount < 0
        Debug.str( string( cr, "Failed to mount", cr ) )
        abort
      debug.str(string("SD card was found and mounted fine.",cr,cr))
      result := SDFAT.popen(string("master.csv"),"r")
      if result < 0
        Debug.str(string("Failed to load file.", cr))
        abort
      counter := 0
      repeat 128
        repeat
          c := \sdfat.pgetc                                              ' get a character
            else
              quit
            quit
          else
        bval := 0
          c := byte[pntr]
          case c
            "0".."1":
              quit
            other:
              pntr++
          c := byte[pntr]
          case c
            "0".."1":
              pntr++
              len--
            "_":
              pntr++
            other:
              quit
        l[counter] := bval
        debug.dec(l[counter])
        debug.str(string(CR))
        counter++
      SDFAT.unmount
      debug.str(string("Closing file and unmounting SD card.",CR))
      SDFAT.pclose
    I know it is probably just something simple that I am overlooking, but can someone please take a glance for me?
    And, again, I just wanted to say that once the file leaves excel, it will never, ever need to go back into it, or any other spreadsheet program. Excel is just being used as a dirty way to make these variable sets, without having techs setting these up ever be forced to mess with, or even see the actual source code used. I guess you can say that I am using excel as a config file generator.
    edited 2011-08-22 10:30
    As an exercise over the weekend I updated my SD text reader example to read and display the contents of your CSV file. Give this a try. Note that I downloaded your CSV file (from an earlier post) and dropped it right onto my uSD card without any modifications.
    edited 2011-08-22 12:36
    JonnyMac--
    Awesome. thank you very much, and it works like a charm. I already have it integrated into my base program, and it is humming along nicely. Now, on to adding the OS block I already got going so that one can specify the config file to load up.This project is very quickly becoming a beast for a beginner like myself.
    edited 2011-08-23 08:05
    Here's a good one for you, OBC...
    I am integrating this in with my auto tester, and a modified version of PropDOS. Any good ideas on how I can make a command in PropDOS that instead of always loading "master.cvs", it loads in whatever comes next after someone types in "TEST"? to make the tester do exactly what it is now, one would type in "test master". I have poured over PropDOS a few times, and I see how you can do it if the option is known like with |more, or /w, but what if the option can and will be different every time?
    edited 2011-08-23 09:07
    Ah, If I understand right you are attempting to read the command line after the command itself...
    The command-line parsing code in PropDOS suffers from the fact that I was a beginner in spin when I wrote it. It works, but it's painful.
    I did some work similar to this recently, (in the last month). I've got a lot going on this week with expo coming Saturday, but I'll see if I can round up some better code for that job.
    Edit:
    One trick that might help you is to use the STRINGS object. Once you have the file name parsed from the command line, the following will help you combine the untyped file extension with it.
    OBJ
    str       : "STRINGS"
    sdfat     : "fsrw"
    PUB Example(commandline)
    extension:=string(".cvs")
    filename:=str.Combine (commandline,extension)
    sdfat.popen(filename,"r")
    OBC
    edited 2011-08-23 09:14
    Yeah. something like that. Worst case scenario, I suppose typing "TEST", then pressing enter, then typing the name of the config file on another prompt would work. Just something to kick start these variables before the test program runs.... but without having to reboot the prop so I lose the RAM dump anyhow. I appriciate you taking a peek. I'm going to keep plugging at it, trying to get all 3 of these elements together. a recent compile just put my program above 4600 longs, so I am well past the biggest thing that I have pieced together to date. I'll post here if I come up with anything spectacular.
    edited 2011-08-23 09:26
    ...One trick that might help you is to use the STRINGS object. Once you have the file name parsed from the command line, the following will help you combine the untyped file extension with it.
    Get outta my head! I was just thinking about that, and trying to get my idea of a secondary command entry to work. I cut and pasted the meat from your command line interpreter, and was trying to think of a way to do just that to the "cmd" variable.
    edited 2011-08-23 09:33
    Yeah, I saw that problem on your horizon.. :) Been there, bought the t-shirt. Hopefully it saves you some time.
    (I don't want to confess how long it took me to figure out that simple trick.)
    OBC
    got it going. Kinda had me tricked for a second there. ah well. I have been burning this code since 4:30 am now, and I finally have this whole section going. now on to the other config file, and setting the date and time!
    Thanks for the help, Jeff.
  • @JonnyMac.
    I try to transmit a self generated google KML file trough a wifi ESP as serial bridge.
    I get the issue with large file the data is not transmited compleet.
    Serial terminal pause , and missed some part and do not go til end?
    I get the same issue on serial terminal using You code jm_read_text
    I only change " check := \sd.popen(string("MLYN0606.txt"), "r") ")
    My file attached
    I guess it is an buffer issue?
    Thank you
    PS. I have to change .KML to .TXT to uploade on parallax? but is is a normal google .KML file
  • Upload it as a .zip archive for better results.
    Some file formats are not supported as attachments.
  • Get it for the .zip
