Better than sliced bread! SD3.01 FAT16/32 Driver Updated! — Parallax Forums
KyeKye Posts: 2,200
edited 2013-08-04 06:52 in Propeller 1
Well, its a new year, and here's a new driver!
Now available on the OBEX is the (http://obex.parallax.com/objects/619/) is the SD3.01_FATEngine.
There's ALOT of new functionality, and alot of stuff is fixed. Stop using the SD2.0_FATEngine if you can and switch to the SD3.01_FATEngine. (I found ALOT of problems with the SD2.0_FATEngine while updating it... you won't run into the problems easily however... but they are there).
Anyway, new features (Please read the bottom of my post if nothing else):
The file system is locked now for any access from any cog. This ensures that the FAT structure and directory structure are kept intact.
Card detect and write protect are now natively supported. The file system driver will abort and throw errors if the card is not in its socket and if you try to write to a write protected card.
The block driver now is faster and much more robust. It supported a 20Mhz write clock and a 10Mhz read clock. The mounting code in the block driver is much better now and should allow more cards to work with the propeller chip. The rebooting code in the block driver is also much better now and relfects the propeller chip's bootloader 100%.
The file system driver SPIN code is now easier to read and follows the FAT standard to the letter. Previous hacks I used in the SD2.0 version have been removed. The file system code now inspects data on disk more carefully.
File system paths are now also supported. So... you can now do stuff like "mv /prop/code.txt /code.txt" and etc. With that in mind, the rename feature has been replaced with the move feature.
Litsting also works much better now. Now, you can list the next file in the current directory, open it, close it, and then list the next file and repeat.
In general alot of stuff works great now. I worked very hard to fix all the problems that were under the hood previously. Stuff is faster and more robust now.
And, on the flip side. There are a few things I don't like. Files are not locked when opened for reading and writing. This means you can delete an open file... open a file for writing more than once... etc. You can also create circular directories with the move function. And, the mount function may let in corrupted or unusable FAT file systems.
But, if you aren't trying to break the file system or the driver then you won't experience any problems, enjoy!
Please test out my driver and post speed test results from running the builtin "test" command. I would like to know the average speed and what cards work with the file system.
«134567
  • MacTuxLinMacTuxLin Posts: 821
    edited 2011-01-06 20:24
    Cool!
    SanDisk 2GB uSD
    >_ test
    Running command: test
    Byte write test... Writ 032 KBs at 003 KBs per second
    Byte read test... Read 032 KBs at 003 KBs per second
    Word write test... Writ 032 KBs at 006 KBs per second
    Word read test... Read 032 KBs at 006 KBs per second
    Long write test... Writ 032 KBs at 011 KBs per second
    Long read test... Read 032 KBs at 013 KBs per second
    Sector write test... Writ 032 KBs at 091 KBs per second
    Sector read test... Read 032 KBs at 221 KBs per second
    Memory write test... Writ 032 KBs at 093 KBs per second
    Memory read test... Read 032 KBs at 234 KBs per second
    Block append test... Writ 032 KBs at 100 KBs per second
    Reverse seek test... Read 032 KBs at 209 KBs per second
    edited 2011-01-06 20:27
    SanDisk 8GB uSD
    >_ test
    Long read test... Read 032 KBs at 012 KBs per second
    Sector write test... Writ 032 KBs at 105 KBs per second
    Sector read test... Read 032 KBs at 188 KBs per second
    Memory write test... Writ 032 KBs at 109 KBs per second
    Memory read test... Read 032 KBs at 198 KBs per second
    Block append test... Writ 032 KBs at 122 KBs per second
    Reverse seek test... Read 032 KBs at 194 KBs per second
    edited 2011-01-06 20:29
    SanDisk 16GB uSD
    >_ test
    Word write test... Writ 032 KBs at 005 KBs per second
    Sector write test... Writ 032 KBs at 090 KBs per second
    Sector read test... Read 032 KBs at 224 KBs per second
    Memory read test... Read 032 KBs at 236 KBs per second
    Block append test... Writ 032 KBs at 124 KBs per second
    Reverse seek test... Read 032 KBs at 267 KBs per second
    edited 2011-01-06 21:49
    I've been looking forward to this - especially the fast loading of binary images. I hope to incorporate it into a new version of KyeDOS.
    edited 2011-01-06 23:20
    Nice work as always Kye :)
    But no prop code time to test :(
    edited 2011-01-07 05:58
    I spent an hour updating Kyedos for the Dracblade. Lots and lots of syntax errors in this new version but they are all changed now.
