Lunar Tracker
Tapperman
I'm trying to build a device to track the Moon in the sky. I'd like to track the moon 1 day before its full, the day its full, and 1 day after its full.
And the thing is working (see video below via link) ... but I have a question
http://www.youtube.com/watch?v=wSULL54JBkE&feature=player_embedded
I have 4 cds cells that, even though they are the same part number, give 4 different levels of resistance when exposed to the same light energy.
How should I correct for this?
... Tim
PS - been a while since I did anything with the BS2
... Tim
See page 4 at http://www.seas.upenn.edu/~robo2005/Electronics%20Lab%202%20v6.doc for Stamp/ptx info.
This guy did it with one CDS cell (see link)
http://home.earthlink.net/~nevadabat/Moonlight/MoonLight.html
... Tim
Thanks for the laugh ... Yeah, I was going to try to scan on the 15th of July but the weather has been so bad, that I couldn't ... Hoping for better conditions on the 13th of Aug.'s full moon.
The problem I was describing in the first post was "when your checking spot on" values from the sensors, there is a bias ... this is because I'm reading the CDS cells in pairs ... and they don't all respond with the same values for any given light energy ... so, the result is the controller looks off from center in both directions based on this imbalance of resistance for any given amount of light.
I'm hoping there is a simple solution, I haven't thought of, that someone else might see?
... Tim
Obviously, you want to calibrate at the low lunar light levels expected, not by looking at a desk lamp.
I couldn't do the video at the real low light levels, so I replaced the cap with a 1 uF and let it look at the desk lamp for the video ... but it see's the moon fine with a 0.01 uF cap.
You can see the values show up real time in the spread sheet from the CDS pairs (left, right, top, bottom and ALL), when your outside ... I don't think a video of that is possible, at least with my camera.
... Tim
Wow, you just gave me an idea! I think you might have solved it. Picture this in your mind
drill and blacked disk (starting with a small bit) with each CDS in a jig. Then check the response to light through the hole. And increasing the drill size as needed to bring the device into the correct ball park
force all 4 sensors to re-act with the same response to stimulated energy? Is that barking up the right tree?
... Tim
PS - How do I mark this thread as 'solved'?
Better yet, get out there (dancin') in the moonlight under the exact conditions you anticipate. The moon waxes stronger as it gets fuller, so start a few days ahead of time and your signal strength will increase when you want to take your real readings.
BTW, is there a lot of IR energy in moonlight? It is after all reflected sunlight, so I'm assuming so.
I've done both already. This is a calibration I did with a candle 12 inches from the flame.
But the moon light I was able to study was only a small set of samples on Jul 14th before it hid behind the moutains, and with the wrong read routine ... and after that, it's been cloudy and rainy almost everyday (Willamette Valley).
Very weird Summer
I can track a candle outside from a distance ... but, I can't get a video of this with my camera!
http://www.trincoll.edu/events/robot/
You've already done the hard part! Contest is usually in April. Time's a-wasting!
Thanks for the link ... that was cool to see that little robot find the candle, then put it out, go home and beep when finished!
... Tim
Great Idea! Wouldn't happen to have a link would you?
Yep, your right ... preformed a test this afternoon and got them all to line up .. then reduce the light and they spread apart ... that approach will not work.
... Tim
I mount the CDS cell inside a Soda Pop Straw, slit down the end with a knife ... then spread the legs on the CDS and place it in the center of the straw (inside) as close to center as I can.
... Tim
But your straws look like they are just for minimal support. They are translucent and the photocells are right near the top. Are your photocells just hanging in the slits? Kinda loosey goosey. If the cells get bumped, all your calibration work is lost.
If it were me, I'd mount them firmly to a plate & glue them all down flat, making sure they are all perfectly parallel. Then I'd build a removeable optical shutter system around the array, then take it apart and paint everything (except the cells) flat black.
Thanks, I was going to use a toy I had seen that had the perfect quad divider for this project 'light, sturdy, small & cheap". But now I can't find it, so since I was running out of time ... I took the thinnest aluminum angles I could find, rivited them together and painted them black.
The CDS cells are inserted into the slits down the side of the soda straw, and then the legs are taped against the outside of the straw. Then the straw is placed in the corner of the angle, and 'hot-glue' is applied to secure it.
However, 20 minutes after gluing ... the glue shrank, and they came loose (2 of them) ... so now I'm going to try 'finger nail glue'.
The straw is easy to remove ... split the straw with a knife length ways, and pull the cell out ... and easy to fabricate again. The straw serves to align the cell, and also holds a label (#4, etc.), in addition, its easy to find (after dropping on the floor) for old guy like me (with poor eyes).
... Tim
It's OK. Hope this video is better (kind of dark) ... but it examines all 4 sensors as one value and finds center in a progression of smaller steps in a series of passes, reading a modified PLX-DAQ macro
http://www.youtube.com/watch?v=LUNEc078n1Q Trim & Zero set
http://www.youtube.com/watch?v=bQUPner-VvQ Track
The Zero_IN routine was the problem that was vexing me ... I think I may have it solved! (here's hoping)
... Tim
New version
@Andy ... I used two images from WAM to aid understanding ... should I remove them?
... Tim
