Is it possible to programme BS2 via RF?
Hi everyone (1st post)
Doses anyone know if it's possible / has been able to prgramme a BS2 via an Radio frequency link?
If so, can you provide basic info or links to sites with info on :
components required eg radio modem and connection diagrams.
Any help would be much appreciated
Well,·there is a device server that enable you to connect to RS232 Serial part via 802.11b/g wireless networks or Internet·so you could make a WIFI connection to your BS2·or BOE, but programming the BS2 wirelessly...·I don't·believe if it could be done!!!
you can look at:
Lantronix WiBox
Lantronix WiBox· = at ebay
PS. you can search here at the·Forum·-Search-·(upper right side)·write:· Lantronix·, I know there are some who has this device, you could read the posts and ask them too.
Post Edited (electrosys) : 4/25/2010 11:28:10 PM GMT
1.) Doses anyone know if it's possible? Yes it is possible.
2.) has been able to program a BS2 via an Radio frequency link? Don't know, but don't see why not.
3.) If so, can you provide basic info or links to sites with info on: components required eg radio modem and connection diagrams.
This would take a lot of research and is probably best addressed by someone who has actually done it. However, to do this, all you need is two wireless modems. But these can be expensive. So an alternative would be to build them yourself, which could be accomplished using two more BS2's and two Parallax 433 MHz RF Transceivers (Item code 27982) and a bit of programming, but not much.
I asked the questions thinking someone might have already done it, thus·saving me the time & having to·re-invent the wheel so to speak.
Interesting ideas from both Zuddie & Electrosys.
I will try a low cost approach using two basic stamps & two rf modem modules & post any success stories including diagrams & parts used etc.
Thanks again
Parallax Engineering
Thanks for your timely response.
I posed the same question direct to Parallax support via e-mail & the response I got was "We are working on a Wi-Fi product that might be available in December"
Would you have any more info on the solution that you mentioned which did work?
Also more info on the "specific sequence of events on multiple pins to initiate programming" would also be useful.
Many thanks again for taking the time to respond to question & sharing your valueable knowledge.
I think the easiest and perhaps most inexpensive way to do this would be to use either an Xbee transceiver or a BlueTooth transceiver or the Parallax 433mhz transceivers and a Propeller on the "client" end. The Prop has enough memory to hold an entire tokenized 2k-16k Stamp program plus the utility itself. I would see it working like this:
- master PC initiates comm. with remote transceiver and sends 2k-16k of tokenized Stamp instructions.
- remote transceiver simultaneously dumps incoming transceiver buffer to Prop RAM
- after receipt of all tokens as bytes, the Prop runs a small utility that initiates the programming sequence on the Stamp and dumps the code.
There used to be a product, the ToothPick or something like that, which was a BlueTooth host and had a Stamp programming "emulator" that could be used to program the Stamp via wireless link. But it was maybe $100 or $120. I think with an Xbee and a Prop and some homework on the master PC side for transmitting the Stamp tokens and bit-banging the Prop to emulate the programming sequence, this could be built for < $40 for the "remote" side, and just the cost of another Xbee for the master PC side.
Hmmmmmmmmmmmmmm......
Post Edited (Zoot) : 4/27/2010 10:43:22 PM GMT
Credit for the·Stamp > program > Stamp belongs to Tracy Allen and his detailed explanation on his web site http://www.emesystems.com/BS2clone.htm
Jeff T.
my idea laptop connect by wifi and used remote desktop software to send the code by Picbasic, that simple?