    Minor problem is that I can't seem to get an SD card to mount. 'tis after midnight so I'm probably missing something simple. Need to swap back and forth to the v2 code to find the bug. fatenginestart passes (it would reboot if failed that?).
      ifnot(fat.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _SD_WP, _SD_CD, _RTC_DAT, _RTC_CLK, -1))
        reboot
    In the old code it was something like mountPartition(partition, "C")
    The new code has no parameters - is that correct? (old code commented out)
      PrintStringCR(string("Testing for SD card"))  ' helpful message if card is out, better than just a blank screen
      'fat.partitionMounted ' mount the SD card
      'fat.mountPartition(0,0)     ' mount the sd card
      ifnot(fat.partitionMounted)
        printstring(string("Card Not Mounted "))
    Addit: I think mounting needs to be done manually - I added it to the original kyedos automatically on bootup as I figured you would always do this.
    So - the command
      byte "<mount> <partition>            - Mount the file system."
    what value do I use for partition? - a string or a number?
  • KyeKye Posts: 2,200
    edited 2011-01-07 08:18
    Its a number.
    The new code always sets the check disk flags now so I removed the "C" option of setting them. Good luck!
  • SapiehaSapieha Posts: 2,964
    edited 2011-01-07 08:55
    Hi Kye.
    But what if I use 2 SD cards AT same time on same Propeller on that system without Drive letter handler?
    Kye wrote: »
    Its a number.
    edited 2011-01-07 10:37
    You need to add drive letter handling yourself. But, yes, you can use two SD cards at the same time... and use two different partitions on the same SD card at the same time.
    Drive letter handling is easy, just a bit of string processing to handle.
  • Mike GMike G Posts: 2,702
    edited 2011-01-07 10:58
    Thanks Kye... Looking forward to getting the new version on my Spinneret Web Server this weekend.
    edited 2011-01-07 14:38
    I seem to have a problem mounting the sd card. I took the code off the obex and changed these lines:
      _baudRateSpeed = 38400
      _SD_DO = 12
      _SD_CLK = 13
      _SD_DI = 14
      _SD_CS = 15
      _SD_WP = -1 ' -1 ifnot installed.
      _SD_CD = -1 ' -1 ifnot installed.
    and it sends the message "Card Not Mounted" at startup.
    There is no real time clock. If I disable the real time clock
      _RTC_DAT = -1 ' -1 ifnot installed.
      _RTC_CLK = -1 ' -1 ifnot installed.
    Then no messages at all appear.
    I wonder if it has something to do with not having a clock? On KyeDO2 the code for the RTC is there but it does not do anything as nothing is connected to pin 28 and 29. However, maybe your new code needs the clock?
    Or maybe it is something else? eg WP and CD not being connected?
    Would you be able to please test this with the above settings?
    edited 2011-01-07 15:13
    My bad. I had the demo code setup to reboot the system if it couldn't turn a RTC on. Its fixed now. New code is on the OBEX.
    The "card not mounted" message does not mean the card is not inserted. It just means that you haven't typed "mount" in yet. Its a warning to tell you that the rest of the file system functions will do nothing until the card is mounted.
    If you have the card detect lines enabled the driver then will say "card not detected" after you call the mount function if no card is found.
    edited 2011-01-07 19:38
    Thanks for checking this.
    I still can't get it working.
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      _leftChannelVolume = 32
      _rightChannelVolume = 32
      _newLineCharacter = 13
      _clearScreenCharacter = 16
      _homeCursorCharacter = 1
      _receiverPin = 31
      _transmitterPin = 30
      _VGA_Enabled = true
      _VGA_PinGroup = 2
      _VGA_H_Res = 160
      _VGA_V_Res = 120
      _VGA_BG_Color = bmp#black
      _VGA_FG_Color = bmp#green
      _leftChannelAudioPin = 11 ' -1 ifnot installed.
      _rightChannelAudioPin = 10 ' -1 ifnot installed.
      _leftMicFeedBackPin = 9 ' -1 ifnot installed.
      _leftMicInputPin = 8 ' -1 ifnot installed.
      _rightMicFeedBackPin = 7 ' -1 ifnot installed.
