Scrolling Text Using MAX7219 to Drive 7 Segment LED Displays
I am very new and very apprehensive about posting on a forum. I have seen some pretty angry responses to posts. I hope I can be clear enough in what I am working on and my question to elicit a kind and helpful response.
I am an artist working to gain control of the LED and sound output of an alarm clock. I hope to generate scrolling text messages across the face of the alarm clock.
I am using the Basic Stamp and MAX7219 IC to drive 4-6 7 segment LED displays with pbasic code. I am currently hung up on finding and altering the code to scroll the text. I went through the lessons on single 7 seg displays and successfully programed the alphabet. I then graduated to 4 7 seg displays using code for a change counter (the pdf with code I am referencing is attached) and I am still working to understand how it functions so i may change the code to create scrolling text. Today I found another pdf with information about avr firmware (see attachment) but I am not sure if this is something I can use with pbasic and basic stamp, but it appears to be just what I am looking for.
If someone could point me in the right direction to find code for scrolling text on a 7 seg LED display or advice in reference to the avr firmware, I would really appreciate it.
sw29.pdf
avr_7seg1_doc.pdf
sw29.pdf
avr_7seg1_doc.pdf
-Tomato
I am planning to graduate to 14 seg displays after I figure out coding the 7 seg displays.
CDP
These are great little displays and can communicate serial so not all the lines are tied up. You get many more options as far as characters, brightness control, etc.... with them. there are also several projects on the web using them with Stamps and other controllers, or hooking them to a PC port.
An example:
http://www.f-16simulator.com/pdf/CMDS_DISP_guide.pdf
I will for sure look into using these smart displays. They look nice!
I guess one part of being an artist is making life difficult or making life difficult for myself rather. I feel the integrity of this art piece is using the type of led display most commonly found in alarm clocks such as the 7 seg display. The clock needs to be believable as a clock unaltered until it starts to react differently than expected. That is kind of the "magic" of the piece. I will ultimately branch out into different displays in the future, especially according to the needs of the projects.
Thanks for the suggestions, but for this project I need to make the 7 seg displays scroll or blink text.
CDP
I am sure it will not work without some tweaking.
(For sure it will not scroll past the left display)
It is just a pseudocode suggestion on one way how to do it.
The key is to separate the display multiplexing loop from the scrool loop.
The indexes are probably wrong to display correct character in correct place.
In theory it should scroll left to right.
Data index 1 to 4
Scroll index 4 to 1
Output scroll index = data index
Do while scroll index
DO while output scroll index
Get data @ data index
Output data @ sctoll index
output scroll index - 1
loop
Data Index + 1
Output scrool index = data index
Scroll Index - 1
Loop
Vaclav
These are very good options/suggestions.
I am going to work with them a bit and see what I can do.
CDP
I found a Nuts and Volts article which provided code (see attachment) but after wiring and trying to load the code I noticed it said it is for BS1. Does anyone know how to update this code for BS2?
BestOption!.pdf
