3000 mAH AA NiMH / 56 cents each — Parallax Forums
ercoerco Posts: 20,263
edited 2011-07-17 00:26 in General Discussion
NiMH cells ain't sexy, but they're getting dang cheap. Here's a dozen cells shipped from China for $6.77: http://cgi.ebay.com/12X-AA-2A-3000mAh-NiMH-Rechargeable-Battery-Cell-MP3-RC-/110614485787?pt=US_Batteries&hash=item19c1231b1b Even if you use them once and throw them away, they're cheaper than good quality alkalines.
I ordered 2 dozen: a full 4 Scribblers' worth. Now I have no excuse for not having at least 2 Scribs doing my evil bidding at all times.
I have also been buying some Lithium Ion 18650s (3.7V, also 3000mAH) and chargers to try. But these NiMH cells are cheaper (and slightly heavier) overall, and AFAIK, safer to leave on long-term trickle charge. Quite frankly, I doubt if these are really 3000 mAH, but even if they are around 2000 I'll be quite happy. Will report back after they arrive. Unless they burn the house down. Cheers!
«13
    edited 2011-06-21 18:32
    Just do not use these batteries in a one hour FAST battery charger the charger will end the charging before the batteries are fully charged because the battery voltage are higher than batteries made in Japan
    buyer beware
    Now if you use a slow battery charger that voltage is NOT being detection then you will be alright
    and the price is right
    edited 2011-06-21 19:10
    @sam: I agree: fast charging is for suckerz! Actually, I have it in my mind to charge them off solar panels:
    1) the charge rate is quite low and safe (~60 mA from the small cells I have), and
    2) it's easy to put (N) 1.2 V NiMH cells in series directly with one or two 5.5V solar cells in series to match the voltages for peak power transfer without a fancy charge regulator.
    edited 2011-06-21 19:18
    That should work what you have in your post
    I agree: fast charging is for suckerz <.......... Now wait a minute that not funny I use alot of fast charger
    edited 2011-06-22 03:58
    WoW!
    What a great buy.... just in time too. I need some
    new cells.
    Hey, I just got some of those solar flashlights you turned
    up on ebay.
    They are really nice and pretty bright.
    They sent black ones and I wanted green ones is
    my only gripe. How did you manage to open them up
    without messing up the case? These seem pretty
    well sealed tight. I want to see how much room is in there
    and hook up a meter to see what the charge rate is in
    sunlight.
    edited 2011-06-23 06:32
    Solar flashlights? You don't need a flashlight when the sun is shining.
    @Holly, have you been selling refirigerators to Eskimos?
    edited 2011-06-23 08:58
    @Loopy: The best solar flashlight is a mirror...
    @Holly: the ones I got were barely sealed. Can't remember if there were even any screws. I took off the keychain and easily popped the case open with a screwdriver.
    edited 2011-06-23 15:50
    This is timely. I was just thinking of getting rechargeables for the little project I'm making of the BOE-Bot I got at UPEW, and wondering whether to spring for NiMH. Both locally and at the usual suppliers 2500 mAh cells seem to be about USD$6 -- EACH. At $6 for the entire 5-cell set, it's a no-brainer; order placed this afternoon.
  • schillschill Posts: 741
    edited 2011-06-23 15:57
    I'd like to see some tests to see if they are anywhere close to 3000 mAh. 2700mAh seems to be the peak right now for most "name" brand NiMH batteries.
    I've become addicted to Sanyo Eneloops. The new ones are only about 2000mAh, but the long shelf life more than makes up for it. No dead robots after a week of sitting on the shelf.
    By the way, MAHA POWEREX 2700mAh are around $3 each from www.thomasdistributing.com which isn't too bad a price. I used to use MAHA almost exclusively before switching to Eneloops. MAHA has since come out with their own low discharge batteries (Imedion) but I've never used them.
    edited 2011-06-23 17:40
    At this price I'm not too concerned if they're only 2000 mAh instead of 3000. Heck, they're cheaper than locally bought NiCD's that only go to 800 mAh. And since the cool plan is to have the robot detect that they need charging, find its charger, and remove itself from the charger after the usual 10 hour slow-charge period, it doesn't matter if their quality doesn't hold up in terms of low discharge or tolerance for fast charging.