      _rightMicInputPin = 6 ' -1 ifnot installed.
      _SD_DO = 12
      _SD_CLK = 13
      _SD_DI = 14
      _SD_CS = 5
    OBJ
      fat: "SD3.01_FATEngine.spin"
      taf: "SD3.01_FATEngine.spin"
      rtc: "DS1307_RTCEngine.spin"
      com: "RS232_COMEngine.spin"
      str: "ASCII0_STREngine.spin"
      adc: "PCM2.1_ADCEngine.spin"
      dac: "PCM2.1_DACEngine.spin"
      bmp: "VGA64_BMPEngine.spin"
    VAR
      long scopeSwtich, scopeStack[17], scopeHeap[((_VGA_H_Res * _VGA_V_Res) * 2) / 32]
    PUB shell
      ifnot( fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, _RTC_DAT, _RTC_CLK, -1) and {
           } com.COMEngineStart(_receiverPin, _transmitterPin, _baudRateSpeed) and {
           } adc.ADCEngineStart(_leftMicInputPin, _leftMicFeedBackPin, _rightMicInputPin, _rightMicFeedBackPin, 16_000) and {
           } dac.DACEngineStart(_leftChannelAudioPin, _rightChannelAudioPin, 0) )
        reboot
      dac.leftChannelVolume(_leftChannelVolume)
      dac.rightChannelVolume(_rightChannelVolume)
      if(_VGA_Enabled)
        ifnot( bmp.BMPEngineStart(_VGA_PinGroup, 1, _VGA_H_Res, _VGA_V_Res, @scopeHeap) and {
             } (cognew(scope, @scopeStack) <> -1))
          reboot
      repeat
          com.transmitString(string("Card Not Mounted "))
    That last line is the first thing being displayed, so do I type something to mount it?
    edited 2011-01-08 07:31
    You type "mount" in. And then use the rest of the commands.
    edited 2011-01-09 04:08
    Sorry I can't get this version 3 to work. Version 2 works fine.
    So I need to narrow down the possibilities of why it is not working.
    1) Do I need to mount the card? Do I type "mount"? Nothing else, no parameters?
    2) Can I automate mounting? I say that because when I boot up with the default settings, on a terminal program I get no carriage return and no echo of characters so it is difficult to debug as lines keep being overlaid on top of each other. In KyeDOS2, one of the things I added was a routine to print carriage return and line feed, so if you changed it from CR only (or LF only) to CRLF it was only one line to change in the program. Different terminal programs have different requirements. If I add in a keyboard object like in KyeDOS 2, it gets complicated. So I need to simplify things.
    In the mount PUB there is this line:
    PRI programMount(stringPointer)
    What is 'stringpointer'? Can I call this after starting the sd routine from within code rather than typing something in?
    3) Can you explain this line of code more? Similar lines appear in other parts of the program
      ifnot(str.stringCompareCI(string("mount"), stringPointer))
    string.compareci to me implies a comparison of strings. It seems to be comparing "mount" with either "mount", in which case it is always true, or with a parameter, eg zero, in which case it is always false. If I wanted to call programmount(stringpointer) from within code, what would I put in "stringpointer"
    Help here would be most appreciated!
    edited 2011-01-09 13:18
    I don't understand what problems you are having. Just start up the terminal using the demo and type in "mount"
    The little program code you see there just takes a string as an argument. As in "mount 0". Its tokenizing the string however though. So you'll need to change the calls to str.tokenizeString in there.
    edited 2011-01-09 20:54
    Dr_Acula,
    Did you try:
      _VGA_Enabled = [B]false[/B]
    edited 2011-01-10 05:51
    Worth a try MacTuxLin, but no, it makes no difference. Sorry.
    It boots with "card not mounted" and when you type "mount" then enter, it replies with the same message "card not mounted"
    Tried a few different combinations at startup - eg commenting out the ADC and DAC engine, but no matter, it won't mount the card. Error coming back is "card not mounted".
    Any help here would be most appreciated. Hardware works fine with version 2. I'm 99% sure I have the same pin settings as in version 2.
    // SD3.01 FATEngine Demo
    // Author: Kwabena W. Agyeman
    // Updated: 1/2/2011
    // Designed For: P8X32A
    // Version: 1.0
    // Copyright (c) 2011 Kwabena W. Agyeman
    // See end of file for terms of use.
    // Update History:
    // v1.0 - Original release - 7/27/2010.
