Double DIPper - Two props in a DIP40 module — Parallax Forums
TubularTubular Posts: 4,774
edited 2010-06-29 21:09 in Propeller 1
This half finished design packs two props into a DIP40 pack. The "Media Prop" can be totally dedicated to graphics and/or sound output. Importantly this board has a resistor in series with each pin, allowing it to drive VGA, TV or be used in 5V circuits etc
Both props have these support chips
* EEPROM
* uSD card or Dataflash (dual footprint)
* ADC / PSoc / MSP430 / PIC shadowing the 16 I/O in each prop (as yet undecided)
* something else that fits up to TSSOP 16 (perhaps RTC, but RS232 or Accelerometer are also a possibility
There is also a "Stamp Mode" which involves flipping the board upside down, and making a couple of links, and a surgical separation (chisel). In this mode the board is much shorter but still retains the VGA and DB9 Serial connector.
I'm trying Micro USB for the first time. Wish me luck!
So, what should I do with the spare TSSOP footprint?
1039 x 859 - 53K
  • jazzedjazzed Posts: 11,803
    edited 2010-06-24 00:02
    Wow, that is super cool! How much? How much without the extras?
    Cheers [noparse]:)[/noparse]
    --Steve
    Propeller Pages: Propeller JVM
    edited 2010-06-24 00:26
    What's a "D15 Slim" connector? Are there cables that have one of those at one end and the usual 3-row DB15 at the other?
  • TubularTubular Posts: 4,774
    edited 2010-06-24 00:29
    Steve, its free to anyone who helps me finish the blasted thing off ! But seriously because of the 0402's and MicroSD header (with its overhang above its pins) it's really a professional assembly job for the top side. I'll hand solder the prop QFP on the reverse side and that will keep costs reasonable. I have to visit the assemblers next week about other things and will get a quote then. But first I need to decide what if anything in that tssop14 spot
    Also I forgot to mention there will be a daughterboard with coin cell that sits at the media prop end. This is more about reinforcing those slim D connectors but also might permit RTC backup
    edited 2010-06-24 00:31
    Phil its just a very compact footprint on the PCB. From the front of the connector its standard high density 15 pin.
    See link below, this is the one I have in mind there are others (perhaps with lower MOQ)
    Post Edited (Tubular) : 6/24/2010 12:38:56 AM GMT
    edited 2010-06-24 01:20
    Tubular: Nice board! Digikey also have a slim VGA connector, but more $, lower volume.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    edited 2010-06-24 02:29
    Ah, so. That looks like the thru-hole version of the one Andr
    edited 2010-06-25 13:54
    Phil Pilgrim (PhiPi) said...
    1200 x 900 - 131K
    edited 2010-06-25 14:41
    wastehl said...
    Very, very interesting. What kind of help do you need? A significant market could be created for something like this. Are there any further details available?
    Bill
    Hi Bill,
    Its just the usual time and certainty of direction. I reached the point where I figured "hey this is going to work", but am now exploring several possible options for the "co processor" and the other spare IC.
    I looked into a PIC24FJ64GB002, which would have been perfect as it has USB OTG and 10 bit ADC for about $3, but it doesn't seem to be physically available in TSSOP28 despite some docs listing this option.
    So the most likely option is a cypress PSoC, CY8C24423 or -633. These are interesting chips in themselves, have up to 14 bit ADC, and can interface to and be programmed by the prop over I2C . And instead of the TSSOP14 I think I'll just have a SOIC-8 pad, which can be used for RTC, FRAM, second EEPROM, SRAM etc.