    That assumes I get the cool plan working of course; if I don't, it won't matter and the key will be saving the money in the first place.
  • BradCBradC Posts: 2,601
    edited 2011-06-23 18:31
    I've been buying E-bay Ni-MH for ages now. I'll bet you a bottle of scotch they come out at between 500 * 700 mAH. They also exhibit quite a high internal resistance while charging, so if you use a delta/peak charger you need to charge them at about 1C or it'll miss the peak.
    The AAA's come out at about 300mAH.
    edited 2011-06-23 18:55
    @Brad, So if you've been buying them for a while, you think they are still worth the price even though the capacity is much less than advertised? I'd assume so otherwise you wouldn't still be buying them, right?
    I'm curious what you think about them and what type of applications they are good for. I just purchased two dozen myself.
    I've read that Duracell NiMH are better than Energizer's NiMH batteries. I have a bunch of Energizer NiMH and they do not hold there charge long.
    I recently purchased some Eneloops at CostCo. I haven't opened the package yet but I've read they're good (and not just from schill).
    I'm also tired of having to plan ahead and charge batteries in order to use my robots. I'd rather have them ready to go all the time.
    Duane
    edited 2011-06-23 19:01
    Duane Degn wrote: »
    This goes back a few years, but I heard that there was a big difference between Energizers made in Japan and Energizers made in China. At the time, it looked like they had stopped making them in Japan. I managed to find some of the Japanese ones and they seemed pretty good. I didn't compare with the Chinese ones.
    edited 2011-06-23 19:23
    re schill's comment on MAHA, I have bought a MAHA charger and it can do all sorts of things, including regenerating cells and testing the real capacity of cells over a number of charge/discharge cycles. I have tested a whole range of nicad brands and it is interesting to see the real capacity. Some are exactly what they say (eg Duracell). Some brand new 'no name' ebay brands are about 1/10th of what they are supposed to be.
    We have now got almost all the batteries in the house as rechargeables - even wall clocks and TV remotes. As various batteries lose their capacity (as measured by the charger) they end up in the bin, and interestingly, my collection of rechargeables is now almost 100% duracell.
    edited 2011-06-23 19:49
    BradC wrote: »
    Good info, I'll test them. Even if you're right though I'm way ahead because even domestic NiCD's of about that capacity are way more expensive. If my robot works I can always upgrade. I'm trying to get a cheap project off the ground though and "working at all" is fine.
    edited 2011-06-24 06:28
    Yeah, I've got 2 MAHA chargers. One for my AA and AAA cheap chinese Smile, and one for my decent 9.6v PP3's I use in my guitar wireless.
    With energizer batteries and energizer chargers, my PP3's used to do ~200 cycles. With the MAHA charger I just threw out my first one at over 900 cycles.
    E-bay NIMH are garbage. Cheap garbage, but I use them in my RC cars, all my remotes and even my noise cancelling headphones when I fly. They end up costing me less than .85c each, but when teamed with a real charger that treats them nicely I've not lost any yet to cycles... they may only hold 1/10th of their rated capacity, but they've been doing it for a couple of years, so I've more than got my moneys worth out of them.
    I also have some Eneloops, and to be honest they are worth every cent, but only in stuff like keyboards and mice when you don't want to be swapping the batteries every 3 months.
    Cheap Chinese are ok, but you *must* have a good charger. Can't recommend the Maha Wizard highly enough. Really.
  • RDL2004RDL2004 Posts: 2,554
    edited 2011-06-24 07:08
    I have a Maha C808M. They make some excellent battery chargers. Mine has easily paid for itself in the four years I've had it.
    edited 2011-06-24 08:21
    You all have just about talked me into a Maha charger.
    I'm thinking about this one.
    Any other suggestions?