    // v1.1 - Updated code for new file system driver - 1/2/2011.
    // Type "help" into the serial terminal and press enter after connecting to display the command list.
    // Nyamekye,
    CON
      _receiverPin = 31
      _VGA_Enabled = true
      _VGA_PinGroup = 2
      _VGA_H_Res = 160
      _VGA_V_Res = 120
      _SD_DO = 12
      _SD_CLK = 13
      _SD_DI = 14
      _SD_CS = 5
    OBJ
    VAR
    PUB shell
      ifnot( fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, _RTC_DAT, _RTC_CLK, -1) and com.COMEngineStart(_receiverPin, _transmitterPin, _baudRateSpeed))
           '} adc.ADCEngineStart(_leftMicInputPin, _leftMicFeedBackPin, _rightMicInputPin, _rightMicFeedBackPin, 16_000) and {
           '} dac.DACEngineStart(_leftChannelAudioPin, _rightChannelAudioPin, 0) )
        reboot
    '  dac.leftChannelVolume(_leftChannelVolume)
    '  dac.rightChannelVolume(_rightChannelVolume)
      if(_VGA_Enabled)
          reboot
      repeat
        result := shellLine(string(">_ "))
        com.transmitString(string("Running command: "))
        com.transmitString(result)
        com.transmitByte(_newLineCharacter)
        result := \shellCommands(result)
        if(fat.partitionError)
    and for reference, version 2 code:
    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474; SD2.0 FATEngine Demo        &#9474;
    &#9474;        &#9474;
    &#9474; Author: Kwabena W. Agyeman        &#9474;
    &#9474; Updated: 6/2/2010        &#9474;
    &#9474; Designed For: P8X32A @ 80Mhz        &#9474;
    &#9474; Version: 1.0        &#9474;
    &#9474;        &#9474;
    &#9474; Copyright (c) 2010 Kwabena W. Agyeman        &#9474;
    &#9474; See end of file for terms of use.        &#9474;
    &#9474;        &#9474;
    &#9474; Update History:        &#9474;
    &#9474;        &#9474;
    &#9474; v1.0 - Original release - 6/2/2010.        &#9474;
    &#9474;        &#9474;
    &#9474; Type "help" into the serial terminal and press enter after connecting to display the command list.                          &#9474;
    &#9474;        &#9474;
    &#9474; Nyamekye,        &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    Modifications by J. Moxham Dr_Acula June 2010 for VGA display, local keyboard, xmodem, LCD display
    CON
      _clkfreq = 80_000_000
      _leftChannelVolume = 70
      _rightChannelVolume = 70
      _micSampleFrequency = 8000
      _micBitsPerSample = 8
      _baudRateSpeed = 115200 ' Don't use Teraterm at these speeds, use ShamCOM or another terminal
      _newLineCharacter = 10
      _receiverPin = 31
      _Port2receiverpin = 25
      _Port2transmitterpin = 24
      _clockDataPin = 29
      _clockClockPin = 28
      _cardDataOutPin = 12
      _cardClockPin = 13
      _cardDataInPin = 14
      _cardChipSelectPin = 15
      _leftChannelAudioPin = 5
      _rightChannelAudioPin = -1
      _leftMicInputPin = 7
      _leftMicFeedBackPin = 6
      _rightMicInputPin = -1
      _rightMicFeedBackPin = -1
    OBJ
       sio     : "pcFullDuplexSerial2FC"
    '  com: "RS232_COMEngine.spin"      ' problems with xmodem with corrupted bytes above 100 in the buffer
      fat: "SD2.0_FATEngine.spin"
    '  dac: "PCM2.1_DACEngine.spin"
    '  adc: "PCM2.1_ADCEngine.spin"
      str: "C300M_STREngine.spin"
      VT100: "VGA_1024_VT100"       ' VGA VT100 Terminal Driver
      key : "Pocketerm_Keyboard"           ' pocketerm keyboard
      lcd : "DracLCD"                     ' 20x4 LCD driver for dracblade
      delay: "Timing"                     ' for millisecond delays
    PUB shell
      VT100.start(16)                                       ' start the vga driver VGA starts on pin 16
      VT100.startcursor                                     ' start the cursor
      VT100.color(%00001000_11111100)                       ' Blue_White  blue =3/4 power 10, white =full
      VT100.cursorset(5)                                    ' cursor type 5
      VT100.clearscreen                                     ' clear the screen
      'vt100.str(string("Testing for SD card",13,10))        ' helpful message if card is out, better than just a blank screen