    So in summary, features in the "prop" mode
    - Two Props in a DIP40 layout for ease of "upgrade" of an existing design
    - "Main Prop" drives the P0~P7 and P24~P31 end
    - "Media Prop" drives P8~P15 (AV) and/or P16~P23 (VGA)
    - Each Prop has independent supporting chips
    ' 64K EEPROM (under)
    ' MicroSD or Dataflash (top)
    ' PSoC CY8C24423/633, shadowing all 16 IO pins of each prop, up to 12ch of 14bit analog inputs. Up to 4 analog outputs
    ' SOIC8 pad can be used for one I2C device - RTC, FRAM, second EEPROM, SRAM, etc
    - Independent series resistor for every pin allows 5v compatibility, RS232 direct receive, VGA or TV drive etc
    - 6Mhz Osc module driving both props in sync
    - Keyboard and Mouse connection via Micro USB connectors (KB and MS must have PS2 compatibility, many do).
    - Programming port and power via separate Micro USB
    - DE15 standard VGA connection using slim connector
    - DB9F for serial or analog I/O using slim connector
    - Small LDO reg to drop 5v USB down to 3v3 (under)
    - 2.2" x 1.1" pcb approx
    - optional CR2032 coin cell daughter board sits between 2 D connectors
    features in the "stamp" mode
    - Single Prop (Media Prop) by flipping upside down and making a couple of links
    - Supporting chips as above
    - 3 wire serial achievable (transistors under)
    - Most/all pins 5v compatible depending on series resistors installed
    - 1.3" x 1.1" pcb approx
    - optional CR2032 coin cell daughter board to power RTC
    Also...
    - Each set of 8 pins has VSS and VDD at either end for ease of pullups, R2R ladders for DDC output, or jumpering for VGA/TV output etc.
    - Micro USB to USB A Female cables are available. I have found a few at $5~$8, but should be able to find some cheaper.
    - Analogs covering same 4 pins that Arduino Mini uses
    Once its a bit further advanced I'll put together a "benefits" analysis, but this should give you a good idea
    cheers
    tubular
  • SapiehaSapieha Posts: 2,964
    edited 2010-06-25 14:53
    Hi Tubular.
    Have You --- Part name and place to but that VGA connectors.
    I have on my boards footprints to that ones --- But not found Parts to BUY --- Have only ones that I dissect from OLD PC's.
    Regards
    Christoffer J
    Nothing is impossible, there are only different degrees of difficulty.
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    edited 2010-06-25 15:13
    Hi Sapieha,
    The two main sources I use are Kycon (available through Mouser), and 4uconnector.com.
    here's the kycon page domino2.kycon.com/website/dsubs.html
    for 4uconnector.com its well worth registering, because it will display pricing on all items. Up to 10 samples are available at good prices, but they can (sometimes) take weeks or months to get the samples together to ship.
    tubular
    edited 2010-06-25 15:58
    Hi Tubular.
    Thanks You.
    And good looking PCB You made.
    Regards
    Christoffer J
    Sapieha
    edited 2010-06-26 02:49
    Sapieha: I found those VGA slimline also at DigiKey (or else it was Future Electronics). Cannot recall pn.
    edited 2010-06-27 02:47
    Bill,
    I'll be sure to keep you on the loop with these.
    They will be loaded something like 8 to a panel, so there is some room for variants too. I'll contact you before I load the panels to make sure what you'd like is accommodated.
    regards
    tubular
    edited 2010-06-27 07:43
    HI Tubular,
    that's very cool. The included ADC will attract a lot of more people to the propeller
    did you do some raw pricecalculating
    I mean can you say the price will be more close to $50 or more close to $150?
    best regards
    Stefan
    edited 2010-06-27 13:00
    Stefan, I haven't crunched the numbers yet, but will do so later this week. But, definitely closer to $50 than $150, without a doubt
  • KPRKPR Posts: 189
    edited 2010-06-29 15:55
    Can you say.. My next Toy??
    Patience is a Virtue.. It's a shame I'm not virtuous!!
    KPR
    I always have someone watching my back.
    Yeah I know what you mean KPR. The slow PCB & assembly standards really sap momentum
    I'm in discussions with the board assemblers... won't be long now...
    tubular