    Duane
    edited 2011-06-24 08:41
    OK, Maha is good, but I'm done R&Ring each cell and charging 4 at a time. I want a higher-voltage charger for N dedicated cells in series to be left in the device, pretty much like an R/C battery pack. Does an equally good multicell charger (switchable for N cells) exist, or must I limit myself to trickle charging to get the job done?
    edited 2011-06-24 09:42
    @Duane Deg
    That C9000 does a lot more stuff than the C808. I'm thinking about getting one of those also. It only does 4 cells at a time and only AA and AAA. The C808 is able to do C and D size and up to 8 at a time. The Maha chargers are all individual, I can charge any combination at the same time or different times. They work like having 4 (or 8) individual chargers. The only con is that they don't do 9-volt.
    edited 2011-06-24 19:19
    RDL2004 wrote: »
    Which is why next to my MH-C9000 I have an MH-C490F. Brilliant little machine
    edited 2011-06-30 10:06
    My 24 AA cells arrived yesterday. Fast 8-day ship from China! Charged some up last night, and I'm testing them now at 500 mA current draw.
    I'm sure a nice charger (or even a trickle charger) can put more power into them than the cheapie wall fast charger I used, so this is kind of a worst case scenario. Will advise initial findings.
    edited 2011-06-30 10:13
    So far, so good then: nothing leaked, caught fire, or exploded! :)
    edited 2011-06-30 10:18
    If that's your definition of a good day, then things are freakin' FANTASTIC here!
    BTW, I'm testing the batteries at work, so worst case, if there's a fire or explosion: AFTERNOON OFF!
    Life, lemons, lemonade again!
    edited 2011-06-30 11:20
    BradC wrote: »
    Yikes, BradC is right on the money. Even at fairly low continuous drain, my quickie test puts them only in the 500-700 mAH range. I had two cells in series hooked up to a DC motor under light load, so the current started at 500 mA and slowly dropped, as did the voltage. After one hour, we were down to 2.2 V total and 440 mA. By 1:10, 1.5V at 350 mA.
    So not 3000 mAH by a long shot. No good for mission critical applications! :)
  • K2K2 Posts: 695
    edited 2011-06-30 12:18
    If it's any consolation, a bunch of us have been there. I was leery enough to order just four cells. When I informed the vendor that I measured only about 270mAh capacity, he begged me to give him five stars anyway. So far (several months later) I have yet to leave any feedback.
    What do you suppose you are going to do wrt feedback on this purchase, erco?
    edited 2011-06-30 13:24
    270? OUCH! Now I feel better! I'll charge differently & test a few more. I did yank these out of the charger right after the fast charge cycle ended, it's probable that skipping the trickle charge phase only gave them a partial charge. It would be nice to figure out how to get at least 800-1000 mAH out of them. My whole goal is to make battery packs that can be recharged in series, so I have much to learn. Battery selection, testing, charging and utilization is a whole science by itself. I have an idea how to make a Stamp-based battery tester, that would be a cool project.
    Regarding feedback, I find that most China sellers are quite eager to please. Many of them will refund 100% of your money in exchange for good feedback. In this case, the price and risk was low. These particular batteries are low-grade, more like Ni-Cad cells, but certainly worth something. I'll find a use for them. It would be wrong to expect a full refund; the shipping costs alone from China had to be something. I'll probably ask for a partial refund, maybe half and see what they say. I will mention the lower capacity in my feedback, but give them good stars for customer service.
    edited 2011-06-30 13:36
    Is there an easy way to identify if they are NiMH or NiCd batteries (other than reading the label which may not be accurate)?
    edited 2011-06-30 14:00
    XLNT question...
    My cells feel pretty lightweight, that might be some indirect indicator of chemistry or capacity. Each cell weighs 18.7 g, whereas a standard Duracell alkaline AA weighs 24.6 g.
    edited 2011-06-30 14:08
    Cut one open, and see if there's a tiny battery rolled up in newspaper (or a fortune cookie fortune) inside.
    edited 2011-06-30 14:23
    I'm pretty sure NiMH batteries take a couple of charge/discharge cycles before they reach their full capacity.
    If the capacity of the batteries aren't close to what the seller stated they should be called out for it. It's deceitful, especially if the seller knows their claims aren't true.
    I ordered a couple sets of these batteries. If they're not at least 2000mAh I'm going to leave negative feedback. I will cycle the batteries a couple of times and try to get the batteries up to their maximum capacity before complaining (or blaming erco as an accomplice).
    Duane