      key.startx(26, 27, %100, 40)             'Start Keyboard Driver  pin,pin,num,repeatrate
      sio.AddPort(0, _receiverPin, _transmitterPin, -1, -1, 0, 0, _baudRateSpeed)
      'sio.AddPort(1, _port2receiverPin, _port2transmitterPin, -1, -1, 0, 0, 120000) ' shamcom works 108000 to 120000 (teraterm can't do 112800 even though it can select it)
      'sio.tx(1,65)    ' test port 2
      'ifnot(com.COMEngineStart(_receiverPin, _transmitterPin, _baudRateSpeed))
      '  reboot
      lcd.start
      ifnot(rtc.RTCEngineStart(_clockDataPin, _clockClockPin))
        reboot
      ifnot(fat.FATEngineStart(_cardDataOutPin, _cardClockPin, _cardDataInPin, _cardChipSelectPin, _clockDataPin, _clockClockPin))
        reboot
    '  ifnot(dac.DACEngineStart(_leftChannelAudioPin, _rightChannelAudioPin, 0))
    '    reboot
    '  ifnot(adc.ADCEngineStart(_leftMicInputPin, _leftMicFeedBackPin, _rightMicInputPin, _rightMicFeedBackPin, 0))
    '    reboot
    '  fat.mountPartition(0,0)     ' mount the sd card
      sio.start             ' start the com port  note can't print anything to screen till sio.start unless only do to vga screen
      VT100.clearscreen                                     ' if the sd card is not inserted, will leave the message on the screen as a reminder. If it is inserted, start with a blank screen
      PrintStringCR(string("**** KyeDOS SD card operating system by Kwabena W. Agyeman/J. Moxham ****"))
      PrintString(string("Type Help for command listing"))
      crlf
      DisplayBinaryFiles                    ' display all files ending in .BIN
    I'm wondering about the RTC. Kye, would you be able to test your code with RTC = -1, and also physically pull the RTC chip out of its socket?
    edited 2011-01-10 06:30
    That makes no sense. The program is not allowed to run the mounting sequence without printing something else out... "Card Not Mounted >_" is just a status token appended onto the >_ prompt. When you type in mount and run it you should get some other output.
    You should see an error llike "file system corrupted", "file system unsupported" or "disk I/O error". Not nothing...
    edited 2011-01-10 06:48
    Dr_Acula,
    In 3.0, you entered:
      _SD_DO = 12
      _SD_CLK = 13
      _SD_DI = 14
      _SD_CS = 5     <--- 5 or 15?
  • b.p.m.b.p.m. Posts: 59
    edited 2011-01-10 07:47
    hey everyone
    i've been trying to run the demo without much luck. all i get on my monitor is a thick green horizontal line in the center of the screen.
    i checked that VGA was enabled and pin group is 2 (demoboard settings). am i missing something obvious?
    should i rely on the serial interface alone?
    blake
    edited 2011-01-10 15:43
    MaxTuxLin - you are right!
    That fixes it and now it works! How terribly embarrassing for me that I missed this typo.
    Well I guess I need to repay the favor by helping someone else.
    @b.p.m - yes the green line is correct. I don't think Kye has quite glued it all together yet. I suspect it is "an exercise left to the reader". Addit: I think it might be an oscilloscope to display the microphone sound.
    There are a few more bits and pieces to get a display going. You need a simple terminal, and one that behaves like a proper old fashioned typewriter where "line feed" moves the line up, and "carriage return" moves the carriage to the left (and dings a little bell). This version 3.0 does not behave like this because it is designed to talk to the propeller terminal program, so the first thing is to go through all the code and convert "CR" to "CRLF". Then you need a text driver, and a clear screen routine and the delete key needs to delete a character, and a local keyboard, and an interface that can accept input from both local keyboard and the serial port, and sends output to both the local display and the serial port.
    KyeDOS v2.0 can do all this. I just need to port the code over...
  • atlstangatlstang Posts: 20
    edited 2011-01-10 17:01
    You guys do the coolest stuff, had fun messing around with your driver. here is the results on a 1gb toshiba micro sd card. got about the same results on a 512mb version of the same type. here is the test command you asked to see.
    Sector write test... Writ 032 KBs at 093 KBs per second
    Sector read test... Read 032 KBs at 281 KBs per second
    Memory write test... Writ 032 KBs at 095 KBs per second
    Memory read test... Read 032 KBs at 302 KBs per second
    Block append test... Writ 032 KBs at 112 KBs per second
    Reverse seek test... Read 032 KBs at 375 KBs per second
    not sure what all those numbers mean but from looking at it im assuming writing to sd cards is much more efficient if i write bigger chunks instead a variable at a time. anyways cool object
    edited 2011-01-10 19:15
    Getting there with KyeDOS3. Working with a local 80x40 VGA display, local keyboard and the 20x4 LCD display. Plus the serial port. List of changes below.
    The big big improvement with version 3 is the amazingly fast "boot" command. Kye has done a superb job here. This truly changes the way to use a propeller. In some ways, external memory may not be so important any more as one could potentially chain .bin files one after the other. Each can talk to the next via files written to the sd card. One could even consider a batch file system. Or do crazy things like run a Basic program than then runs a C program. Or even Shells a C program.
    Things for Kye:
    1) In the new string engine I could not find PUB endsWithString(stringToSearch, stringToFind) '' 12 Stack Longs . Is this in the new string library under a diff name?
    2) I seem to have a very strange bug where LS works for about 10 lines then it hangs the VT100 terminal and indeed, the entire program. I suspect there is no range test and it is writing off the end of the allocated hub buffer and overwriting code. Solutions are to either fix the VT100 code, or to print out the files in columns using spaces rather than tabs. For the latter, is there a string function that returns the length of a string? Then one could print 20-strings.len to make up the column.
    3) I've had to comment quite a few things out to make things fit, mainly the audio. Not ideal, but then again, using the new way of thinking, one would put that audio demo into a new program and do a 'boot' to it.
    4) Regarding the 'boot' command, I am wondering if we can replicate something in CP/M, where if you typed a command, it would first look through the list of commands but if not found, it would look through the list of .COM files (in our case, .BIN files) and treat those as commands as well. So to run "movie.bin", instead of typing "boot movie.bin" I would just type "movie". I think it would be a matter of storing the name of the command, add .BIN to the end then running through the list of all the directory entries looking for a match.
    All great fun!
    modifications by J. Moxham Dr_Acula to create KyeDOS v3. Pins setup for the Dracblade (similar to the Propeller Demo Board)
    - name this file KyeDOS3
    - changed sd pins to 12,13,14,15. WP and CD = -1
    - RTC DAT and CLK -1
    - Audio and Microphone pins all set to -1
    comment out 'adc: "PCM2.1_ADCEngine.spin" and compile to find all PUBs referenced by this
    comment out adcengine start and PRI programTapeWavFile and dac: "PCM2.1_DACEngine.spin" and PRI programPlayWavFile
    comment out programPlayWavFile(stringPointer) and programTapeWavFile(stringPointer) and PRI scope
    comment out if(_VGA_Enabled) group
    startup is ifnot( fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, _RTC_DAT, _RTC_CLK, -1) and {
    } com.COMEngineStart(_receiverPin, _transmitterPin, _baudRateSpeed))
    comment out 'bmp: "VGA64_BMPEngine.spin" _VGA_BG_Color = bmp#black _VGA_FG_Color = bmp#green
    add OBJ VT100: "VGA_1024_VT100" ' VGA VT100 Terminal Driver
    copied VGA_1024_VT100.spin and VGA_80x40.spin to the working folder
    added VT100 startup code - now have a blinking white cursor on a blue screen. 80x40 text.
    commented out ' long scopeSwtich, scopeStack[17], scopeHeap[((_VGA_H_Res * _VGA_V_Res) * 2) / 32]
    (need to watch memory F8 here while adding more objects to the OBJ section)
    added key : "Pocketerm_Keyboard" ' pocketerm keyboard
    added lcd : "DracLCD" ' 20x4 LCD driver for dracblade
    added delay: "Timing" ' for millisecond delays
    added the keyboard startup key.startx(26, 27, %100, 40) 'Start Keyboard Driver pin,pin,num,repeatrate
    added lcd.start - this is dracblade specific with a 20x4 local keyboard. You can leave this out if not used
    commented out the existing .com driver. There is a bug with xmodem with corrupted bytes above 100 in the buffer, this does not show up with typing as the buffer never gets this full
    added 2 port serial driver (variation on Tim Moore's code). Copied object to current directory sio : "pcFullDuplexSerial2FC"
    F8 now fails with all instances of .com
    Added some printstring routines that send data to VGA and to the serial port and the LCD display and do CRLF properly
    added sio.addport. removed startup for the .com
    global search and replace "com.transmitstring" to "printstring"
    global search and replace "com.transmitbyte" to "printchar"
    edited a line with #comquotation marks. Keep doing F8 to find errors
    edited PRI shellline so it can accept Backspace and can read from keyboard and serial port
    found that the string engine syntax has changed. putcharacter is now buildstring
    found that the string engine syntax has chnaged. getcharacters is now builtstring
    rewrote PRI shelldecision
    replaced instances of quotationmarks from the serial driver to a local variable quote (ascii 34)
    added local contstants Horizontal_tab, Linefeed, CarriageReturn. Did global find/replace
    F8 finally compiles with no errors!
    added sio.start, print signon message
    added PRI DisplayBinaryFiles. Changed to the new syntax for reading entries
    ** edited the string engine - added PUB endsWithString(stringToSearch, stringToFind) '' 12 Stack Longs
    baud rate 38400 for testing
    comment out ' _newLineCharacter = 13 , replace with crlf
    go through the DAT shellProgramHelpStrings and replace _newlinecharacter with byte 13 and byte 10
    commented out the wav file commands in the help section (can always uncomment them later) amd the PRI
    replace instances of PrintChar(_newLineCharacter) with crlf or with printstringcr. Multiple instances
    removed "are you sure" from the boot command
    edited the 'help' commands so they each fit on one line
    moved the check for mounted card after every command to above the loop so only checks once.
    working on a very strange bug in programDIR - if send more than a certain number of tabs to the VT100 the whole spin program shuts down. Possibly overrunning a buffer and overwriting code. Need a better solution to line up files in columns
    also shows up with the LS command.
    edited 2011-01-10 20:27
    Good job Dr_Acula. You'll find that the SD3.01 FATEngine is extremely robust... and everything with the demo is correct and fine =).
    @BPM -The green line you see is the data coming back from the audio ADC. It's "scoping" the audio input for the prop chip (think propeller demo board microphone). If you disabled the audio adc then you would get just a green line. Use the "play" command to see the audio ouput of a wav file. This should work always... even if the DAC is disabled.
    edited 2011-01-11 16:05
    Kye, I'm having trouble with this latest update.
    I have a uSD setup on a breadboard. It works fine with version SD2.0 but not with SD3.01.
    When I type "mount" or "mount 0" into the shell, I get a message "Card Not Detected."
    If I set _SD_CD to -1 I get the error "File System Corrupted," even after formatting the card with version 2.0's demo.
    Here are my modifications to your demo
      _baudRateSpeed = 115200 '250_000
      _receiverPin = 31
      _RTC_DAT = 29 ' -1 ifnot installed.
      _RTC_CLK = 28 ' -1 ifnot installed.
      _VGA_Enabled = false 'true
      _VGA_PinGroup = 2
      _VGA_H_Res = 160
      _VGA_V_Res = 120
      _leftChannelAudioPin = -1 '11 ' -1 ifnot installed.
      _rightChannelAudioPin = -1 '10 ' -1 ifnot installed.
      _leftMicFeedBackPin = -1 '9 ' -1 ifnot installed.
      _leftMicInputPin = -1 '8 ' -1 ifnot installed.
      _rightMicFeedBackPin = -1 '7 ' -1 ifnot installed.
      _rightMicInputPin = -1 '6 ' -1 ifnot installed.
      _SD_DO = 11 '0
      _SD_CLK = 10 '1
      _SD_DI = 9 '2
      _SD_CS = 8 '3
      _SD_WP = -1 '2 ' -1 ifnot installed.
      _SD_CD = -1 '12 '1 ' -1 ifnot installed.
    Thanks for sharing your amazing work.
    Duane
    edited 2011-01-11 20:35
    Hi Duane,
    Do you have RTC on your bb? Have you tried:
      _RTC_DAT = -1
      _RTC_CLK = -1
    edited 2011-01-11 21:14
    Yeah, if you are getting the "File System Corrupted" error you should reformat the disk with Windows or Linux or Mac.
    The new code checks alot more stuff when mounting the SD card. If you get that warning then truely your file system has been compromised somewhere.
    Just copy all the files off of it, reformat, then copy the files on and you'll be good to go.
    -- Note: my format is just a mass delete of everything on the file system. It does not fix the patition format information.
    edited 2011-01-12 05:19
    Got some more coding time. Life is good!
    1) added a true/false constant for the LCD 20x4 display. This is because the 20x4 display driver is unique to the dracblade, whereas much of the other code is portable to many other propeller platforms. All character input/output on Kyedos, including serial, goes through a couple of PUBs so it is easy to add/subtract display options in a few lines of code. It makes the code fractionally slower but I think it does add better flexibility to modify things, potentially with just one line in the CON section. One might, for instance, want to disable the serial port and just display to the VGA display.
    2) Added a 6 column directory display.
    PRI ProgramDir(StringPointer) | buffer,counter
      ifnot(str.stringCompareCI(string("dir"), stringPointer))
        counter:=0
        crlf
        fat.listEntries("W")
        repeat while(buffer := fat.listEntries("N"))
          buffer := str.trimstring(buffer)
          PrintString(buffer)                               ' print file name
          counter++                                         ' add one to counter
          repeat 13-strsize(buffer)                         ' add spaces so columns line up
                printchar(" ")                              ' print space
          if counter == 6                                   ' new line
            counter :=0
            crlf
        crlf
        abort 0  ' so knows a command was run
    3) Kye, can you please explain something. Regarding strings, I see some code that does this
    PRI shellCommands(stringPointer)
      stringPointer := str.tokenizeString(stringPointer)
    Now, I gather you have a string, and now the str.tokenizestring points to this string.
    Let's say I want to work with two strings, and compare them. In a local PUB, do I need to define an array for that second string? If I did, and say it was a small string, could I make the length 80, instead of 255? (so long as the string is always kept under 80).
    Please forgive my strange ways of working with strings. I started with mbasic, where you never worried about length of strings. I then moved to sbasic, and pretty much all strings were 80 characters and the way you worked with them was closer to the metal, a bit like C.
    I've also written a lot of string handling in assembly, which is even closer to the metal.
    In many string handling routines, I found I could save memory by defining a number of generic strings at the beginning of the program, maybe call them string1, string2 etc, and each one is 80 bytes (20 longs), and I set myself a rule that each string stayed local in a function (copying strings between functions was done with pointers a bit like C). Then you could save memory by only having string1 to string7, and reusing them over and over.
    I've kept a similar concept in more recent vb.net coding - over and over I use one string, "LineOfText" and it is reused by each function. Saves memory to make it a global string rather than define it for many individual functions.
    Hub memory is starting to run out in Kyedos, so, can I define "string1", "string2" etc in the VAR section of the main program, and point to those strings using the Spin string object?
    Or maybe you can suggest another way of working with strings that might be better?
    Where is this heading?
    I'd like a new PRI, which the program falls through to if it can't match any of the commands. Its simply then looks for a match with a .bin file on the sd card, and runs that if it exists. It would only be a few lines of vb.net code but I'm very confused translating this to spin. In vb.net pseudo code:
    sub checkbinfiles( commandname as string) ' commandname is "myfile.bin"
    dim match as string
    ' now switch to pseudo spin
          if str.stringcompareCI(buffer,commandname)
             match := commandname
    ' back to pseudo vb.net
         if match <>""    ' found a match so run this with the BOOT command
             programboot(commandname)
    abort 0 ' never gets to here if reboots, but if it does, then go back to the command prompt
    please forgive my mixing of languages. I see that there is a command
    PUB stringCompareCI(characters, otherCharacters) '' 9 Stack Longs
    maybe I just need to see a simple example of how to use this, as it clearly uses two strings.
  • bpragerbprager Posts: 22
    edited 2011-01-12 08:10
    Dr. Acula, in regards to stringpointer and the comparestring function. That is used to determine what was typed and therefore what command to execute. Kye, one question I have is rather than have the shell take the result of what was typed and call every function until your stringcompare matches (worst case ends up with a lot of calls and stringcompares), why not just put in a Case statement?
    Maybe I'm missing something (very likely!), but it would make the code more readable and I would think tighter as you eliminate all the extraneous calls to both the routines and the stringcompare functions.
    Thanks for a great routine, its becoming the heart of my new project!
    BruceP
